- Headlight question
- How do you get original keys?
- Photoshop Request !!!
- OSCAI - Plumber's CAI :)
- replacing starter solenoid
- Redesigning A32shop.com. Images?
- 4th gen in Dibs commercial
- Moog Sway bar links
- painted sawblades
- tokico suspension set up problem on 95
- WHAT WENT WRONG?
- Problem Shifting out of park! A/T
- Monza Exhaust
- Auto Shift boot installed. pics
- Maxima refuses to start
- HOW TO: Install the Suprastick V4 for your 4th gen
- I've read all the starter posts...
- Whats the deal with breather filters?
- darn airbag lamp flashing again
- strut install...need help
- 98 Maxima Day-run light dead
- Picking up new used car
- Any solution to the P0600 code?
- AE engine cover
- Maxima z32 300zx BBK Conversion?
- Bizarre electrical problem.....
- Another y-pipe question from me . sorry guys
- Exhaust install
- when to replace springs?
- quick question about a y pipe
- wierd noise when ac on... help pls
- 95/96 'Ebay/CE' Red/Clear question
- center console done! pics*
- Weird relay problem :(
- Quick question about engine bay cleaning
- Need help with pioneer install
- Need help
- G35 staggered rims. Can they mount without aything else?
- 96 5spd idle, stalling, deceleration problems
- My car wont start and I am stuck in parking lot
- 4th gen outside cab air filter
- anybody happy/unhappy w/aeroturbine?
- I need help with a hayden 401
- Factory Alarm and Intermittent wipers stopped working
- Overheating and weird starting
- Victory pipes on the max!
- installed new ss clutch line.....you guys must be lyin'
- Actor Morgan Freeman in a Maxima Car wreck last nite...
- suggestions about agx struts
- finally, it came in! suprastick teaser pics
- 5spd swap, shifter hits up against heat shield. what to do?
- cel still on?
- P0171 System Too Lean (Bank 1)
- ECU Code help
- engine stuttering... HELP!
- Steering Wheel CD Controls
- Air Ducts
- the best ingredients to black/clear tails
- Installing RSB- do I need rubber silicone spray/grease?
- have $3k to invest in a maxima sugestions?
- Inset rear wheels? Just curious
- question about coolant level check
- PIAA 2100 Fogs Installed (Pics Inside)
- HELP---Need to replace front wheel bearing....
- Help With swap in Dallas,TX
- $189 cefiros? ftw...?
- Monro Rip Off
- AC not cold after new radiator install
- Knock Sensor install on a 1999 I30t Cali Spec
- idle like a diesel??
- Cefiro Headlight Question
- Clutch and Flywheel ques.
- ENGINES SWAYS!!!!!!
- Painted SE 16" center caps
- What would cause abnormally high power steering pressure?
- anyone with conzult or similar here?
- replacing thermostat
- VQ35
- blinking cruise control light
- "Throttle Shock"
- SUSPENSION FOR AUTOCROSS!!!!!
- FULL EXHAUST
- MAXIMA BRAKING CALIPERS
- $600 suspension budget, option A or B?
- Warpspeed Lately?
- Looking at a 97 5spd
- Loose Sun visor, How to fix?
- 12k HID lights anyone have them? Legal?
- some help
- Looking for specs on a particular bolt
- Maxima starting problems
- FYI- new? smoked amber bumper lights
- Car will not start....no spark
- Its not the ign. witch or the starter
- No tail lights HELP
- intermittent brake issue
- CV Boot Replacement Time
- Leather repair question
- Speedo Problem
- Sounds system completely went out, head unit still works though
- where can i find a 5v source?
- jdm projectors ?any1 seen these
- ABS light goes on and off intermittently
- Heli Coil for Transmission pan bolts?
- 03 i35 steering wheel on 96 max
- After 3 Maximas, making the jump...
- Cleaning salt corrosion from sawblades
- HELP...Mushy clutch!!
- Pulley noise - harmonic dampener or other?
- RIMS for my Pearl White SE
- EU 2-step question...
- Front suspension member issue - Stripped bolt
- Newbie Question Reguarding Engine Oil???
- Weird Alarm Problem
- Sunroof won't slide back
- NEED ADVICE ON INSTALLING HIDS FOGS
- Anyone not like Tokico HPs?
- Door handle lining removal
- Engine bay makeover
- is there any way we can put THIS in our maxis?
- What to look for when purchasing a used 4th gen
- Clutch Advice
- Rear Caliper Question (sticking??)
- Shifter trim shape
- 5 spd tranny problem need help!!!!
- Urgent Problem
- Where to find the best deal on window motors.
- Code P0138
- High-flow cat or Test pipe? For better sound and perfromence
- Front Marker Lights???
- different intake?
- 97 5speed couldnt put car into any gear
- Resetting ECU.
- When you buy foglights for a GXE do you need to buy a stalk too?
