- o2 sensor - warranty coverage
- Firing Order for spark plugs
- need help on headlight replacement
- i35 foglight connector/harness
- maybe you seen this video before
- Mavis Wagner brake pads, any good?
- Staggered Rims
- A little fun for next weekend :)
- fog lamps, how to....
- Rim considerations
- 1998 I30t, aftermarket vendor needed for center tail light reflector
- Drivers' Seat Quit Moving
- cefiro parts for my i30
- Oil Filter?
- need to know asap difference between ecu
- Rear wheel spacers for 4th gen I30 + wheel q's
- Differences between I30/I35 and 5th gen GLE
- Heavier wheels need more power.....
- what color should i choose?
- center caps get pushed off
- i30/35 owners
- I searched, I promise. HEADERS
- Wow! These new headlights look crazy nice but....
- ABS light
- New Look (Front & Back)
- Redline Mt90 fluid
- A32 JDM Cefiro Dual Piston Caliper w/ JDM Nissan Brake Pads
- Any brake differences between I30 and I35?
- VIP trunk lip wings available for A33
- My weekend
- Coilovers, Ionic body kit, B-Pipe, or TV?
- cigarette burn hole on felt by window....help
- 2001 i30 keyless remote unit question....
- Just purchased 98 with 50k miles nice car!!!
- Paint code for 2002 I35 Sport champagne wheel
- My respect for infiniti is over!
- Do 18" G35 wheels fit 99 I30???
- 1999 I30 Aftermarket NAVI question
- Carputer Time!
- Alternator Upgrade?
- Friend needs some help
- Looking for brake pads
- Cell phone switch?
- 2nd time to the track
- What makes an I35 "prewired" for XM?
- completed pix.
- 1999 Q45 - Good Car?
- what's a good intake for an i35
- SES light - 02 i35
- 98 I30 Tail Light Troubles...
- Murano Rims
- Would this be worthwhile?
- Ionic Dynamics I35 Aero Kit is now available!!
- Help!!!!!
- Suspension problems . . . .
- How To Remove The Steering Wheel The Correct Way?
- Is it Worth It.....
- Steering wheel audio buttons issue
- service engine soon Light
- replace oem bose amp?
- ECU Codes 39 and 75
- Fuel Tank Size
- 2k i30 (replica of 5th gen maxima's)
- TSX Retro In Cefiros
- Q45 Tb?
- O2S Not Ready (No Codes Either)
- what's wrong with my brakes???
- Hyundai i30? WTH?
- How to I aim my non-HID headlights?
- 2000 I30 Tranny????
- A33 double din?
- Bad coils from accident???
- Leaks after switch to synthetic?
- Mpg?
- It's spring, time to change you in-cabin filter!
- Sneak Peek..
- Buzzing noise after car sits for a few days
- Was browsing around a Thailand Cefiro club....
- bodykits?
- ANOTHER crunked teardown of a VQ30DE (170k)
- Getting painted!!!!!!
- looking for a replacement battery I30 2001
- Rim/tire fit on my 98 i30?
- HELP Removal of Touring Rear Spoiler
- Write-up : Rear rotor/brake pad replacements 2001 I30 A33
- Tough choice
- Infiniti dealers in the DC area?
- Time for a transmission fluid change?
- any 4th gens with body kits /lip kits?
- ECU Interchangeability
- Idles Too High Sometimes
- Backed up into a pole today
- code p2236
- I35 eyelids
- Jack Placement and Suspenion Write up
- M45
- First ever 1996 Infiniti I35?
- Sagging door
- Uh, Oh...Peeling I30 Rims
- i35 having rust problems?
- new shoes for the I
- Both of my side view mirrors broke off....
- Cracked armrest on 00' I30
- Suspension rattling . . . . .
- Sylvania Silverstar Ultra vs. Philips Nightguide vs. GE Nighthawk
- Tires losing air after car sits?
- Discovered a Leak
- Transmission Fluid
- i30 steering wheel 96 vs 2000 interchangable?
- Lip spoiler?
- Another HID Projector retrofit (TSX projectors into eBay A33 lights)
- HID Kit Problem Help PLEASE!
- Blacking out a grille
- Climate control removal?
- does this make me the first?
- I35 grille
- axle shop confusion
- i30 comparisons
- Rearview mirror with compass retrofit question!
- HID retrofit finally done *pics
- Q45 Headlights Will The Fit?
- Non-HID - Converting to High Watt Bulbs
- Cleaning your I30 engine
- Upgrading from the Spec Discussion (Split from the A33 3.5 HLSD Swap Thread)
- Air Bag Lite Flashing ! ! ! ! ! ! ! ! !
