- Anybody seen these on a 4th gen?
- Trouble with A/C Unit
- Bleeding brakes!!! changed fluid... now no compression in brake pedal!! help needed
- Deer vs Maxima....( I lost)
- striped tails. $2.99 mod
- How do I take off the passenger side view mirror?
- New England Maxima Owners??
- Lowest times from a stock maxima??
- NWP Engineering spacers installed w/MEVI
- brake light cel....
- Cant get O2 sensor off!
- Never looked at a Y-pipe... Is this real?
- Car feels slow....
- Performance Fuel Injectors
- Timing Chain job cost $2,700
- Transmission problem?
- ECU TEST
- can't adjust rear height on coilovers
- Painting questions
- AC Want Blow on 4
- burned out dash lights?
- Clutch pedal question...
- Part Number Request
- Keyless entry not working
- Shudder in 2nd
- Tranny Help
- Exhaust fitment and quality questions
- First one who tells me what's wrong gets $20 via paypal
- Valve Cover Gasket Question
- spongy brakes
- Will these look good on white?
- gr2 with stock SE springs. anyone have this.
- stillen pop-charger......
- 97 black supercharged max, is it worth it
- LED license plate lights
- painted badges
- best way to red/clear tails, AE heads
- rpm gauge
- A pop and a shudder while turning
- air con problem
- A/C Clutch Disc Wrench Necessary?
- $850 - $900 for Tein Basic Dampers
- Tip of spark plug...GONE!?
- knuckles interchangeable? wheel bearing replacement
- is there a better strut bearing out there?
- fog bulb burnout issue??
- Maxima Gurus Please step in .... stumped here !!
- Starting
- Anyone have any idea what this might be? *vid included*
- the strangest thing that happen to my max
- camshaft pos sensor leak?
- lost the oil dipstick
- Replaced alty, now a/c doesn't work. wire on a/c compressor?
- Electrical problem
- Disassembling cylinder heads?
- Strange electrical fault
- axles, noise etc.
- Car "stalled" and would not start.
- A/C line condensation
- Best place to get an Alternator online?
- This is weird... three ribbed belt
- Brake light/Turn signal swap
- why can't I get this CV axle into the tranny?
- Switch placement
- Changing CV axles on 5sp - should I drain all the gear oil?
- how do i find a leak in my a/c lines?
- Summer project: 00VI swap. gathering all the parts. Have questions
- new y-pipe and cat, why is low-end dragging?
- Connecting H.I.D in fog lights
- annoying front driver noise
- Help changing PS belt
- Lateral link noise
- Front driver side suspension squeek w/ VID
- My soon to be I30t*Pics included*
- 02 Sensors
- the stealership that is nissan - my recent experience
- LED interior lights *PICS*
- Sound from wheel pissin me of!!
- why did you buy a maxima?
- squeaking in the rear suspension
- Are the R34 headlights any good?
- Any known mods for the maxima that will allow us to keep acc mode on without keys?
- Clear Tails Question
- Leaking Trunk.....any suggestions on how to fix this?
- OOIV swap help needed
- What are some good HID brands?
- Raising rear end..
- Comments on installing my UDP today.
- car shut off today when i threw it in neutral
- Ripped Hose - What's it called?
- Replacing axle seal
- Climate Control No Worky?
- 280 miles on a tank
- 5th gen mirrors install, need help with base
- Alternator R&R
- Clicking sound while cornering - but none at slow tight turns
- My right front fender is dented in...can I just swap it from a junkyard?
- 96 Max SE Oxygen Sensor and airbag questions
- 1996 GXE question
- B4 and after
- tranny leaking? ***PICS***
- why does my car sound like a remote controlled car?
- Rpm's rise and fall
- Funky Transmission
- Trans Cracked ... can I "JB" it?
- Knock sensor problem ... ebay knock sensor?
- New LED Tail Lights
- Why can i start my car with no key??
- Cleaning El-Cheapo after market K&N wanna be filter...
- OEM Rim Swap...ftw?
- Which 4th gen body style is better?
- Trouble with Manual Tranny
- How long can I drive on bad differential bearings?
- power loss from 2k-2.5k rpm's
- anyone black out their OEM corners?
- y pipe
- Just bought 97 5spd SE. Put my mustang wheels on. . .ha
- Using LED tails
- Yaay! Got my first check engine light!
- Best MPG ever on my 99 this weekend
- EGR valve issue.
- my car pics when it burned
- Idle issue
- my max had a make over today.
- Mevi Help
- need advice on radiator?
- Do I Need To Drop This Thing 'Er What?
- How Do The Fogs Pop Off?
- Ebay Item FeedBack 4th Gen
- clicking sound?
- need advice on tail lights
- ??????Vafc or Safc w/ DEK??????
- help with replacing bose system with aftermarket
- Tranny Grenade FTGDMFL!
