- Engine pinging around 2000 RPMs
- Who here has replaced the factory NAV / Bose with Aftermarket? Lets see some pics
- I30 owner needs help about exhaust and rims
- Quick Question About Clearing Headlights
- i35 Steering wheel control
- Injen intake placement
- Plastidipped My Grill
- Maxima MT mounts on i30?
- Service engine light blinking I30T
- How does this make you feel?
- Let's see here who has...
- Where Can I buy Plastic Rivet Fastener for my trunk - Infininiti i30 99
- cant seem to figure it out
- 99 Infiniti I30 axles
- Advice with Tire Size??
- Opinions on wheel?
- Who has replaced the radiator?
- Rear Turn Signal Bulbs Driving Me Crazy (What Kind Is It?)
- low wiper fluid light...
- Will 40 Offset be OK?
- Anyone parting a i30?
- Just bought an 02 I35 with Nav, need help on Aftermarket radio
- LED Taillight Install?
- Lets see those i30/i35's!
- A few questions for my 2002 I35
- 96 I30 won't start but cranks all day.
- Infiniti Wantabe?
- Power Valve Assembly repair VQ35DE
- 01 i30 and an i35 grille?
- Car hard starting questions???
- TCS switch/light
- 2000 Inifiniti i30t AC Relay
- i30 HID swap
- I35 Suspension Setup
- Kindly assist!!
- "ghost" revving?
- questions about both i30s
- looking for a cold air intake...
- 2003 I30 Stalling, Not Starting, Rough Idle, Etc.
- AC and Heater
- Installed Progress Technology RSB on '01 I30
- Different A32 I30 grilles, blacked out and retrofitted headlights and fogs, and more!
- suggested HID kit for '01 i30?
- Give me your opinions...
- polyurethane motor mounts
- Ghetto Short Ram Intake
- HID light sometimes not working
- eibach pro kit
- Binding Ignition Lock
- The inside of my ride
- help me solve my headlight problem
- URGENT: 1999 to 1997 I30 Engine Swap ECU
- I30 Guru's
- tire question
- headlight problem
- 2001 infiniti i30t amp installation
- In Japan!!!
- Ebay headlights?
- ABS or Carbon Creations CF hood?
- Battery constantly dying
- Pic Request: All-Weather Mats
- Help, I need a little assistance. AGAIN
- i35 6speed swap??
- Time to toss my spare tire cover ^^
- 2000 I30 Stock Exhaust Diameter?
- 99 i30 / 99Maxima Contol Arm
- Transmission TSB - Is this the fix?
- What Do I Need to Fix P0158?
- I35 parts
- HELP: *Axle Nut Keeps Coming Loose*
- The bleeding continues..
- Hard Starting...
- How much is she worth?
- 2000 I30 Holding 1st Gear on WOT
- 02 I35 ses light dose not work
- problem with Progress rear sway bar width
- Oh Geese, This is not my month AT ALL please help..
- shifter knob for 4th gen max or 1st gen i30 5 speed
- 4th gen steelies on 1st gen i30
- Car vibrates and becomes louder
- '04 Center Console fit an '01??
- Question about a 2000 I30t
- Fluctuating Oil Temperature
- Spare Keys
- NO START! URGENT HELP!
- Laser Shifter Install
- Close call
- Autech Kitted A32
- Need advice
- Where to buy I35 performance mods?
- jingling noise from under car
- 00-01 I30 DRIVERS SIDE HEADLIGHT
- Bad struts?
- Transmission issue? Sensor?
- Can someone guide me in the right direction.
- What do you make of these Ebay Cefiro headlights?
- Proud new I30 owner
- 6th Gen Maxima Rims on a I30
- GI: A32 Calendar
- Stance Nation I30
- SWEET RIDE! :)
- Mirror LED pics and video
- Navigation mod (need advice)
- In need of a front passenger seat..99 Infiniti I30t
- Installed AE Foglights A33 01 I30
- adjusting shift cable
- 98-99 Headlights in 96 I30
- No one can figure it out! Suspension issues. Please advise!
- Best corner light bulb
- SYCEFIRO!
- Looking for parts
- Planning next upgrade (sub)
- Please help quick!
- Transmission pan gasket
- Sunshade stuck in the up position
- AUTO power window not working on driver's side
- Transmission problem?
- Corner lights
- 97 i30 headlights
- 97 i30 tails for sale
- Cefiro owners..
- HID fog lights installation (sticky?)
- Question on drop springs
- Key fob window roll UP feature ???
- Reverse lights LED
- What is this radio connection?
- Thinking about my Gpas I35
- Teaser - BCR Coilovers and Ionic Dynamics Install
- What do I need to buy in order to give my i30 a tune up @ 175,000 miles
- Maxima Mirrors on an I30?
