- Waste Spark and Nitrous backfire
- NEW NX Nitrous Solenoids
- Link to J&S info...
- Nitrous Wiring Diagram
- NX single stage limit?
- Can the cvt's handle a shot of nitrous?
- Sprayed for the first time, got some questions
- Question about N.O.S
- different kind of bottle heater pad
- looking for a bottle warmer
- Spark plug questions...
- electronic WOT switch for DR mod?
- how much can my car take?
- Frost on nozzle
- 50 shot and 75 shot jets???
- nwp plate yes or no?
- few questions
- ZEX rated at crank?
- Any 5th Gen's spraying?
- any mods needed pre 75 wet shot??
- Nano Nitrous - anyone installed this?
- Progressive Nitrous Controller Gen-2
- Benefits of exhaust cut-out?
- Anything needed with a 35 shot???
- 150-shot and pump gas :ugh:
- Entering the realm of the nitrous crew, but I have a question first
- How will the stock clutch handle the nitrous?
- 2 quick questions
- Got teh Sauce...(PICS)
- Question on nitrous feed line.
- Step 2
- Wideband 02, Really needed?
- Nitrous VS o2 codes?
- Spark plug part number for 04 3.5
- Upgrading fuel pump on returnless system
- can finally retard my timing, just making sure im doing it the right amount
- Running E85 with spray?
- ? Use nitrous to override the factory rev limiter ?
- Looking to shorten my nitrous feed line
- 75 shot and 2* advance on 3.5... anybody else?
- 125/150 shot. Have the ideas, just want some opinions on specifics. (5.5 gen)
- For you nitrous boys who wanna keep it stealth
- 5.5Gen and Nitrous
- Nitrous questions
- Plan on running big shot----few questions
- This car doesn't have nitrous.............
- Nitrous Qs for my 5.5
- Looking for a good Nitrous Kit/Set-up.
- Spray off the line
- nitrous newbie help !!! well not too much of a newbie
- my nitrous setup
- NX Incognito?
- What size shot should i run
- Spraying thru Every gear.
- Help- get me in the 13's.....
- Testing solenoids?/other concerns
- MID 12'S ON 150 wet shot?
- installing a nitrous system with an upgraded ECU...
- Pulsing n2o
- bad day at the track
- Swapped Dynotune Kit, Problems! Help!
- Question about nitrous kit
- Possible 11s This Season?
- Oxy-Hydrogen Generator for a Car
- well i almost blew it up
- Need some help
- Few n20 q's
- Nitrous Wet Kit
- opinions
- Are The Zex Wet Kit Jets Making The Advertised WHP!
- dynotune EFI kit
- 3.5L before and after 1/4...
- t6378tp: I'm callin' joo out!!
- NX system on a pretty unmodded engine
- For those without a bottle heater yet...
- ZEX dry nitrous for sell
- Need some quick advice...
- jwt ecu+nitrous vs stock ecu+nitrous
- Best complete Newbie kit?
- Solenoid stuck open!!!
- 3.5L and Nitrous
- Just installed purge and heater *PICS*
- Bottle heater
- Nitrous with JWT ECU
- Wizard of Nos fs.
- Ordered some goodies!
- Nos jet sizes.
- MEVI = about what in the 1/4
- I did the inevitable! The VE Auto is no longer NA! (Pics inside)
- non max but ran 12's
- is this true? retard timing on 3.5 for 75 shot?
- Spark Plugs?
- Preignition - not good for valves
- 75 shot or more?
- How do I wire in a relay for my window switch?
- most popular nitrious kit for 5.5th gen(3.5)
- Can I Tap The Fuel Line From....?
- What track times does your max run with nitrous?
- dry fogger nozzle forsale
- wth had to redo now heater dosnt seem to work?
- Q's for those with more than a 100shot
- Good Exaust Piping Size for Nitrous
- what it cost me to put my n20 kit together
- making headway on installing the nitrous
- for sale zex nitrous management unit
- wiring diagram
- Anyone with Zex and 3.5 PLease Step In
- Which wire to hook up to TPS for Zex
- custom switch panel (for sale)
- fjo mini controller
- Nozzle fitting adapter
- purge
- In your opinions how necessary are these?
- Nitrous Fuel Line
- clean ur jets
- Scangauge II is THE BEST!!!!!!
- NHRA inspection
- Can a direct port do this?
- Hitman EFI system
- Nitrous issue.
- DynoTune Wet kits, who has em?
