- 99, 140k miles, need new suspension. what am i looking at for cost?
- My maxima. R.I.P?
- Power Steering Pump, how much to fix?
- Electrical problem, need help asap.
- taking the max camping
- more interchanges
- cv axel interchange
- Question about tinting 95-96 red/clear tail lights?
- Your opinions please
- To Upgrade or Not to Upgrade. I need opinions. . .
- Struts that best resemble stock??
- Vibration during acceleration
- The BEST 4th Gen Commercial
- Engine check light, 5 errors.
- E-10!
- Bad missfire only below 2000 RPM?
- knock sensor update
- annoying interior rattle
- So finally my car is all stock and ....
- Tein Coilover Setup...
- another horn not working please help.
- injen CAI question
- Question about superguled tranny drain plug.
- Check engine light intermittently working
- 9.5" in the rear...
- My Maxima - modifications/problems
- My radiator is leaking, can i still drive??
- rims deciscion. 03 maxima or 05 G35 coupe
- How to make polyurethane mounts
- Replacing axle seal?
- Suspension overhaul - need you opinions/knowledge
- to fix up, or run it into the ground
- Illumina strut/shock/spring kits vs. HP strut/shock/spring kits
- Fog lamp help!!!
- Can I tow a 4x8 or 5x8 trailer with my Max?
- Broken Fan!
- 1000 rpm when the gear is "N" or "P"???
- which struts!
- The Wizard performs magic with CF fabric on custom steering column. Tons of PICS!!
- offset concern- can someone show me a pic of a 4th gen with a32 i30t rims?
- shifter broke at base!!!
- Drove over high part of drive-way curb and scraped under car near wheel, oil dripping
- Car Died on Highway - P0325 and P0340
- Why do VQ30 exhausts sound like ****?
- HIDs for R34s...
- I'm back after 5 years!
- Gauge Cluster Wiring Diagram
- DIY: Oil pressure switch?
- Driver Side Headlamp problem
- Wheel opinions FTW !!!!!
- New Intake...
- Knock sensor hard code..?
- who has 300zx wheels on their max?
- Sand blasting aluminum?
- Will ignition coils from a 2000 fit in a 99?
- 00VI Guys...4th or 5th Gen IACV?
- Monitoring the engine...
- Radiator Question
- A/C freeon?
- Hard starts, stuttering, and backfiring
- Horns blowing on their own
- Knock Sensor and mechanic
- Aftermarket fog light replacement bulb
- How to install headers?
- hissing...possible fuel pump?
- Strange sound from right front wheel area ...
- OBD1 OBD2 question?
- I need an Exhaust gas analysis.
- replacement bumper help
- Pathfinder Bose unit question
- Another problem yay! wheel bearing?
- Big problems
- poly urethane mounts
- Throttle Body SeaFoam
- Sticky for gauges needles
- High Beam/Low Beam REWIRE question
- How were David L tails made?
- Alternator whine
- Help with Emissions Test
- IACV cleaning- weirdness with warm up afterwards.
- Car starts then dies
- Is a 42 pound rim and tire, too much for the max?
- Has anyone ever shipped out a stillen kit?
- loss of power...can it be my valve cover gaskets?
- knock sensor code
- camber suspension problem
- what is this ebay crap?
- few questions regarding rear brake/rotor/hub maintenance.
- Antena
- 230TE
- just got the evo II installed but....
- Injectors firing when motor is sitting, start problem
- Carfax question about a maxima
- Removing interior trim
- Broken seat motor cover
- Clicking from rear when braking?
- Question Right side parking light brighter than left???
- Fuel Inj Question
- Symptoms of clogged CAT
- Help wth 2 rear intake bolts.
- OUCHHH
- suspension question
- I love my cruise control
- E-brake light always on
- I30 Swap
- Time for Shocks?????
- Where is the tire/wheel info listed?
- What are the real world performance specs of a 4th gen Maxima(after 100,000 miles)
- Suspension drop question
- Car leaks!
- replace cv axle or just boot 180,000 miles
- fuel needle? question?
- Am i screwed? time for a new tranny?
- Will 350Z rims (& mounted tires) fit maxima?
- battery light and brake light
- ecu codes after reset
- Window Modulators in the Max keep on breaking...why is this?
- how to take off rear speaker covers??
- 0201 biggest pain in my a$$
- Audi s4 Projectors???
- Check engine light is blinking while the car is running...WTF?
- How to remove coil wire clip ?
- A bit of a strange gas mileage question
- Will EGR hi/lo cause a rear 02 sensor CEL?
- Heated seat wiring question
- Problem driving on the highway today
- A/C clutch disc removal
- Hawk Pads Rattle--Any Ideas?
- Car shaking and CEL flashing?
- Which Knock Sensor to buy
- How to tell if wheel bearing is bad?
