- ? - Tranny Fluid Change for High Mileage Care
- Flush and fill with Amsoil synthetic in auto tranny results.
- Synthetic Oil and High Milge
- Differential Fluid Change
- fuel injection cleaner...
- Bosch Oil Filter Advice Questioned
- 96 max trany ? please help
- What oil filter to use?
- Anyone use the Pure One Oil Filter?
- changed from regular to synthetic...mpg huge drop
- BG 44k and other products
- What antifreeze to use: Red, blue or green? What does the radiator drain look like?
- Confused on Motor Oils and restorers, help
- Oil in the driveway
- Radiator Coolant Change -- 30k
- Dexron II or Dexron III - steering wheel
- good additives to Maximas?
- Best ATF
- Anybody use quarker state motor oil here?
- Denso oil filter? Nippon oil filter?
- Nissan OEM filters
- Is it ok to mix different brand of motor oil?
- Cost of ATF
- You burn oil? Or need a good valve cleaning??
- Problem???
- Octane Booster
- Is it bad to go over 3000 without oil change??
- b&m trick shift
- What problems using regular power steering fluid instead of Dexron III?
- GL 4 vs GL 5
- How much oil to fill?
- Redline MT-90 Cheapest Price You've Seen
- Spreadsheet update and the removal of Bosch/STP/SuperTech filters as recommended....
- is it time for mobil1 synthetic?
- Extra Special 6 speed tranny fluid?
- Uh oh.. switch from synthetic to non-synthetic?...
- Notchy shifting after long drive (when warm)?
- Oil Change Intervals: By Time
- Simple oil change question.
- OMG Please help fast!
- After Mt-90 (having Same Problem?)
- AT pan bolts and amount of fluid
- mileage with oil change to mobil 1 10W30 supersyn...
- mileage with mobil 1 10w30 supersyn
- Going to change tranny fluid (manual) what kind to use?
- Proper grease to use on caliper pins
- for those using amsoil synthetic motor oil
- Redline MT90 tranny fluid vs stock fluid
- MT-90 with A.E. VLSD?
- Oil temperature?
- Problems...What oil filter to get...
- AT fluid level
- Overfilling ATF
- 2002 -- 4.5 Qts Capacity
- Tranny problem?
- Redline gear oil or Royal Purple??
- Motul 5.1 or 600? Where to buy?
- Maintenance Questions
- Blackstone tranny oil report back
- Conflicting reccomendations for VQ oil change interval
- Redline tranny oil
- Should i switch to synthetic oil?
- Oil filters
- What's the correct ATF for 96SE
- 5W-30 or 10W-30 ??
- Nissan Filter VS Amsoil filter
- Two questions about using 300z fuel filter
- engine cleaner?
- Which oil filters have cardboard endcaps?
- brand of coolant?
- Bleeding Brake
- Bleeding my brake, what to concern?
- G35 Mobil 1 Oil analyses... not encouraging
- oil capicity
- Where is a guide for changing ATF
- Walmart Question
- Redline MT90
- ATTN:*All using Amsoil or Redline synthetic in 6-spds*
- Ryco Oil Filter
- steering fluid
- What is your take on the product restore.
- Causes of "shriveled" oil filter gasket?
- What kind of motor oil do you use in your maxima?
- Where do I start?
- mobil 1 manual tranny fluid
- M1-105 Equivalents (STP, Bosch)
- Oil Change Question
- Its time for me to make the oil decision. Step inside...oil party
- STP S6941 oversized VQ30DE oil filter now only $3.99 at AutoZone....
- Pep Boys: 11/15-11/30 1 Case Castrol GTX $0.88/qt after rebate.
- Leak sealer
- Diamonizer
- Change tranny fluid or don't?
- Should I use this gear oil?
- redline transmission oil?
- $11.94 Oil Change at Walmart
- Streering Fluid
- 91,standard trans.
- Oversized Filter with 225 Tires?
- Finally updated the spreadsheet.....
- simple quick question...
- Ironic and scary coincidence at the same time.
- Just switched to 0W30 Mobil 1. Whoa!!
- 1992 GXE Tranny and Oil Fluid
- 1 quartz of synthetic oil = $5, then 4.4 quartz = $17? WTF?
- ...is it true what I was told about motor oil to my 99?
- newbie oil change question
- Do fuel injector cleaners work?
- Atf Buy/change
- Which oil is better
- Finally decided to change the ATF - my story
- Finally changed the ATF - my story
- change oil filter
- Lucas Transmission Fluid
- ...So how often, if at all, do I change my trans oil?
- leak in engine main seal
- How do you replace the fuel filter? Which one should I get?
- Wow, what a difference a filter makes
- Coolant flush and capacity
- Quick Redline Question?
- What color is the Tranny Fluid should be?
- Penzoil Synethic, Jiffy Lube
- Mechanic told me NOT to change the trans. oil...does this sound crazy??
