- Amsoil ATF
- Oil filter ? for Bill
- VQ35DE 3K mile OCI
- Mixing Toyota Red and Green Coolant
- What ATF's to stay away from?
- redline mt90 question
- Coolant disposal
- fuel system cleaner/additive
- Differential oil change - 4th Gen
- You Burn Oil ??
- anyone use mobil-1 75w/90 gear oil?
- Oil, Oil, Oil. What kind?
- Prioritizing fluid/service needs
- 5 minute Motor oil Flush
- Brake fluid question
- engine oil for the summer?
- Confused...
- Heck....I'm impressed!!!!!(Seafoam)
- Transmission Tune Up
- Two more Redline 10W-40 samples w/4K miles
- Is mobil 1 worth it?
- Bill....Some G35C oil test if you're interested
- Synthetic oil = more horsepower
- ATF change in my 1990 maxima
- ATF = power steering fluid?
- Changing filter w/ out changing the oil.
- 15208-9E000 filter and other oil Q's
- Want to know why the Seafoam and BG44 seems to make the car work better?
- best oil filter?
- Switch to Synthetic over 100K?
- recommended panel air filters?
- 5Gen Power Steering capacity and "equivalent" fluid?
- where to buy seafoam?
- bleeding brakes and ABS on 5th gen
- Intermediate Filter Change?
- Tranny Flush help
- Where is filler on '04 5 speed auto SE?
- Why does Nissan now only recommend "mineral based" oil?
- Oil Filters
- An interesting thought...but
- Which Auto Tranny Fluid should I use? shifts hard now
- Long version of K&N HP1008 Filter?
- Coolant change question
- time for major tune-up, have some questions
- Amsoil vs M1 Synthetic ATF
- 5 Speed Gear box oil
- AFTER how many miles do u change ur oil with 5W-30?
- After ATF change, level slightly over-full. Dangerous?
- I think I am leaking ATF? What to do?
- Help with ATF flush.
- its ben like over 1,000 since i switched to synthetic
- Where to refill the tranny fluid in an automatic?
- Synthetic vs. Regular motor oil
- Changing power steering fluid
- 60k tune up is upon me...
- 5w30 or 10w40
- Free 6 quarts of Synthetic Oil
- trans slippin after flush
- help! which oil filter?
- When to change synthetic oil?
- Sunroof lube
- Seafoam
- synthetic oil vs. petroleum oil
- Trans fluid change at Jiffy Lube?
- Royal Purple synthetic oil, Max-Gear???
- Mobil1 SuperSyn Longevity
- fram double gaurd filter
- Castrol GTX High-milage: The Facts
- OIL change in 92 maxima
- '98 ATF change question
- Different blends of oil
- Pennzoil 75w90 gl-4 oil?
- sea foam hose???
- Coolant question
- Few questions about switching to synthetic...
- quick question about ATF
- VLSD VS Amsoil series 2000 and Redline Mt90
- vacum hose
- How about Marvel Mystery?
- Used Engine breakin : Tips? Synthetic?
- Seafoam Vs....?
- Has anyone tried the Motive Power Bleeder?
- Probably OLD NEWS, but Bill any comments?
- will using synthetic ATF cause any problems or void the warrantee on the tranny?
- got my amsoil ATF! now.....
- Manual Transmission Fluid
- When should you change your transmission fluid?
- brake fluid flush/bleeding... Do it yourself??
- yet another seafoam question
- Speaking of Oil, what brand do you guys run?
- Quarts of Oil??
- AMSOil 5w vs 0W
- Mobil1 0-40W in
- Tranny Prob Info
- New oil standards?
- Auto Tranny fluid
- Transmission gear oil
- Seafoam + Maximas = pics :)
- Anybody using Lubegard Red?
- Drained engine oil color -- anyone tried out Auto-Rx
- How many qts. needed to change tranny oil?
- radiator/tranny flush
- Best Autotranny Fluid
- Auto Tranny Pan Bolts
- Changing oil today??
- need to order Amsoil Atf , where is a good place to do so ??
- Z-MAX???? :ben:
- Changed MT Fluid to MT-90 for the second time
- Low oil level but NO light?
- My review of Chevron Techron
- Compression tests vs. Oil Analysis
- Added extra oil follow up.
- Fluid for clutch
- added extra engine oil
- Book Says API GL-4 anyone use API GL-5
- ransmission
- Seafoam in crankcase. Directions don't specify
- Can someone tell me what Seafoam is?
- BG 44k has made me very happy.
- What kind of oil do u guys use?
- Who uses oil filter #15208-9E000 for 2k2 or 2k3?
- Power Steering Fluid = Automatic Transmission Fluid?????
- People who have flushed dino ATF with syn. Thoughts?
- Brake fluid comparison Dry/Wet Boiling Points
- Visited 3 Dealers, none had stock 300zx fuel filter. they gave me this instead....