- I need help mounting a micro switch on a 5th gen
- Converting a Nitrous Kit to Direct Port?
- what would be the easiest way to add fuel pressure gauge?
- nitrous bottle
- Nitrous + ECU
- Dual vs Progressive
- jwt set
- Please help fuel problems
- MSD window switch (8956) wiring question
- What wire
- Raising shot, Gauges, Etc.
- testing nitrous bottle 5 year manufacture date
- MSD Digital Switch control 00VI and Nitrous
- What octane gas are you nitrous guys running?
- Ummm help!
- nitrous questions -- non max :)
- Nitrous noob question:
- ZEX Triple FireT Spark Plugs specifically for nitrous...thoughts?
- How good is the fuel fittings/lines in NX Import Kit
- Nitrous legal issues
- I read the stickies but....
- Anyone try this before?
- Progressive conrollers
- where to buy larger nx jets
- Rich Highschool kids are stupid F*CKS
- drop resistor
- Using stering wheel buttons
- soleniods
- Nitrous installed!
- Murphy's Law Can Suck It!!!
- Did not hit 13's :<
- Colder Plugs.
- Testing Waters.. Zex Nitrous Kit
- Need help with window switch.
- Nitrous window switches.
- Emanage Ultimate and timing advance...
- E-Manage Ultimate: Worth it for NA + Nitrous
- Nitrous help.
- Crankshaft position sensor??
- some new toys for my nitrous kit
- Water-Methanol Injection
- looking for 125 nx jets
- which ngk plugs with zex 65 dry
- how to read plugs after nitrous
- which intake??
- safcII w/ nitrous??
- question about zex install
- Installed my heater and pressure gauge
- New to Nitrous
- zex dry retard timing
- I'm Going To Install Larger Nitrous Plumbing..
- Consensus on best plugs
- advanced timing with zex
- few questions about zex dry
- Nozzle input ok??
- Selling my nitrous Purge for cheap.
- Anyone need a MSD window switch
- tps wire??
- A couple of questions..
- Cutout and Nitrous
- Bottle warmers
- building my setup, anything im missing?
- What's needed to do a nos shot higher than 55?
- FS:I still have NX fuel press, N2O press mech gauges
- New To No2
- Going on the bottle, a few questions.
- Anybody know if this is true?
- Spraying before MAF?
- Zex dry kit on a 97 max
- My new Nos Setup
- set up question
- Any God Deals We Should Know About?
- Can I Use a Nisan Kit on Another Make?
- any pics of install on a 5.5 gen?
- Anyone using an ebay AFPR?
- Nitrous Kit
- check engine light flickered
- Anyone tried this?
- Does anyone use 2step colder for daily drive?
- purge installed
- Anyone have a purge solonoid or kit i can buy?
- Mechanical Nitrous Pressure Gauge, Risky?
- Advice about 75 on 06...
- Shorted out my heater.
- Window Switch?
- nitrous kit
- What preignition-damaged spark plugs look like...
- Went to a 75shot today!!
- I need power!
- Update on my setup.
- This place is dead.
- Highly recomed for us nitrous orgers
- FS: NX nitrous/fuel pressure gauges
- maxima-mizing my new nitrous kit
- Correct spark plug gap question
- Anyone ever blow there motor?
- Do you weigh your bottle after having it filled? Buyer beware!
- NX Nitrous guage not working ?
- Nitrous refill $
- window switch
- Capacity of 5th gen pump?
- Is this IM for a 4th gen?
- nitrous & Jet performance
- 75 shot
- Gauges?
- Anyone here useing a stand alone system?
- Which Plugs to run?
- Well, I'm going to do it again.
- Which bottle warmer brand to go with?
- Largest Safetest Boost Amount for 3.0
- 5.5 gen ZEX installation (TPS question)
- zex dry kit and a window switch
- fuel pressure question
- fpr...set at what pressure
- idling weird after new plugs
- Purge show and new bottle blanket, i love it!
- fuel pressure regulator for 3.5
- Walbro 190 or 255?
- 75 wet shot was running perfect.. but now I am gettong detonation+fuel puddeling? wtf
- nitrous time i need opinions asap
- where to buy, direct port
- a v-afc question
- Most commonly asked questions about nitrous by NX
- Took the new kit for a spin
- New Season Nitrous checkup
- Fuel Pressure Safety Switch?
- jwt ecu's good or bad for wet kits???
- Fuel pump fuse
- Do I have everything I need?
