- Mobil 1 Filters
- Switching between syn. oil & regular oil
- 1st OIL CHANGE Complete report!
- did I syn too soon?
- Oil Type Question
- Gear oil question.
- People who are sick of hearing about seafoam, and all its BS, step inside
- Using Seafoam on an Auto-Rx treatment
- what do u think about redline power steergin fluid
- Marvel Mystery Oil (gas additive) make your engine knock?1
- Mobil 1 users, come on in!
- 3,500 miles Oil Change.
- engine oil flush liquid
- finally switched to amsoil ATF.
- Seafoam Transmission Lube
- draining antifreeze procedure question
- restore
- Having transmission flushed tomarow...
- where to buy chevron techron for good price
- Fuel system and tranny flush..
- Found Royal Pruple for $5/ quart
- Higher Mileage Oils? Worth it or Not?
- Lucas Additives?
- Wix oil filter any good?
- Where to buy NIssan Trans Fluid
- TX7 anyone know anything about it?
- another seafoam question???
- What kind of oil do you use?
- OEM Oil Filter Question (Part # 15208-9E000)
- Best Fuel Injector Cleaner????
- Oil Filter part number??
- what kind of manual transmission oil are we suppose to use
- gettin new clutch put in....what type of tranny oil do i need?
- Amsoil Tranny Fluid
- what oil should i be using!
- Rislone Engine Treatment
- When do you pour in BG 44k?
- Synthetic or Dino?
- Ruff Starting
- trying to find redline mtf....
- Best oil?
- should I switch to a high mileage oil
- Where to get Seafoam?
- PEPBOYS MOBIL 1 Synthetic Motoroil - $2.33 a quart
- mixing oil
- 30K miles on Redline D4 ATF, should I stick with Redline? add Lubeguard?
- Some bad Gas?
- quick question about oil stop leaks....
- Does using synthetic tranny fluid void your warranty?
- power steering fluid
- coolant flush question
- Synthetic tranny fluid, any difference?
- After Switching to Synthetic Problems.....Help!
- Are fuel injector cleaners safe?
- Carquest has Seafoam in Canada!!
- changed oil/filter first time, weird noise?
- RED vs Green
- Changing To Mobile 1 ATF
- The Real Verdict on AMS Oil
- Mobil 1 SS 0W/30?
- BG machines
- Specifically why shouldn't synthetic oil be put in 100K+ mile engines 4 the 1st time?
- Just started Auto-Rx....
- Would an oil filter for a '96 max fit a 2002?
- A Little Seaform works
- Any sales on Mobil 1 now??
- what the hell?
- Who wants to see what seafoam does(Video)
- Seafoam not smoking; engine not smooth
- Pennzoil contains Paraffin and hence not to be used ?!?
- Synthetic Fluid in the 6 speed manual
- Castrol GTX StartUp?
- What local stores sell Redline MT-90?
- Seafoam Alternative
- When to change MT fluid?
- Amsoil Series 2000 Synthetic Gear Lube
- Any side effects of having too much ATF?
- Changed oil after 89k, but problems arise
- Chevron Techtron
- People that switched to synthetic, did u notice less MPG?
- Hydraulic Clutch is out - help!
- Water wetter - where does it go?
- ?very confused? A/T filter/screen?
- royal purple
- The 3 different tranny fluids
- Clutch Servce
- Shifts feel notchy durning day's first drive.
- What do u guys recomend for transmission oil?
- Urgent> Need help on Trans Oil Location!
- "Avoid expensive premium gas..."
- For people that switch to synthetic motor oil, what drain interval do u guys use?
- High Ambient Temp ATF
- How "extended" are your drain intervals?.....
- Amsoil synthetic oil burn?????
- Is it better to use synthetic engine oil.
- Dont Look Now!!!
- Regarding Automatic Transmission Flush
- Checking ATF level...(long)
- Just cleaned intake manifold +++
- Dexron 3 instead Dexron 2 ?
- "Nissan Long Life" vs "Nissan Genuine Antifreeze"
- Fuel Injector O-ring Lubricant
- Nissan A/T fluid
- oil change...what to use...?
- Mobil oil filter seemed small
- changing 5 speed tranny fluid?
- Bad news to BG 44K fans...
- The 87 vs 93 debate!
- what's better N why? Mobile 1 every 6,000mi, or regular oil every 3-4000mi
- Where to fill/pour ATF? Couldn't find answer in the stickies...
- Which brand of gas?
- Automatic Fluid Type?
- Is Auto-rx worth it?
- Where to find BGK44??
- Fumoto Valve
- transmission fluid
- Mobil 1 synthetic ATF
- Redline Atf
- Burning oil?
- Penzoil 10W-30 and BOSCH filter
- when getting a coolant change.....