- 1995 with 1999 power seat...problemm
- Engine cutting out while driving
- Motor or engine question
- How can I repair "door panel clip" area?
- Official 95/96 to 97-99 Steering Wheel Swap Guide
- so i think im getting another 4th gen
- Springs - KSport GTs or Tein S-Tech?
- how to tell when brake pads are worn out
- Hard start help please
- Hard Starting / Pulley problems..
- Short Throw Installed
- Stillen Kit Question
- Weird sound from engine: Vid Inside
- Screeching from driver's side
- Intake Q
- Are Fogs supposed to get reallllly hot?
- Maxima GIRL!!!
- Just got this 98 5-spd SE, take a look (Lots of Pics)
- parking brake light and trunk
- Another projector refit on the way
- Pic's of the '02vi Painted
- Stillen RSB
- Very strange clutch problem-PLEASE READ
- A bunch of engine related problems cropped up suddenly
- Will These Part Numbers Fit?
- JWT Chip and Z32 MAF or SAFC II and Z32 MAF
- Pulstar plugs
- Replaced fuel Inj
- Spring Tune-up...CV Joints blown
- Keyless entry - Radio - Clock not working...
- mevi or 00vi on a 3.5
- How much did yall pay for headers/y-pipe installation??
- DEK swap 80-90% complete
- oil leak, now what?
- hit the curb at like 25mph
- my car sucks in the rain!!!
- Vibration over 70 mph.
- ptatohed's "exterior decorating" (pics) [part 2 in a series]
- P0600 Code No MIL Light
- Questions about replacing a rad
- Power windows problem: cable stipped.
- Photo Request... M45 Rims On a 4th Gen
- FREAKING YPIPE!!!!
- Weird problem.
- Best place to get tires from?
- Where is your 4th gen rusting?
- How water tight is your 4th gen Maxima? Does your trunk leak?
- rotor brembo or oem with oem pads
- help shaving my trunk
- I really need help here...
- 98 steering wheel not lining up with 95 mount
- sticky tach issue...
- Ask a Idiot who just stripped his Knock Sensor threads by over tightning Anything!
- 4th gen side skirts
- IAC Electrical schematic
- Jumpy tachometer - anyone fix this before?
- The official y-pipe thread
- Energy Suspension LCA bushings "squeeky" ??
- Is there a HOW TO on replacing Water Pump?
- Fidanza flywheel
- VAFC help with intake and y-pipe only?
- Spring Suggestions
- would 5thgen springs fit the 4th gen ?
- O2 sensor issues.
- I need a boards opinion on Ksport Coilovers...
- Sound Clip Request... Everything Stock + Cattman Catback and Megan Catback
- Is this a good deal? 1998 Maxima for $5k **PICS**
- Car won't start. Is it the starter?
- Tranny Guys step in!
- For a 1998 Max GLE/I30 with stock suspension, what are the ride heights?
- Shopping for rotors
- Check front strut mounts
- Axle/driveshaft replacement and tranny fluid
- Time to Replace the Bose....Pioneer FH-P8000BT???
- Please help me to see this deal.
- DUBS on my MAX
- The worst exhaust system I have ever seen
- Grill & door handle painting: what should I expect?
- DEK swap owners
- Differences in parts between 95-96 and 97+
- 95-96 to 97-99 trunk switch... same right??
- Pulled Trunk lid with spoiler... Will post as I go for HOW TO
- Brakes
- "HUMMM" after Rear Brakes were changed
- check engine light ?
- CAI vs Short Ram?....
- What tool is needed to change rear brake pads on a 98..
- WTB: 95-96 Cruise control steering switch
- Best deal on strut mounts
- Knock sensor, bad gas, something different??
- Poll:4th Genners with sunroofs, Do you rock the sun/wind deflector or not?
- Startup belt squeel
- Problem with engine starting on prospective Max
- Coilover and Strut/Spring Guys... What'd You Pay?
- PCV valve
- RMS Replacement Photos...
- Anyone have access to Nissan part number system?
- o2 sensor problems
- Meguiar's has nothing on my headlights!
- Got a knock sensor code, replaced Knock Sensor, Reset ECU?
- About time for a new PCV valve
- ANYBODY HAVE OLD ENGINE MOUNT?
- HOW TO: Custom A32 Large Bore MAF
- Could 5th gen stock airbox setup fit a 4th gen?
- Weird rear caliper problem
- Strange screetching noise when stopped
- Hmmmm, 2009 Maxima?
- Locating replacement tranny
- quick help needed: will this fit my 97 GLE?
- Rear Calipers
- Stock SE rims with S-Tech springs?
- rear driver side brake sticking, smoking
- Shop installed rear struts wrong, plz help!!
- P0100 and P1335
- Hood struts not holding up hood
- REALLY Weird '98 Problem
