- taillights....not altezzas
- Matching AT control unit
- driver side power seat stuck???
- good mechanic in around central/norther nj
- oil leak.from..?
- Power Steering
- Plug in Power Steering Hose?
- Any Old Magazine Scans of Maxima Reviews?
- Spotted Black max in West Palm Beach
- Driver's side visor lights dont work?!
- 300zx Clutch Disc same as Maxima?
- police dashcam of 4th gen...
- coil pack blew up? pics
- loud rattle in morning start up...
- Tranny Swap
- HTP Billet 4th Gen MAF Adapter
- Will a 95-96 BCM work in my 99?
- Rear Suspension Alignment
- Exedy Stage II Chattering
- Change power steering fluid?
- what is a h4 harness??
- sunroof height adjustment?
- Cattman End-of-Year Sale now up!
- Oil light flickers at stops (sometimes)
- trouble starting
- Has anyone bought carbonfiber hood recently?
- R34 Fitment
- Need recommendations for winter floor mats
- What do i need for a BBK?
- Alternative Spoiler Available?
- The mods you LOVE that u've done
- HELP AXLE HELP
- Lights dim at High RPMS.
- How do I fix the rear door window?
- Few question..
- intermittant high idle after driving on fast/extended trips?
- cut a wire .. did i screw something up?
- Engine braking....
- ~~(some advice?)Starting Issue~~
- Back of headlight Rubber protector?
- Has anyone bought anything from 2kracing?
- gas cap pressure release??
- Car throwing bad codes, Bad ecm?
- Magnaflow Y-pipe/Cat Assembly
- Merry Christmas Everyone... Free FSM, Recalls, TSBs... Everything
- Got Rear Ended by a fking WONDER BREAD truck!
- MAF?
- Very stupid question...SE/GXE/GLE??
- Flashing CEL. A Diagnostic mode of some sort?
- Does your clock go BRIGHT when the dimmer's turned up?
- Exhaust Leak in Flex Tube - Any Fixes?
- P0300 code, can someone help me. Im stumped
- Anyone have these 18" OEM MAX wheels?
- 95 Max running rough - Help needed
- Vibrant catback
- I hope someone can help with my starting problems
- NeoWedge led's in climate control?
- *-***Bodykit question***-*
- part number for master cylinder firewall spacer need for swap
- Suspension Problem
- Can Mitsubishi Evo MR wheels fit on 4th gen?
- Antifreeze in my tranny fluid??
- 200,000 Miles!
- Maxima sitll stalls when warm
- Thermal Element for High Idle in TB
- engine oil leak, front seals...
- what tool set is best for our cars????
- Opinions plz on suspension combo, Blues&CMS
- performance ideas needed HELP ME!
- How do you know if you have bad bearings?
- rear valve cover gasket-repair info
- what do you guys recommend? (headlights)
- New Front Seats – looking for options
- Bell Housing Code
- stillen battery tie down worth it???
- Adding Power Seats
- Dead Fuse?
- Gear Whine
- my OCD was acting up....
- Need help; my car wont run but its starts up
- clamp to big for battery terminal
- what hood to get.
- I need a picture of...
- Clutch issue
- looking for oem or better lca's for my 95..
- Anyone do an auto-dim mirror install?
- Transmission Search/Swap Nightmare
- That Black Sealant Crap Around Our Tail Lights?
- Exhaust question
- Best place to buy Shocks/Springs
- 4th gens in North america = built in Japan
- Next is a GREDDY SP2
- Front brakes... calipers?
- poor 4th gen! I hate to see a ricer behind the wheel of a max
- Battery
- Fidanza vs. Stillen Flywheel ... What other parts are needed?
- how to make fog lights be on without headlights.
- do i need it? ..cap
- Newbie quesiton about Ypipe
- ANYONE WHO CAN HELP!
- Replaced Belts and now there's a knocking noise
- very particular brake and gas pedal problem
- Whole car starts vibrating at 60+ MPH, plus shake steering wheel.
- Radiator does not fit
- 99 Rear brake/axle question
- 160k miles, should I replace springs, shocks, LCA, what about the ebay kit?
- Quick Question on Exhaust Gaskets
- Locked myself with keys in car while working on door lock Actuators - HELP no spare
- To Overdrive, or not to Overdrive?
- Front brace rusting out
- shudder on accel at low speeds
- Greddy ultimate
- After market coils
- Pulled the codes.....
- 5 speed conversion and abs
- Nissan and Infiniti factory service manual in PDF
- Simple Question - How to Remove Fog Lamp on 96 Maxima?
- door speaker "case" problem
- Tatanko's Christmas Thread 2008
- dead battery, where's the drain?