- Red Headed Step Child to the I30
- Hard Question (electrical)
- 2000 i30, SLIP and TCS lights, gas smell, cant drive pass 20 MPH
- SES p2135
- Battery Buffer
- front end project 1998 i30
- Mirror LED Mods?
- My I30 build
- Rear window trim
- What are the symptoms of a key that is not programmed to a car
- HID fogs
- Brake Problems
- A/C Cooling Intermittently
- I30 Fog Lights: Terrible Light Output
- front end pics...painted everything
- Gauging Interest for VIP Front Tables...A33
- quick leather repair
- Sound dampening
- 2000RPM whine has me stumped
- Feniex Flashers on I35 (Short Review and Video)
- Tokico HP + Eibach Pro Kit Review
- Best LED wedge bulbs?
- Anyone got aftermarket exhaust?
- Strange "springing" noise from transmission
- Oil leak
- Painted Engine Cover (Color Matched)
- I35 2003 question
- i30 shake on highway
- Quick Question!
- Brake Pads
- gen 1 illumination issue
- So i35 suck overall?
- Rear Ended on Saturday :(
- Need advice with sub
- Front Lip for I35
- Parking light issue
- Quick quick?
- SoCal Maxima is up and running
- 5th gen window vent shade
- How to remove the dash trim pieces...
- Bulb size interior spot/directional light
- Knock sensor replacement on i35
- Cefiro Headlights on I35
- Carpeted Floor Mats
- WTB: I30t BBS Centercaps
- Is looking for a Front Cover(bra)for my 2000 I30
- Type of oil to be used
- Tires and wheels....4 sale
- WTB I35 Wheels
- 02 I35 WONT CRANK :o(
- Noise in engine
- Interested in mod, need advice
- Faint burning plastic smell?
- Possible GD on CF I30 hoods.
- 2000 Infiniti I30 with rough idle . . stalling . .so confused.
- i30 wont start
- Yellow Foglight Capsules
- Really bad gas comsuption
- 2002-2003 I35 ECU compatible?
- 2002-2003 I35 compatible?
- I35 HID Fog Conversion
- H.I.D. Bulb Replacement
- Ignition Coils & Fuel System Issues
- Infiniti i35 / Nissan Maxima Vapor Canister Purge Valve Replacement
- Do the 96 I30 fog lights fit on 99 I30?
- Does 96-99 maxima fog lights fit on 99 infiniti I30?
- Fog Light Mod Help?
- I35 Dash/Cluster/Climate/Clock Lighting Help?
- I35 DRL Bulb Size?
- I35 Lowbeam bulb replacement help?
- Leather Kits for the I30 01-04
- Difficult to change I35 headlight ballast?
- Are these bulbs legal?
- I35 Foglight With Highbeams???
- Group Buy Discussion for 1st gen I30 Body Kit
- Will these headlights work effectively?
- Fog light and High Beam Headlight Help?
- Automatic Dome Light Problem !
- Headlight Help!
- Cattman Cold Air Intake
- Whine/Rumble noise at specific RPMs
- quick question glass pack
- I35 Heater/Blower Grinding
- Are the interior lights of an 02 I35 compatable with those of an 03 Maxima?
- hid seating in cefiro housing
- A32 I30 with R34's, not Cefiro's?
- I35 Straight Pipes Help?
- Random Misfires, Cam Pos Sensor, and Bad Ignition Coil - Please Help!
- Anyone down to help?
- Anyone know if these headlights will fit?
- O2 Sensor, Direct Fit-Color Coded or Not?
- test pipe vs cat..down pipe
- Help! P0650 Code.
- P0138 Code-ECM reprogram?
- Automatic Climate Control: How to "force" the AC on?
- Anyone know where to buy a splash gaurd?
- About to join the I35 club
- Transmission trouble
- Whirring noise before startup
- HOW-TO: Fixing the 98-99 center tail light bulge
- a32 on Coils: how low will it go?
- Anyone know whose i30T this is?
- corner lights (96 i30)
- Maxima Forums listed as Attack Site by Google?
- 18" G35's, What size tire? 2k I30
- What was your first mod?
- LED Strip Lights (Pics)
- 95-99 i30 lowering kit and stock suspension
- A32 cefiro trunk garnish...
- Simple gauge cluster question
- Homelink not working with LiftMaster Garage Door
- Q45 seats in an I35
- Rust under radiatior?
- Power lock question
- Anyone used these headlights?
- 4th gen exhaust components on 99 i30?
- Electronic Suspension?
- Pics of my little install and Clay Bar
- a32 i30 and cefiro