- Has anyone done an A33 6MT HLSD swap? (I am the mod. If repost- sorry)
- Installing I35 grill on I30
- Semi-Detailing Pics
- rear end q's?
- Help me mod my A33 I30
- double pop-out draw modification
- Rear Turn Signal Bulbs?
- Trunk not opening
- feedback on wheels
- 5 Spd. Swap DONE!!!
- dOES ANYONE KNOW WHERE I CAN BUY CHROME DOOR PILLARS FOR AN 03 INFINITI I35
- Shaking @ high speeds
- Replacing Stock Velour Seats with Leather Seats
- I35 stock HID Kelvin rating??
- Changing Navigation on '01 I30
- a/c & heat fan noise
- Infiniti I30 Armrest has cracked *pics*
- 5zigen wheels, are they any good?
- Coils and Knock Sensor???
- Stilloking for a32 cefiro parts
- Car keeps turning off while driving : HELP
- Looking for a32 cefiro parts
- SES light code #P0420 on 01 I30
- Auto headlights....anyway to stop them from working???
- 2000 aftermarket dash kit. still available?
- HID headlight problem
- Burned Light Sockets
- If you want A33 side skirts come in for cheaper than retail
- I35 led tail
- Interesting lighting tidbits (for those who care)
- Has anyone taken apart an A33 fog light?
- Wheel spacers
- Need some help identifying this
- what i really want.
- Vibration on acceleration
- Problem with my '96 A32
- wheel replacement - technical question
- another body kit
- I35 ?
- I'm Back
- A33 alternator installation question
- I've Never Seen This Before!
- I35 Rear Sway-Bar Installed
- one mint i30
- is this true?
- Soundgate ALNS1V2 question.
- Just found something thought i'd share
- Whats the rec. mileage for a water pump
- F/s gas door switch
- Door lights Not on?????
- Installed Yellow Foglight Capsules...and LED license plate light pics
- Infinti steering wheel??
- 96 I30 with 18" 2004 SE wheels
- Slip/abs/TCS off?
- Is this the correct fog bulb?
- Condensation in Tails
- I30 leather seats
- Exhaust diagram/layout?
- 1996 I30 with rough idle at cold start but smooth when warmed up?????
- 2k1 max and I30 ECM swapable?
- Snow Day Pics
- I'm part of the I30 family!
- How many miles do you plan on getting from your I30/35?
- SES galore
- Alternative to in-dash NAV
- re-attach rear view mirror?
- Brake Pad/Rotor Install Problems
- Low Mileage on 2000 i30t
- How do you remove the power antenna mast?
- dont yell
- Whine sound, car shuts off, and SES light??
- 01 i30t $12k for me sister
- 2000 I30 Gauge/Instrument/Speedometer/Cluster LED
- Question about Auto's
- Anybody know of any A33 aftermarket hoods?
- Pics of the front and rear dropped finally...
- Would you trade I30 for 3.2 TL?
- Throttle body cleaning
- 2000 I30t Died Again During Cold Start
- Finally got my I 30 lowered. and new lights *pics*
- Aftermarket or OEM Fog Light
- OEM Satellite for 2002 I35? Aftermarket NAV?
- BBK Suggestion
- Factory Navigation CD
- I30/I35 compass mirror ?
- Rough drive after coil / plugs replacement
- What size bulb
- Need help with chrome gauge rings.
- plugs/wires
- Problem With Y-pipe??
- I35... factory spare size?
- Battery Recomendation
- 1999 vs 2001 suspension differences
- 1999 I30..my backdoor won't unlock with remote, help...
- MAF Part#
- Service Engine Soon Light
- Belts
- Chrome Trim
- A sad example.
- ks, o2, and coil replacement question and advice with problems
- Yellow Fogs
- n3985's Lighting Evolution Worklog Begins....
- Infiniti i35 side skirts
- Help w/buzzing pls.
- Picture Request
- Brake light will not turn off?
- little quote here please!
- Anybody want to sell anything?
- Almost wrecked my car then.... CRASH
- Garage Door
- Think I found out why my gas mileage sux.
- Cefiro Wagon!!
- WTB 00-03 clear side markers.
- problem with gauges
- HID in 2001 I30
- 02 I35: New rattle at 1700 rpms until tranny shifts
- Any advice for coils?
- Woops, how do I buff THIS out?
- Sweet A33 Body Kit
- Does anyone know what this means?
- 2003 I35 parting out
- 00-01 carbod fiber hood?
- Finally found the best city light bulb!
- Installing I35 Overhead Console
- Newest Pics of said Debadge and more!!
