View Full Version : Fluids and Lubricants
Pages : [1] 2 3 4 5 6 7 8
  1. Fluids For 5th gen
  2. What oil should i use on my 2000 i30
  3. Royal Purple
  4. Shell Rotella T (ZDDP)
  5. 5w-20, what happens?
  6. Oil Deal! - Castrol Edge + Purolator Pure1 for $2.66 Total!
  7. Just Changed Oil, But May Have Made Mistake - What Now?
  8. Walmart supertech 7317 filter vs Mobil 110 and Supertech Synthetic
  9. Filter Alternatives
  10. Nissan Esther Oil??
  11. Oil Cleanup - How do you clean your Oil change materials?
  12. any recommendation of oil for 123K with oil burning?
  13. switch back & forth from synthetic to regular oil?
  14. Castrol Synthetic or Castrol Edge Synthetic??
  15. HOW TO: ATF Drain and Refill
  16. Due for an Oil Change in 1500 Miles
  17. YOUR CHOICE IN MOTOR OIL
  18. Synthetic gear oil
  19. 2004-2008 Oil / Filter
  20. 244,xxx miles/first oil change
  21. M1 EP test results..
  22. CAN AMSOIL REALLY DO THIS??? Please share your Amsoil stories...
  23. Changed to Amsoil GL4 + Amsoil 0W-30 and got 35 mpg!
  24. Mobil1 deal
  25. all castrol oils $12/5qt at walmart
  26. First Mobil 1 5W-30 synthetic oil change
  27. Shell "Nitrogen Enriched Gas" ?
  28. mobil 1 ATF?
  29. Best deal on redline mt 90 trans fluid?
  30. quick Q about oil change
  31. Summer Gas Blend & Better MPGs
  32. Best engine oil to use with 167Kmile Max 97
  33. recent price of fluids (tune-up)
  34. '04 SE w/105k ATF change
  35. Mobil 1 on sale at Costco
  36. how much oil do I need?
  37. NEED a simple answer??
  38. Greased Lightning (synthetic magic grease!)
  39. Reserve Fuel Capacity 02 SE (U.S.)
  40. Motul Products
  41. What Exactly is Nissan Matic-D Fluid?
  42. diff. oil visc for a 3.5 that burns oil?
  43. Lube Gard AT Protectant
  44. NPN Filters
  45. Shell Gasoline with nitrogen?
  46. 50¢ per quart charge to recycle motor oil??
  47. chevron gas, contains ethanol?
  48. Mobil-1 back on store shelves?
  49. Changing ATF fluid on 6th gen
  50. K&N Oil Filter
  51. How to differentiate manual transmission fluid from synthetic engine oil????
  52. Anyone Know a Thing or Two About Wheel Bearing Grease
  53. Castrol edge?
  54. Which is the better motor oil??
  55. Gold PureOne
  56. Oil Change
  57. Brake Fluid with low freezing points?
  58. So now that Valvoline Synpower brake fluid is discontinued...
  59. frozen oil
  60. Looking to switch to synthetic
  61. Octane booster and fuel injecter cleaner
  62. Another source for GL4
  63. Who Are The Top 3 Oil Filter Manufacturers?
  64. royal purple??????
  65. Redline Water Wetter Question
  66. How long have 9E000 filters been made in China?
  67. Thanksgiving Week Special
  68. Topping off anti-fr and ps fluid-what to use
  69. Acura Antifreeze
  70. Oil starvation damage repair
  71. using atf to clean engine before oil change?
  72. Should I Check Engine Oil Cold or Warm?
  73. Penzoil platinum??
  74. Who does
  75. Nissan Fluids Online
  76. Mobil 1 ATF "new formula"
  77. Shop refilled with too much oil
  78. Radiator Drain Plug
  79. Engine Oil Report
  80. New Mobile 0w30???
  81. ODD Gas Octane Pricing Lately
  82. Amsoil oil ?
  83. Tranny fluid
  84. Cabin Filter change
  85. tranny oil weight question
  86. Mixing break fluids
  87. My car ran on syntetic from 60k to 137k then went to regular can i go back to synthtc
  88. German Castrol Deal at Autozone
  89. 04 max Oil quantity vs recommended?
  90. What weight oil do you use, and how many miles on your car.
  91. redline water wetter
  92. FYI Guys... Pennzoil Platinum $3.98/Qt.
  93. synthetic vs. conventional
  94. Do you guys trust WALMART brand SUPERTECH fluids?
  95. Would AMSOIL Synthetic ATF Benefit an old 1993 Maxima?
  96. AutoZone - 5qts Valvoline Full Synthetic + Bosch Filter = $9.99 AR
  97. Z-TECH Fuel System Cleaner?
  98. Valvoline SynPower syn. VS Mobil 1
  99. transmission fluid
  100. HOW MUCH COOLANT LOSS IS NORMAL IN THIS HOT WEATHER?
  101. Whats a good thread lubricant?
  102. Water2Gas Upgrade Kit
  103. Royal purple
  104. the 3,000 mile oil-change myth.....
  105. Clutch bleeding procedure
  106. Seafoam in gas... for your lawn mower
  107. 1997 maxima 5sp manual transmission drain plug stuck
  108. "Hypermiling"
  109. Does this really work or just another BS?......
  110. Clutch Fluid Replacement
  111. 5 Quarts RoyalPurple + Wix Filter for $35 @ O'Reillys
  112. So I did an oil report ----- UPDATE
  113. PX3 Extreme Oil Booster
  114. Mobil 1 0W-30 Advanced Fuel Economy
  115. Anyone running straight E85??
  116. Gas rating
  117. Octane Rating question...
  118. DIY: Gravity Method for Brake Fluid Change
  119. Belt Dressing / Conditioner Good or Bad?
  120. How Do I Change Brake Fluid?
  121. Transmision fluid level?
  122. Can The Color of the ATF on the Dipstick Determine Service or Not?
  123. Has anyone used Terraclean
  124. Where to get synth brake fluid for my 04 maxima in Detroit?
  125. LUCAS OIL PRODUCTS
  126. Interesting Octane Article
  127. quick oil question!
