- Learning with lights.Xenons.
- What to do with my a/c...
- 95-99 SE 16" Alloy Rims Question
- Reprogram ECU
- exhaust for sale
- Lowering your car?
- Another Strange Hard Starting Problem... Possibly ECU???
- 2k rpm problem !!!
- A couple of things regarding gauge cluster mods...
- What car alarm/Remote start ?
- where to buy knock sensor? cheap
- HO alternators. Anyone know where I can get one good price?
- I can't see!!
- clutch line confusion!
- Replaced 3 starters in 4 years—What gives?
- Any cheap possible way to mod our back seats to go down?
- Fuel problems slowly creeping
- DRL = Passenger side highbeam
- R34 fitment issue
- Bad idle, bad driving, and p0300 code
- selling cool stuff, turning in the max :( pics
- Spark Plugs
- Jumpy temperature gauge
- tire rating max speed
- 95-96 SMOKED tails
- dead battery or alternator?
- 5th gen clutch install
- Everyone should invest in this Scanner
- having a problem with my maxima (LONGG STORY)
- Can damper pulley squeal?
- Apexi afc version 1 or 2
- defroster fuse locaction?
- Y pipe installed, getting smoke from the pipes? Like evaporating...
- Additional information on replacing your transmission
- might have clutch problem
- Need help with rear brakes...complications.
- fx35 18's
- Spotted 4th gen!!!
- Strange headlight problem on 1995 Maxima no low beam on one side
- Need some assistance please
- 97-99 stillin lip kit for 1996 nissan maxima?
- belt size for unorthodox underdrive pulley and no a/c?
- Little honorage
- Quick and dirty power antenna mast replacement
- 0505 Code: No Failure Recorded/Detected
- key fob question
- Are these parts interchangeable from a 99 to a 95 & 97?
- 99 to 95 ECM swap a Success! +1 Later NATS :)
- Need help diagnosing a weird sound (RPM 1100 - 1300)
- Grill on 98...........
- Ionic Lip kit install??
- Please tell me this is my axle gone bad (Video)
- new motor mount thoughts?
- 95 gle 5spd swap. 2 faults so far, any comments will help
- Retrofit question
- Where to buy KYB Strut Bellows (Dust Boots)??
- Air bag light on, bose radio not working, possable water damage
- OBX Catback System
- Steering at highway speeds
- New fenders already painted?
- 0-60 times for our cars? Getting Lots of disrespect from ricers.
- Tein Coilover Q
- Do our remotes generate random codes?
- Hard starting question: Hold key for 15+ seconds before car starts.
- Alternator help!
- Ambient light in Maxima
- Resonator Removal
- Bose surround sound
- STERLING MIST was made '98-'99 right??
- Rack & Pinion leak
- cam sprocket spacers for vq35 swap?!
- Replacing alternator
- checking motor mounts?
- '97 cali spec
- 97 SE MT / 5 Speed to 6 Speed swap
- Knock Sensor Fail Inspection in NJ?
- 11 year old radiator: how long can it last?
- CAI vs Short Ram
- Engine Mounts Please help......95SE AUTO
- Battery questions
- Brake Booster Question
- Does Your 4th Gen Have Starting Issues?
- 5th gen mirrors
- stillen lip?
- Moving from my trusted '95 GLE to a '97 I30
- How do I remove the A/C condensor?
- How to replace window regulator
- Noobish intake question
- Big CA Smog Check Problem
- Metal Scraping While Starting (Long read)
- iPhone Bluetooth Connection for Bose HU?
- 95/96 fogs
- got my lip kit :)
- Is my MAF sensor done?
- WTB: Black Armrest cover Climate control knob
- How are 99's and 00-01 strut mount bolt patterns different? (regarding stillen FSTB)
- Hit a semi-truck Tire on the free way...scariest thing ever
- A33 Maf on a VQ30DE?
- Question about Front Windshields
- My painted interior is GONE! :D
- Engine swap choices, which is the SMART way to go?
- Changing plugs... unpleasant finding
- www.motorvate.ca?
- emissions due and P0446 code
- changing the fuel filter! ISO advice
- Car starts....sometimes.
- TCM Compatibility - Any differences?
- Ok to use Matic D in the power steering system?
- Total capacity of fluid in the power steering system?
- Brown Dash: The Scar That Won't Heal
- woodgrain steering wheel
- 15th Anniversary
- rotor rust did'nt dissapear after driving all day????
- Oxygen sensor Codes question
- really weird electrical problem
- Info on changing out front wheel bearing
- so my engine blew last week...
- I think im going to get rid of my car. Rust is causing expensive problems w/ exhaust
- Help! LCAs Installed.....Funny Noises!
