- Egr gasket forgotten after intake manifold assembly?
- looking for an exhaust video of sp2.....
- Radiator Cooling Fans (Help!)
- Looking for someone to LED my speedometer
- 95 se automatic stutering/bucking when I put the foot to the floor?
- knock sensor related
- so what do you guys think about this maxima?
- Egr Valve code issues
- Tachometer doesnt work...
- Is it possible to drop a 4th gen without a bone jarring ride?
- 96 I30 or 98 MaxSE + questions on each
- Average Temp. for your Maxima
- Dealership Inspections
- POLL: WHAT CAI DO YOU THINK IS BEST?
- Haunted Bose Radio and clock
- Help installing factory cd in a 1997 max
- 2005 seats on my 95?
- idle drop
- Quick question
- Power Steering Leaking - Rack/Pinion? Gasket?
- P0100 & P0110 codes...
- i need help with projecor mod *PIC's*
- ebrake problem!
- Diff. Engine Sound+Slightly Rougher Idle (EGRC Solenoid - CEL - or Timing Chain?)
- 00vi and egr help needed
- Where can I get this done?
- n/a sounds like turbo...wtf?
- I need a solution and some torque specs!
- 99 Only, Do you have rear deck rattle? I think i found the problem...
- Clattering Sound From Back End
- Troubleshooting starting issue, HELP
- Ignore or fix? EGR and Knock Sensor
- Half-and-Half Intake Setup
- RSB install.
- Which intake to use for Seafoam?
- 95 MAXIMA SE Might sell....thoughts?
- 1995 SE with lots of upgrades
- Is there issues with wheel alignment when car is dropped 2"
- Can anyone tell me the name of the color of this maxima?
- bad mount????
- Maxima.org FTW!
- Quick question
- PIAA Xtreme White Plus or Super Plasma GTX? (H3&9004)
- List of issues...
- my e46 retro - big pics
- throwout bearing
- Squeaking suspension, weird oil smell, and knocking when i have defroster on
- Weird Idling issue!!!!!!
- water pump
- AC compressor
- transmission output bearing
- AT 2 MT
- Starter: Nissan Parts Vs. Autozone
- How To: Fix Your Spoiler LED Light
- y pipe
- Estimated labor costs
- A32 headlight replacement problem
- My motor got loud recently.
- stupid question about towing a maxima.
- blew a d2 coilover again, rebuild?
- Strut mount problems?
- Starting Issue 00vi/Injector related??
- Tranny rebuild. Does this look like the right kit??
- Starting Probs When Cold
- Starters & Alternators
- Did anybody replace their idler pulley assembly?
- is this right?
- Whining noise alternator or belts? what is it?
- Streetglow LED's
- Quick Question: Will OEM 03 Hood Struts fit on a 95?
- Maxima!!!
- 1106 code
- O2 Sensor - Upstream
- Wheel Bearing problem... i think.
- Prepping for Roadtrip
- car leaking oil and coolant!!
- I'm tired of low quality buttons/clips/screws/retainers that Nissan provided.
- regarding a short antenna solution (power mast into stationary connection) - question
- Starter Sig
- For the guys with auto ecu w/ 5psd
- Replaced starter, now engine dies
- Intermittent Extremely High Idle
- question on trany swap
- What would you do with two Gen 4's?
- No starting issue - help!
- Wierd faint whine when cruising 5-20mph
- chipping the ecu?
- PLEASE HELP! Need 4th gen Radiator Install DIY ASAP
- clutch kits advice, OEM vs Daiken Exedy
- Code po1320 cant clear
- plastic coolant reservoir '96 and '97 same?
- Loose Hoses?
- Help me solve my Starting Problem
- '95 Automagic rattle 1st gear
- horn upgrade????
- how to wire low beam to go on with high beam
- O2 Simulator / Fed Spec Y-Pipe on Cali Spec
- grease monkeys
- Sunroof makes screeching noise if you hold either button
- Driver side door wont open
- Harness for rear 02 simulator
- Put stock suspension on, my steering still 'uncenters' itself over bumps.
- Automatic Transmission Failure
- Speaker Rattles??
- Car stuttering/buckling/almost stalling at idle AND while cruising
- Great all motor edition = NWP SPACERS
- SE-L question
- Finally Got A 5 Speed
- quick catback question
- Transmission dipstick won't stay in place
- 99 maxx transmission drain plug size
- I need to make a decision on a Clutch, anybody have any suggestions?
- Spark plug danger?!
- Looking for a new muffler need some advice
- How to wire a Remote Start
- dimmer switch led?????
- i wish...
- Engine Temperature in a 96 GLE
- Actual NISSAN Brand Gas Cap?
- Axle replacement question
- compression test TAKE II
- Car not starting / stalling again!