- Oil report: taken from a daily boosted, 265whp, 10psi, lean mixture VQ30DE-K
- Oil analysis of.....
- 1 simple simple question !
- how much oil?
- oil change
- For those who have changed their ATF, how much did you pay for it?
- Change Transmission Fluid
- How much brake fluid should I get?
- Rebuilding engine, what fluids should I use?
- synthetic on 2k max
- Pros and Cons of switching to synthetic oil
- OIL = semi-synthetic or full synthetic
- Good Brake Fluid Suggestion!
- where to buy redline oil online
- Oil Experts Please Look!
- Nano fuel additives to produce 10% fuel savings
- tranny fluid
- Transmission Fluid Flush
- Error code 1336 Crank/Cam Sensor Range/Performance.. what does it mean?
- Where can I get AMSoil ATF...
- Slick50 high mileage ATF treatment
- Synthetic Oil. Good, Bad, or Does it Matter?
- how often to change belts/hoses/battery?
- Opinions on Royal Purple ATF
- noob oil change advice
- Dealer tells me I need to change my power steering fluid (44K miles)
- Used New Oil in car. Looks really promising.
- Have never changed Transmission fluid after 285, 000km!
- Best Oil to use?
- Does anyone use a magnetic drain plug?
- flushing manual trans
- Viscosity Classifications
- Fuel Additive in a 89' Maxima? is it ok
- POLL: What manual transmission fluid are you running if you've already changed it?
- finally changed tranny oil... now running MT-90
- best oil for the 03 maxima
- how many possible drain spots on a manual 4th gen tranny?
- Naughty, naughty! My local nissan dealer fills their MTs with 80w-90 GL5...
- Couple of ? about Mobil 1, and Slick 50
- *125 000 KMS, still running on original auto Tranny fluid! What to do!*
- HELP!!!! brake fluid mixed with power steering fluid
- MT-90 doubts
- before I dump the old tranny fluid...
- oil filter question
- Switching to DOT 4 Brake Fluid
- 75W-85 MT Fluid
- Engine oil, what do you use?
- Oil Filter (How many times can it be used)
- Do I need a TBN for gear oil?
- Water Wetter
- What should be the color of drained oil
- oil drain plug won't budge
- Oil-how Full Is Full?
- Does Octane Boost work, or is it a scam?
- Oil analysis on 2k SE!
- Engine Oil
- what brand of oil you use?
- what fluid to use
- amsoil filter SDF-20 vs SDF-13?
- Changing oil! 3k or 5k or more
- Letter re. Syntec
- Long life coolant..
- Switch To Synthetic
- More proof of blown motor
- Redline MT-90 seems to have smoothed things out
- Switched to Mobil 1 last night
- Part number for 4th gen oil filter ?
- What oil to use in Fall New England weather
- Castrol GTX High Mileage oil
- Is the fluid in the P. Steering Resovoir..
- Royal Purple 75w90 Synthetic gear oil
- Is synthetic engine oil recommended
- Switching Motor Oil
- oil change question
- Never pull out Oil Level Guage while filling Engine Oil
- Need help with fluids
- OIL and FILTER
- ATF and Oil Pan Questions
- just put in redline mt90- I dont feel anything
- Oil Filter won't budge!
- Change to synthetic?
- Clutch hydraulic Fluid Leak. Help Needed.
- how to flush radiator?
- PM from member Droosh - Champion Labs comments on Mobil 1 filters for VQs:
- power steering fluid
- Change My Oil and Oil Filter
- Oil Filter Suggestions
- Castrol syntec 5w-50 for 92 ve engine???
- Oil and oil filter 2002 Maxima
- Synthetic or not to sythetic
- Super tech oil filter for maxima?
- which redline
- Oil Viscosity and Gas Milage.
- where can i get gl 4 synthetic gear fluid?
- Changing from 5w30 to 10w30 in the winter
- gear fluid change
- newbie to the oil change seen
- does anyone know how to lub the antenna rod
- AHHHHH!!! This is sooo frustrating
- Transmission Fluid Change == 30K
- OIl additives to prevent leaks?
- Mobil 1 Oil
- My Blackstone report: anyone ever see copper and lead levels...
- manual transmission fluid
- Is High-Mileage oil required for vehicles with over 100k miles?
- Is changing Mobil1 synthetic every 10K miles bad?
- How do you change the power steering fluid? What fluid should I use?
- Confusing oil facts!!!
- 18mpg + oil change = 23 mpg (long)
- may be smoother tranny
- Extended drain coolant
- 03 350Z what Oil
- Fuel filter
- Any info on Pureone oil filters?
- Marvels Mystery oil
- 94 Maxima Oil and Filter Help
- Coolant question. Dealer serviced.
- Awesome Techron experience
- Quaker State Oil
- Is Mobil1 Synthetic 10W-50 too thick?
- Supersyn - a true synth?
- 5w30 vs 10w30
- First Oil Change what oil???
- Best transmission oil for 96 Max.
- help oil on drivway how to clean?