- Pic Request..5th gen GLE wheels
- Still No air/ No heat
- How many miles till ECU resets?
- No start in cold weather unless push started
- Bad hesitation under power, tachometer drops too...
- tokico blue's warranty claim
- aftermarket steering wheel..... horn / cruise control / airbag ???
- Has anyone tried Blacklight bulbs for......?
- bose speakers not working
- update: redesigned mount for 4th gen installed> pics
- knock knock?? fail?
- Short Throw Shifter
- starter question
- Radiator Fan making very loud grinding noise!
- 1997 Starting issues
- who knew? 469530 ohms
- What are the signs that my alternator is going?
- Hood strut installation instruction
- Need new tires(no one answered in tire forum)
- Car is studdeing really bad at WOT Help!!
- Car does not start anymore!
- Diagram for 0807 Solenoid Valve
- 95 to 99 catback swap.will o2 sensor work?
- Check Engine wount go away!!!
- to buy or not to buy
- Head light shot today..
- HELP!!! MY CAR IS DEAD !!!
- got my CF mirror shells :)
- Maxima Wont Start
- broken headlight mounting screw
- Electrical Shortage
- 4th gen one piece?
- Torque converter housing case, is there a gasket?
- OK, CEL!!!!!!
- had to take my foot off gas before trans shifted 95 auto
- Its been a crazy CEL week.
- Please Read I need help asap!!!!!!!
- Battery Light on!! Break Light on!!
- Do Upper Oil Pan Leak With E.Mounts?
- rear anti-sway bar installation
- 95 Max SE starting problem revisited...
- GAS DEPLEMINSHING
- New CAI Issues
- What year ECU is "B6"? I searched, but....
- Is motorvate down?
- battery drain help please!
- Growling noise passenger front
- gear shift indicator light
- auo TPC on MT throttle body?
- Knock senson bypass question
- !!! help i cant find park in my car !!!
- Replace input shaft bearing
- Car stalls under low rpms
- 95 maxi starting problems.
- Free Serpentine Belt Wear Gauge!!
- rpm tak prob
- Struts, the good, the bad, the cheap...
- How to reset the fatory alarm
- Sister's car is acting strange - Please help
- Update....New Starter installed same problem....need help
- Anti-seize for Spark Plug Threads?
- Need a new muffler... some suggestions?
- no interior lights please hlep
- Where is this tranny leak coming from?
- What other gaskets needed for WP project???
- 95 max mistery harness
- exhaust question
- carbon fiber hood question
- Bad clutch maybe?
- is my car really an SE?
- Pre-Cut Tint
- Tranny leaking fluid
- Code 1605
- Inside trunk dimensions for our maxima?
- Is this proof that my steering rack is bad?
- my car missed 3rd gear??
- Rusted radiator support
- CEL 0801 Part Number
- Output of tsx projectors
- sea foam question
- My car wont start Pt. 2
- jdm tranny install now hesitation during start
- 2008 Stock civic si vs. nissan maxima 4th gen..
- Heating and A/C vent buttons don't work
- Spare Key with chip and automatic starter question
- MAXIMA VS BENZ ?!?!
- SSV4 Suprastick 5.5 gen
- weird brake/axle problem?
- Power steering or rack and pinion?
- Finally----5spd conversion question
- Putting badge on. Need help
- High Flow Exhaust With Good Noise Reduction?
- removing stuck caliper bolts
- how to insert the pass side axle?
- Battery/Brake Lights on at the same time
- replacing cv axle, got questions
- Engine Swap 1999 engine in 1995 Chassis?
- Question about strut replacements
- rebadge mytrunk
- The LED Light Picture Thread -Exterior-
- steering problem - quoted $1600...WTF?
- blinded by the light
- 95 Maxima Doe's Not Start but cranks! HELP! plz
- What's it worth?
- stock air box removal
- idle issue...HELPPPPPPP
- KS...Is it REALLY worth replacing???
- sensor questions
- Can't get the hazard light to illuminate ... ??
- Trunk Finished.
- brake pads ??
- Bank one, Sensor two is..
- M.A.F Sensor Ghost
- Tranny swap....
- Heated seats + Heated Mirrors
- High performance transmission rebuilt kits for our maxima's?
- check this out VQ25DE
- Clock AFR mod
- Header Back Exhaust cost
- transmission?
- 00VI Swap (Help Needed) Pre-Installation
- KS Resistor Install With Pics
- repair exhaust pipe
- Fuel Pump or Ignition Coils?
- 80 MPH - Car Shakes
- Tires for 97
- Oxygen Sensor Replacement
- How to test your maf?? help.
- cam sensor? leaking (pic)
- XTREME HIGH EXHAUST !!!