- Upper perch on rear springs is ****ed, need some sugestions
- need some wheel opinions
- Which O2 sensor is it?
- CHEAP GAS!!!
- tire suddenly started leaking air (no nail)
- Fuel Induction and Power Steering Fluid Check
- Spoiler or NO Spoiler
- How to change a radiator?(didn't find it in the stickies)
- Fuel Inj Question
- Calling all Exhaust/Muffler Guru's, Altima SE-R Muffler on 4th Gen?
- Checked TPS with Multimeter, didnt read the recommended 5volts
- New clear tails 97-99 w/pics.
- starter on the way out?
- replacing axle question
- knock sensor
- gooey taillight stuff
- Rear strut question
- stupid car still choking
- Tail Lights not working
- pics of overhead console w/o sunroof?
- Have KYB dust boots improved?
- '96 has developed hard starting issues.
- Hit a pothole, now shakes
- almost got hosed. thought needed new alt but was belts/
- 95-96 spoiler fit 97-99 trunk lid?
- Where to buy window trim?
- 97-99 Front bumper question...
- Changed plugs- Got a new car.
- spring break project:00vi swap
- driveshaft removal and installation
- Brake noise (tight caliper?) Q
- Alternator issue, need help!
- check engine reset procedures
- More then one maxima
- wtf is wrong with the clutch
- Warpspeed?
- Anyone ever swap in a 5th gen blower motor?
- steering rack bushing?
- AC IPS bearing
- My last post?? Got a new car (non-Maxima), selling a few mods, thanks for the help
- Manual steering rack
- mazda 3 wheels
- PS return line
- Removed antenna, keyless/clock/homelink dead.
- 250,000 Mile Maintenance
- Vibration on acceleration problem.
- Rear caliper piston won't screw in
- Driver side Brake Problem
- Belt Adjustment
- Replace CV boot or entire axle, dealer or shop, OEM vs Autozone
- Goodbye to the .org
- I just recieved my red clears tale 97-99 .
- Installing a B-pipe on a 99
- 95-96 Led Tail teaser pics.
- Car popping out of 1st gear
- My 95 Max 5spd vs Jetta GLI 6spd (turbo) VIDEO
- Healight Aiming Suggestions!
- nissan consult
- tranny clunk helpppppppp
- PCV change today
- Z32 caliper MESS UP HELP ASAP
- Exhaust Flanges...
- Anyone else's Starter get gunky after a about 6 months?
- changef fuel filter and created a problem?!
- how much do you think this is gonna cost to fix?
- getting tired of not being able to put people in the back
- Blower motor cover
- Tested my Knock Sensor, read 530 M-ohms...Operational?
- StaLLinG ISSuE !?!?!?!?!?!?
- WTB Exhaust Cutout
- time chain tensioner again or what?
- Brake problem....PLEASE HELP ASAP
- !!!Start Problems; Please Help!!!
- Coilover questions
- Time for the blackout(non-alcohol related) - Black Carpet, Dyed Headliner and pillers
- NOOBIE THREAD ABOUT VQ35 SWAP
- How to do the dye test?
- anyone ever use Prime Well tires?
- CV Joint - Need Advice ASAP
- KYB GR-2 what to buy, and mounts?
- Spoiler and removing it to replace clips... AGAIN
- The start of my E-Manage Ultimate project
- Stillen Kit installation question
- How to: Create custom LED Map/Dome lights[Tons of pics]
- When I do my short shifter this summer, can I improve my Gates?
- light buzzing/high pitch whistling noise after 2 amps, components, and sub installed?
- thinking of buying a 95-99 maxima any tips info advice??
- Replacement Pearl White Paint
- Bad coils HELP!!!
- Starting System Scenario
- Did I damage my computer by turning off the CEL often?
- HELP!!! Key Lock Cylinder Replacement
- Who is the REAL "Budget" exhaust company?
- LCA Bushings/sway bar bushings
- a trim question
- pics
- Ticking noise
- 2009 4th Gen Calendar
- need help....???
- Changing Water Pump, Need Help!!!
- 4th genners also insomniacs?
- Wooden trunk liner
- Good day for Max, replaced driver CV axle and passenger side hub/spindle in 2.5 hours
- Car KEYS anyone? Replace your Key?
- Painting calipers
- Newb Ride Height/Rims Question
- Any way to reduce Bee's in Can sound? ALSO battery terminal making fuzz
- Car wont start..starter?
- Anyone get clicking sound near iac?
- P0136, will any 4 wire o2 sensor do?
- where is the thermostat in engine?
- Uninstall Bose unit...where to start?
- Custom Floor Mats - Any good?
- Any special tools needed for lower ball joint and inner tie rod?
- Whistling sound towards the right passener side
- battery voltage
- power steering pump
- cutting the 3 nubs on the 97-99 headlight