- 2 problems: Doors lock when I slam LF door, leaking PS hoses
- Exhaust question
- HOW TO- 5.5 Gen Front Brakes on 4th Gen
- how to remove spoiler from trunk lid
- Finally I sold my I30.
- spent the last 4 hours trying to take off the KS *epic fail* any alternatives?
- Question about brake pads
- when the car is turned to "on" is the check engine light suposed to be on
- Where is the EGR valve?
- Stereo problems
- Has anyone gone to Autozone and bought a Duralast coil but instead got a Nissan coil?
- Installing LEDs
- Check engine light several codes
- What is this piece on the throttle body?
- help with greddy muffler sizes
- Is having extra HP in your car mess up the trans?
- do our factory anti-theft sound when lock/unlock?
- Dash, climate and radio lights turn off COMPLETELY when headlights are on
- Mulling Over Carbon Fiber But I Have No Experience With It...
- Significance of the C-clip on the drivers side axle
- how to improve D2 coilovers.
- Clutch problems
- rusted nut, strange question(s)
- XENON vs ,MTEC Halogens (4 kinds) vs. Sylvania Xtravisions
- help with codes
- 00vi(hood or no hood)
- Coolant Leak on 5th gen maxima (made it into engine)..
- 95-99 DiamondCut Euro Headlights OEM Replacement (Clear Corners? 95-96)
- didnt pass socal smog
- Thinking about getting a drop, and have no idea how to go about..
- Changed my KS. Got the CEL cleared the car feels no different...why
- Blower Resistor or Blower Switch?
- Is it save to drive on 2 strut screws ?
- Trying to rest my ECU and now SES light went back on... lol
- motor swaps
- Shaft: hub or splined end?
- How do i reset my ECU ( I HAVE Searched)
- P0400 EGR Problem
- spark plug gap? should i bother or no
- Congratulations to The Wizard! - The Wizard's Maxi. featured in Nissan Sport magazine
- womp, womp, womp?
- My hood wont stay up automatically
- no sound from stock bose system 95
- Ground plug help plz ...
- Bose HU shutting off randomly
- please help...car stalling out
- Going one up in tire size from stock?
- New Clutch/Flywheel
- For thouse who has trannys rebuilt/replaced what milage did u do it at? Auto only.
- att those who have headers on the there max
- changed my fuel filter and maaan was it dirty!
- Need some help, cracked oil pan
- Flash lights or beep on unlock?
- Better for HID's? - OEM Cefiros, aftermarket Cefiros, or R34-style?
- Imput Shaft Bearing or Throwout Bearing?
- new/solid motor mounts???
- Power Steering Fluid Leaking
- fuel filter the out side is down or up?
- Difference in A/C condensers?
- fuel filter placement question
- Clutch Problem?? HELP!!
- obx catback.... 97 maxima
- Are our AC systems designed not to activate if there is not a certain amount of.....
- Where is the ASCD control unit located?
- 10" sub in between rear 6.5
- Just a recomendation...
- Tranny makes sounds after rebuild.
- out with old, in with new
- I'm Desperate, what is wrong with my dam car?
- stillen or Magnaflow?
- Wierd A/C
- Spoiler Light - Model PUT-SB-001, 4 screws... approx 20"
- Maxima lowering question
- Where to buy ASCD clutch switch?
- 5 speed swap concerns.
- running amp wires... help
- Anyone know what this is?
- Spring Recommendations for Illuminas
- cars been pulling very crappy... Time for tuneup
- Flashing airbag light on 99
- Low gas indicator light
- Rear wing
- DE-K have different mounts/brackets?
- What oil filter do you use in your 4th gen Maxima?
- does 98 come prewired for powerseats??
- Couple wiring questions...
- Foglight problems
- just wondering how much would it cost to convert to stick.
- Pulling off viynl on rear window
- Ugh.. this is starting to get on my last nerve
- :))) HAS anyone thought about tan leather seats in black maxi
- Radar Hardwire *Pics*
- check engine light IACV related
- maxima twin turbo?
- Pondering battery relocation, Have questions.
- Am I missing something?
- need help, ball joint or control arm ???
- Bose Eats My CD's....
- Bee-r limiter installation
- Code p0420
- Need clutch / clutch pedal expert help ...
- Question about 97 maxima car audio system
- What would you do ??
- A/C smells bad, I tried Lysol, something's not right!
- Cleaning Maf video
- Ebay ignition coils
- Can't find the leak....
- Im back and im black :P
- spark plug stuck in the engine
- Help w/ P1605 OBD II Code
- alternator question
- Noobie Brake Noise Problem Question! Help
- QUICK: should my buddy buy this max?
- What is wrong with my car!!! trans issue? chime in maxima proz
- removing "maxima"
- Over the next few days ill be changing my transmission, questions and pics in here