- Leaving the .org
- Installing subs to bose deck, wire question!
- fuel pump fuse??
- Max Sounds like a boxer engine.
- I need turbo insight
- Just replaced engine, now need help of course
- WON'T TURN OVER/ starter/alarm
- Maxima leaves me stranded. Alternator issue?
- Where can I buy the Cluster Rings?
- Tranny Flush and Fluid Replacement options? or opinions? on whats best.
- Recommendations for ebay STB's that WON'T dent the hood?
- CEL 0803 What is this?
- Brand Specific: Autolumination.com's Halo.Xenon Bulbs - 6000K vs. 8000k -front look?
- compression test gone bad!!! help
- will they fit
- Looking for Link to Junk Yard Search
- Auto shifter led problems
- Aftermarket Cams and idle ignition timing
- Bose amps?
- Custom exhaust Question. Butt weld or overlap? Opinions/Experience?
- I wouldn't buy a 4th gen after reading this
- injector question...
- got me another 4th gen
- ecu swap on 99 maxima
- DropZone Shocks???
- Exactly What Bulb Size Goes into the A/C Controls?
- Its not a coil pack
- question about swapping engine.
- Tell me my trans is not going bad. . .
- Kill Switch Help
- Motor Oil over #5 spark plug
- Looking for a 4th Gen Maxima Owner: Description Inside
- Brake problem a few questions
- MAX ON DUBS
- Minor Leak - Engine Oil?
- Finally dropped...Total Failure.!!!
- Code 0205 Idle Speed Control same as IACV?
- Auto Trans Gear Display?
- 96 Maxima hard to start
- Scary brake problem at -25.
- ECU has code, but no CEL
- help with tein coilover
- about JDM maxima's true or false
- R I P VQ30
- P1335 Error
- For someone who SERIOUSLY knows power steering issues
- speedo question
- What is this?
- need some sensor help!!!
- Q about i30 lip on a 96 maxima
- Need a picture
- 1997 Max: Hard Starting [With VIDEO]
- Manual Trans Re build in NJ
- where to get a pully assembly? checked all auto part stores
- brake issue question
- idle shaking and loss of power
- Tuesday night accident , need help
- ecu question
- Code 0807 or 1008 Differences?
- rear suspension
- Seeking clarification, 02 thread pitch
- Speedometer off by 5-6%
- Q/A will a 4th gen 97 vq30de fit & work in a 5th gen I30 2000-2003
- Only 3000 miles left...
- Operation Tranny...complete
- coolant issues
- cold/hard start.. w/ video please help!
- Remote Start Installation
- ECU question
- headlight weak?
- What is a good catalytic converter to buy?
- GREDDY EXHAUST SPECTRUM ELITE
- Cold Start Auto Transmission Stalling
- Help me order the correct gaskets (VC, oil pan, and?)
- code 1008 evap purge and why did I do it?
- Q before i start my retro
- High idle-intermittent-need help
- P1105 code. confusion about finding a sensor
- Replacement radiator fan
- My bent lip
- garage door opener on 98 ?
- Left driverside air vent stopped working
- Xtal ( Chrystal ) Gauges
- 110k off a starter ain't bad
- BRAND NEW NM1-HDSS ACT clutch for 95-99 maxima
- 4 gen maximas with 5 gen wheel owns...
- please not the rack.
- Please... Welcome me back...
- fast and the furious 4
- lca question......
- MY christmas Gift (yay/nay?)
- Wierd light problem??
- weird problem
- broken tensioner on ac and alternator belt.
- Swapping Speedometer...
- Looooong 1st gear
- Quick newb question. What size is the stock exhaust supposed to be?
- Thanks & Farewell
- catalytic converter/ exhaust
- ecu screw broke now car wont start
- brake light doesn't light up
- strange starting issues
- How do I remove the leather off the seat?
- Got Spoiler Repainted - Now I Need New Clips!
- Help. Can't get my Tranny out.
- hard to turn steering wheel nooooos
- for those who want a new floor layout for your trunk. (QUICK write up)
- fuel hoses leaking.....
- Anyone have 4th gen steering rack part numbers?
- P0505 IACV Circuit
- ignition coil location #4
- Transmission Trouble
- 95 Maxima Won't start
- Climate control buttons dont work (and weird fog lights problem)
- 1996 Maxima starter issues.
- Engine starting problems?
- guage cluster swap....now MAJOR problem
- Slave cylinder
- Looking for one of these.....
- leaking steering rack. ideas for fixing?
- Low Beams Work But No Hi Beams
- Anyone Automatic chirp 1st @ around 3500-4500rpm?
- kyb gr2 + eibach springs question..
- wire diagram for coil pack harness
- Which clutch?
- Tranny pan bolts
- Brakes question