- I do believe this is a noob question
- Happy thanksgiving At Maxima.org
- Help! Car pulling but then straightens
- Heating problem and 02 sensors
- AG lowering springs...?
- transmission going bad?
- catch can install??
- Another security Q?
- How To - Install Headlights
- Drop Zone struts
- Maxima wont start after HID install.. Help!
- Car stalls, hesitates, after driving 25 miles and is warm
- Methods of securing OEM struts to FG/CF hoods?
- Ignition Problem
- A/C not working
- Racing Seats / Side Air Bag?
- Awkward gear shifting
- New C/V's installed / Loud popping noise + jerking under acceleration
- Ignition Switch?
- HELP!!! Reliable Mechanic in Atlanta needed
- VAFC II pink wire
- power steering pump may be going??
- Misfiring? Bad Gas? Any ideas??
- Acc. belt tensioner MISSING?
- Brake light lit
- H&R spacers
- How much should I pay for a ABS speed sensor?
- ruby pearls...almost extinct?
- brake problem
- Need your opinion
- my 96 black maxima i have some questions
- help me find my leak
- need nissan part #
- R34 Headlights run both High & Low beams at the same time?
- Parking brake sticks on when it is cold...
- Steering Rack - In Progress - Need Help
- My odometer and trip odometer just stopped working...
- Intake Resonator?
- Possible temp sensor issue?
- Help with Antenna
- Transmission Speed Sensor location
- Tail light problem
- 4th Gen Maxima Video from Nissan
- O no another retro.
- Quick question about my radiator
- Time to say 'bye'...
- need a car fax report. anyone
- Adjusting AGX's.....
- another "knock sensor" thread, but look!
- Got my Stillen lip kit today........
- gas smell at start up....
- symptoms of bad transmission
- mother nature meets the v
- Blinker Problems
- Antenna Mast no retracting - repair or replacements?
- Big Burn smelling at the WOT
- Great VID who's car??
- P0440 evap code?
- Which HID do you guys recommend?
- Exedy Stage 1 Overkill?
- WTB: 3inch exhaust
- Overheating and no warm air
- removing fuel pump?
- Would Someone Photoshop These For Me?
- Thinking about this car
- Weird Sound from Tire
- Weird hesitation and s sudden viberation
- Car doesn't start....HALP!!
- relay for turn signal and hazards
- VLSD vs. non-VLSD axle differences?
- late model manual tranny in 4th gen (possible swap)???
- PCV Valve
- ABS sensor is stuck. Help?
- would black signal lense look good>?
- Idler Pulley or AC Pulley Bearing
- ECU question ??
- WHO WANTS A CARFAX HISTORY REPORT?
- Fog Light Question
- clunk sound when put in reverse gear
- Starter Possibly?
- engine is smoking
- Anyone use 300 ZX rims on their 4th gen
- Oops, now what do I do...
- Lugnut threading problem
- Grinding noise after axles replacement.
- my little "build" need some help...
- LED Help and tips
- Do you have to cut anything when you install K-sport coilovers?
- VSS OD Blinking Problem
- OK what the heck is going on?
- 2000 Bose headunit fit/work in 98 SE?
- Re-wire the good one
- 2009 Calendar ready for purchase! Thanks Guys!
- Just to be sure...rack for 99 will fit 95??
- stillen lip kit price down
- Exhaust droning noise, not enough back pressure?
- USA Spec PA11-NIS iPod adapter
- FYI Guys... It's The VC Gasket Not The RMS...
- Will these 19"s fit the 4th gen?!
- Reverse Lamp switch in trans, help!
- projector fittment in r34's
- Mounting the ZUNE?
- Just installed front suspension (struts&springs), hearing noise, need help!
- Tire sizes
- o2 Sensor
- Good Mechanic in LV
- Repeated Injector Failure
- Just changed my fender (PIX)
- Looking to Buy First Maxima - Advice Needed
- Which fuse is for the driver's side mirror lights?
- looking to replace my Exhaust *advice*(*pictures*)
- Got a little rust
- transgo shift or reprogramming kit?
- code 0505
- WHY do I get 12MPG?????
- Codes, Codes, Codes
- Adding additional fog lights?
- Strut boot and bumpstops
- Wheel Bearing help (pics inside)
- Anyone else have uneven head lights?
- Lowering springs question
- trunk won't open
- cattman header question
- quality of megan lowering springs
- looking to get a 4th
- Grounding issue? Car starts, int. lights work, wiindows/radio/climate control don't
- ebay rack and pinion?
- Stillen Exhaust
- How to install 97-99 fog lights?
- DO NOT! I REPEAT DO NOT!!!!!BUY AFTERMARKET UNDERDRIVE PULLEYS!!!!!!!!