  128. Changing Coolant but drain plug is beat..
  129. Idea for tranny flush...Will it work?
  130. 5.5 Gen 5mt gear oil recommendation.
  131. Engine Cleaning additive recommendations?
  132. Mobil1 synthetic 10w30 high mileage?
  133. Mobil 1 EP-change oil every 15K miles?
  134. Your experience with synthetic ATF
  135. D3 Synthetic ATF Cost
  136. Changing axles on auto - how much ATF needed?
  137. Blackstone UOA - VQ35 60K miles
  138. Mobil 1 5w30 Truck and SUV?
  139. SuperTech 75w/90 gear oil
  140. Lucas Transmission fix
  141. Gas Treatments with 93 Octane
  142. Where do you guys get chevron techtron in quebec, canada??
  143. Oil burning smell
  144. mobile 1 m1-105
  145. Bout To Switch Over
  146. Can the dealership do synthetic oil changes?
  147. When should you change up fluids?
  148. Used Oil Analysis
  149. walmart supertech synthetic?
  150. Are generic hoses at Checkers OKAy as heater/coolant hoses?
  151. Blackstone oil analysis with German Castrol 0W-30
  152. Brake Fluid Talk.
  153. coolant disapearing slowly
  154. 4th gen check engine? oil?
  155. Regular gear oil recommendations?
  156. Seafoam
  157. GM Syncromesh fluid?
  158. Flush or just drain?
  159. AMSOIL DOT-3 and DOT-4 Brake Fluid
  160. Would I benefit?
  161. how much tranny fluid?
  162. Changing Transmission Fluid....Safe or not?
  163. The process of switching over to synthetic?
  164. 4th Gen Break Bleed order?
  165. Amsoil Signature Series Oil
  166. Seafoam in crankcase?
  167. what fluid to use for the clutch
  168. What type of steering fliud shoud i use?
  169. Mobile Clean 7500 & Switching to Synthetic
  170. Brake fluid shelf life?
  171. To all you oil experts..
  172. Going back from synthetic oil to regular
  173. ? on antifreeze mixing??
  174. Acetone as a fuel additive to increase MPG???
  175. Rad mat'l and af changes
  176. How long before synthetic breaks down?
  177. Is royal purple just f***ing me royaly??
  178. How many quarts for the 6th gen?
  179. Dexron Mercon III tranny fluid
  180. Synthetic Oil?
  181. Just found some German Castrol at Autozone...
  182. Winter Fuel Formula question
  183. B&M Trickshift Vs. Mobil 1 ATF
  184. Any quick reference on what 100% Synthetic are made of?
  185. Free Synthetic blend oil change...should I do it?
  186. Supertech Synthetic
  187. Octane Mixing Safe
  188. Shelf life of unopened brake fluid?
  189. FLushed PS Fluid
  190. AMSOIL GL-4 75w-90 = EXCELLENT!
  191. Lubricate blower motor
  192. Esso XD-3 0w30...want some?
  193. mobile 1 extended protection synthetic
  194. how many miles to go on synthetic?
  195. Fuel injector cleaner....
  196. Visual inspection maintenance
  197. changing oil......
  198. refilling/bleeding clutch fluid
  199. Best brake fluid?
  200. Words of advice on AUTORx?
  201. Tranny AutoRx or Seafoam Tranny Tune?
  202. filter magnets
  203. Need to know which ATF to use...
  204. AMSOIL REP??
  205. Synthetic oil tests
  206. advanced oil filter?
  207. quick question on going synthetic
  208. My dipstick hates me
  209. Best non Syn ATF?
  210. Two-fold Oil question
  211. [Oil filters] Which type do you use?
  212. Switching from 10W-50?
  213. weird engine noise when cold.
  214. Intake Manifold cleaning
  215. Gas rumor...
  216. Motul 600 brake fluid
  217. How much extra engine oil is too much extra? I may have screwed up.
  218. My first oil change by myself.... <---noob!
  219. Increasing My OCI to 10 K Miles -- Based on Oil Analysis
  220. Royal Purple oil?
  221. Fuel injector cleaner?
  222. Oil Analysis: High Lead
  223. Interesting Article on Flushing
  224. cons of using fuel system cleaner too much?
  225. Feeler for Group Buy -- Renewable Lubricants, Inc. (RLI)
  226. Question regarding engine flush
  227. Sparkling oil...metal bits? Not good....but long
  228. Trying a New Blend...
  229. Why would Castrol GTX score so bad?
  230. Chevron Techron Cleaner any good?
  231. My First Oil Change...is it easy?
  232. Tranny fluid question
  233. My MPG goes down after every oil change
  234. permatex??
  235. Mobil 1 High Mileage??
  236. mechanic switched from synthetic to non synthetic
  237. What is Chevron PurEscape?
  238. K&N Wrench Oil Filter
  239. How's THIS for a good deal on oil? *pics*
  240. What kind or brand of antifreeze for the 2007???
  241. Overfilled ATF?
  242. could someone tell me the size of the Tranny drain plug?
  243. Check out my DIY engine and tranny UOA
  244. Royal Purple Advantage
  245. Thoughts on QPower QHorsepower Ferrari?
  246. Mechanic recomended I switch to synthetic "blend"
  247. Synthetic Oil Change Dangerous?
  248. MT90 not GL4 anymore?
  249. oil level high
  250. 99 Max, Tranny Drain And Fill (not Flush)