- what kind of oil do you guys use?
- can i switch to syn.???
- MT and ATF
- Max Life and similar oils
- What ckutch fluid do you use?
- Where to get ATE superblue locally in fremont/bay area
- Prolong: Truth or Trash?
- Does the car have to be level when changing transmision fluid?
- Squeaky Brakes
- ROUGH idle
- what type of oil filter removing device do you use?
- bleeding brake
- Inspect tranny fluid at 15k?
- Best ATF syn trammisson
- Royal purple vs Redline vs Amsoi GEAR OIL
- Brake Fluid Sticky?
- Pennzoil ATF
- what tranmission fluid do you use for you manuals?
- Adding ATF to 98 Maxima
- What type of Sunroof lube?
- Changing OIL on 2002
- I was told by many that a Full Transmission flush would be a very bad idea!
- could someone give me the link...
- Leaking w/ Redline, is it a problem??
- $90 + 16 quarts for tranny flush worth it?
- My review of Mobil 1 systheic ATF
- Mobil 1 105 vs amsoil SDF-20?
- Changing oil of MAX opinion???
- I accidently ordered Redline MTL!!!!!
- redline mt-90 - how is the shifting suppose to feel ?
- Power Steering fluid
- Red Line - water wetter super coolant
- How many people have brought.....
- brake fluid and bleeding
- How often do Mobil 1 systheic ATF need to be flushed?
- Gear Oil
- Outbid by .50cents on a 15208-60U00...argh
- is that true about Amsoil?
- How do I do my own ATF flush?
- Prestone Extended Life Antifreeze, BS to water pump damage
- Cheapest place to get Mobil systheic ATF?
- Synthetic vs Synthetic blend
- Any Redline product for automatic transmission (AT-90...????)
- Dexron ATF fluid any good?
- Quick Drain oil drain system- has anyone used them?
- ATF in Crankcase.........
- Syn ATF runs hotter
- is it possible to go over 3,000mi oil change interval with synthetic + oem filter?
- Bleeding brakes
- Amisol tranny fluid ?
- Auto RX for motor, Any good? Engine seals??
- Heading down to the local auto store. WHICH fluids are woth the investment?
- Fuel Injector Cleaners
- Synthetic ATF?
- So is Amsoil Series 2000 75W-90 gear oil the correct oil for the tranny?
- Synthetic Oil, / Oil Filter.. (Confused :-))
- Expressway Lube Centers "Kleen-rite" engine oil treatment
- Performance Engine additives
- Change MT Fluid Myself or Go to Jiffy Lube?
- opinions on RT-90 transmission fluid
- Is it safe to go from 10W30 to 5w30 mobil synthetic
- The EnviroLution Engine Life-Guard System
- Concerns about switching to Synthetic?
- TRanny Oil
- transmission fluid question
- Fram X2 Oil Filter any good...........
- What kind of antifreeze?
- Leaking Clutch Fluid
- Transmission Oil
- What kind of manual tranny fluid should i get
- Hard Water in coolant
- oil change interval
- Duralube?
- Redline MT-90 is the greatest.
- yota vs nissan oil filter
- ? about radiator flush
- question about oem oil filters
- Transmission fluid exchange question
- 2002 - 2003 PCV Valve
- Oil change needed or not?
- Royal Purple Motor Oil
- greasing ?
- oil filter question
- Stupid question, but not sure
- Low oil level
- anyone use kendal oil?
- synthetic oil + high miles
- Am I using the right power steering fluid?
- How many miles can I get from an M-110
- benefits of oil change
- Castrol Syntec..ask the expert gobbledy gook
- OK, so how often do
- *HELP* Technicians or anybody, car shutting down!
- Does Royal Purple oil really increase performance?
- I am going to fail my next Emission Test - HELP!
- Im goin for my first oil change
- Sea Foam
- ATF Fluid + Transmission Noise
- How much $$ do you spend on changing your own oil/filter ?
- Coolant / AntiFreeze for my Maxima ?
- Brake Fluid Dot4/5 Synthetic - Not Synthetic
- Castrol 0W30 (green made in Germany)
- whats some good non-synthetic tranny fluid
- which amsoil motor oils for our cars?
- Quick question about going back and forth with Amsoil and Mobil 1
- Its GREEN!! (Amsoil Gear Lube replacement)
- Redline MT fluid
- what kind of oil do i use?
- RedLine Oil
- Is it a good idea to change my gear oil?
- Redline MT90 or Redline MTL?
- Matrix lubricants/Engine Oil, where can I find some?
- where to discard coolant?
- Are you running 10W30 or 5W30?
- Z Max?!?!?!
- My '99 needs an oil change. What do you recommend for 82,250 mile car?
- TSB re: ATF Syn. Flush
- How much oil comes out of your car?
- Winter Oil Change
- better gas mileage/increased horsepower products?