- can i run synthetic???
- Mm Auto Repairs
- couple questions about fuel filter change...
- Startup problems and 10w-30
- is there a how to clean our EGR's???
- Coolant change...
- At the risk od sounding dumb: what/where's the vacuum hose?
- SRY..again seafoam...
- Fuel Injection Cleaners
- full service on my brake system... what fluid to buy??
- Do I need a washer for the ATF drain plug?
- Oil/Additive Questions
- A whole bunch of oil/addtive questions...
- Amsoil Series 2000 Synthetic 75W-90 Gear Lube???
- Oil change with Castol GTX New start!!!
- Gear oil break-in
- Transmission gone bad?
- GL4 in 3rd gen 5 speed?
- High miles and synthetic
- Kendall Full Synthetic oil
- Bleeding Clutch line....5th gen...
- Using synthetic oils...
- Why is the antifreeze drian plug made out of plastic?
- OK to use Water Wetter in cold environment?
- Oversized filter debate....
- Motor Oil Question
- Clutch fluid reservoir
- When is it time to change your anti freeze?
- Brake Fluid
- What's a good brake fluid?
- Motor oil. what type do I use?
- Help Wrong oil? 0w-20
- ve30de transmission flush write-up
- Oil/Lub job
- Yes,another seafoam thread but I got some questions
- Anyone uses seafoam to clean engine?
- Synthetic motor oil........Amsoil vs Mobil1
- Does that seafoam really do anything?
- Oil change
- ATF questions
- Gear Oil Change
- How do i check my 5sp Tranny Fluid?
- Where can i get GL-4 ?
- Lucus Oil Products
- Transmission fluid hose
- Changing to synthetic oil. question
- Changing Oil...(Dumb Question)
- mesh screen for oil filter
- ATF in the 6 speed
- Synchromesh Tranny Fluids?
- tranny fluild prices
- VTC protection
- 92' Nissan 5spd Tranny Oil ??
- GL-5 only = bad. Surely a GL-4/GL-5 is not.
- techron @ 35k miles?
- Amsoil vs. Redline ATF
- Radiator power flush
- Transmission overfilled
- seafoam
- Replacement brake fluid questions
- Those going for reasonably long intervals - do you change the oil filter half way?
- silver color motor oil!!!!
- At Transmission Help!!!
- Is it true if you replace your tranny fluid...
- How much oil????
- 5w20
- oil filter
- Seafoam and GM Top-End Cleaner
- Anyone use Sea Foam Trans Tune?
- How soon should I use Seafoam?
- Changing Oil using a Topsider suctioning device.
- gear oil
- Pennzoil Synchromesh Gear Oil
- Fuel system cleaner
- 10k miles for synthetic???
- Any reason MT90 wouldn't be compatible with factory fill conventional gear oil?
- sea foam and check engine light???
- Sea Foam - Purchasing online
- Changed MT90 after 19,250 miles.
- Which Amsoil 5w-30 you prefer? regular 5w or 5w-30 XL-7500
- Oil Survey
- Automatic Transmission issues and fluid capacity
- atf fluid?
- How much fluid?
- Putting Mobil 1 oil in for first time.
- Power Steering fluid
- Water Wetter ??
- MT gear oil capacity
- Which automatic transaxle fluid for my 01 Maxima?
- Coolant Flush Question
- Techron
- can someone help me
- Which non synthetic ATF?
- I got some unopened AMSOIL tranny fluid from a friend that is ~2yrs old...
- Amsoil oil filter problem?
- Redline mt-90 purchase at local store?
- oil for the car
- 8k interval with synthetic or 5k with conventional? :)
- Lucas Products
- Is it even possible to buy a cheap GL4 gear oil?
- Auto Trany Fluid ?
- Oil Filter Problem!! Help!!!
- What steps to take when switching to systheic oil?
- AC Recharge
- what is absolutely the best oil stop leak?
- HI which oil for my max...?
- Engine ?
- clutch fluid
- All BG products.....?
- redline water wetter...work?
- Just changed my oil, 8K miles
- replacing coolant w/ completely NEW coolant
- is BG MOA okay to add to oil...
- Amsoil 80-90 GL-4 Gear Lube?
- GL4 vs GL% GEAR OIL
- So *that's* what 3rd gear is supposed to feel like?!
- What is the absolute best brand of Gasoline?
- AT and radiator flush, DYI or service pro?
- which oil filter for synthetic?
- What about the engine block drain plug?
- Sea Foam
- Which Oil Type?
- Engine oil cleaner??
- Oil Weight?
- Guys that are runnin Redline Water Wetter
- Oil capacity for 02 Max?
- Previous owner used 20w50...Which weight now?
- Engine Restorer & Lubricant...???
