View Full Version : Fluids and Lubricants
Pages : 1 2 3 4 5 6 7 [8]
  1. Mobil 1 Synthetic
  2. Tranny fuild
  3. Engine oil
  4. rredline tranny fluid
  5. Anyone try Cool Collar
  6. Engine Swap related fluid questions
  7. Question about manual transmission gear oil
  8. Change filter w/o changing oil?
  9. amsoil query
  10. Finally made my move to Mobil 1 Supersyn 5w30
  11. changing oil question
  12. water wetter / Mobil 1 syn
  13. do I need to flush?
  14. *Question regarding the installation of a new oil drain plug washer...*
  15. oil filter vg / ve filters.. differences?
  16. slick 50, duralube??
  17. Amsoil
  18. amsoil synthetic?
  19. Fuel additives?
  20. Oil for 98 Maxima
  21. Mobil 1 - 0w40
  22. 0w/30??
  23. Oil in my antifreeze
  24. Transmission fluid
  25. How do I change my oil? Should I use additives? Where can I research more about oil?
  26. Want to start chaning my own oil. Got some Qs.
  27. what kidn of clutch fluid is recomeended,
  28. How to change 02 MT fluid?
  29. Can changing MT fluid make existing leaks worse....
  30. Can I use Bosch oil filter A6000-30785
  31. trick shift for 90 auto max?
  32. discard oil
  33. Is additive for A/T any good?
  34. What oil and oil filter should I use? Can I switch to synthetic? What viscosity?
  35. how often do you change your mobil 1?
  36. Is flush recommended before oil change?
  37. What is good transmisson fluid for a automatic.
  38. AMSOIL Synthetic Oil
  39. Best Radiator fluid to use for boosted application
  40. Which grade oil should I use?
  41. Switching back and forth....
  42. Mobile One or OEM Oil Filter?
  43. Quick dumb question. How often do you change M/T fluid?
  44. changing ManualTrans. fluid became a nightmare!
  45. HELP .. need all opinions about transmission fluid change
  46. Synthetic Oil People - Oil Change Intervals
  47. Appearance of used MT?
  48. How to change manual transmission fluid? Which fluid: GL-4 or GL-5? Best gear oil?
  49. Amsoil synthetic
  50. Best Synthetics
  51. How offen to you change the MT fluid
  52. mixing 5w30 and 10w30
  53. Switch to Synthetic Oil at 84K
  54. MT fluid change
  55. brake fluid?..how often to change..
  56. oil capacity
  57. castrol syntec blend
  58. any one use royal purple?
  59. Summer Fluid Question
  60. Maintenance Gurus. Short Distance Drives?
  61. oil change
  62. tranny rebuild... question about metal shavings and tranny oil
  63. 15k oil change
  64. finally the lazy admin gets off his HICAS and makes an oil forum
  65. anyone use AUTO-RX in their max?
  66. VQ35DE new engine break-in - why 3750 for the 1st oil change?
  67. Warning about fitment issues of the Mobil 1 M1-105 oil filter on VQ30DE Maximas
  68. FRAM oil filter question...
  69. Engine Cleaning Additive?
  70. STP S6941 Fittment Issue in a VQ35 Maxima
  71. Nissan has discontinued the VE30DE - specific 15208-60U00 OEM oil filter.....
  72. Amsoil OIL filter help needed!! ASAFP
  73. Valvoline MaxLife Oil & ATF, Nissan Oil Filter
  74. OIl filter top by-pass valve. How important?
  75. Just hit 123456 and changed oil with a BIG filter
  76. Changing Oil Filter before Oil
  77. BlackStone Report: NOT good!
  78. Motor oil, does it play a big part in performance? yes or no ?
  79. First Oil Change
  80. 70K on my Max..can I switch back to regular oil from Mobil 1?
  81. Can I switch to synthetic oil at 58,000 miles???
  82. Best Oil for 2k2 6 speed
  83. K&N oil filters
  84. Oil change questions.....
  85. The Amsoil SDF-44, SuperTech ST3950 and STP S3950 filter do not work on VQ engines...
  86. Note on VQ35 Oil Filter Selection: VQ30 filters should cross reference....
  87. 3.5L Oil Filters Revisited
  88. How to flush automatic transmission fluid? What ATF to use? How to check the level?
  89. Engine Oil .....OMG help!
  90. 1st oil change
  91. Nissan Oil Filter vs. Others (ie. Mobil 1)
  92. How to flush automatic transmission oil and using Royal purple ATF....
  93. Help w/Tranny Fluid Change - Automatic
  94. Best Conventional Motor Oil
  95. Questions about Sythetic Oil Weights
  96. Synthetic Oil
  97. Just a little something for CFster (OIL)
  98. *12/30/04* Oil Spreadsheet-How do I take a sample? What lab? How to do more research?
  99. Just switched to Syntetic Blend
  100. Oil Changing question
  101. made the jump to sythetic
  102. Brand new 02 SE - Have initial oil questions
  103. AMSOIL API Certification
  104. 2001 Pathfinder VQ35DE problem!
  105. spark plugs and engine oil
  106. oil change
  107. Oil level very low
  108. Mobile1 -> I put my money where my mouth is...
  109. Royal Purple
  110. What Kinda Oil You guys Use?
  111. Synthetic Oil?
  112. Redline Oil
