- Nitrous and SAFC
- mechanical nitrous gauge or not?
- should i spray?
- Guy's , Anyone can help me
- Walbro fuel pump installation
- Specific spark plug questions
- got my nx kit!!
- purge valve part number for nx wet kit
- 03 Maxima....75 or 100 shot?
- nitrous and the first time at the track
- Inexpensive nitrous fillups
- gauges
- ANY estimates on what I will do 1/4 mile with 50 shot???
- Where to buy Zex?
- JWT+ Nitrous?
- 125 shots rec
- Leaking lines or normal?
- Nos Refill Station In Nj/nyc
- Who has blown their engine? Adding it to a daily driver?
- where to buy NX 100 jets?
- In Cabin Nitrous Gauge Mount and Protective Cover
- Purging question
- anyone using NOS NOSzle direct port?
- Thinking about nitrous on my 2k4, questions.
- vg + bottle
- Dry ZEX Nos system and a maxima?
- Through what RPMs do YOU spray?
- tried the 100 shot, need help with fuel pressure
- Knocked .839 sec off my ET
- Looking to get ZEX
- How much do you pay for Nitrous.......
- What spark plugs to use?
- n.o.s.
- Where can I not use Thread Sealer?
- other jets ok to use with NX?
- Holley 05122NOS kit B-Day gift
- How Much Should I Expect to Pay...
- JWT NOS and ECU worth it?
- some nitrous ??'s
- Automatic Nitrous?
- shark nozzles
- N2O Bottle and Spare Tire Q.
- Zex Kit Install Instructions
- NOS brand jets
- attn Jim (pm doesnt work)
- Medical Grade nitrous oxide
- Where to find Walbro 255 High pressure fuel pump?
- N/X at Pepboys
- do I need a fuel pressure regulator?
- HELP! I think my kit has been put in wrong!
- Fuel Pressure PSIs
- EGT:When exactly do I run lean or rich?
- Fuel pressure isn't bumping up
- Plugs
- NITROUS first time not so good
- Q on Direct Port setups
- ZEX bottle heater
- Mounting Solenoid Qs and lots of pics
- Easiest place to get a switched source?
- NX kit installed Part Two
- Check out some of these questions!!!
- Quick! Let me know if this is a good price!
- NEEDED: Pics of Fuel T splice location
- Want to buy 30 shot jet/nozzle any one have one for sale?
- Nitrous..a few questions
- New way to launch with nitrous w/o slicks
- Question about my bottle and a splitter i have on it
- AUTO + Nitrous
- next size jet
- To my n2o MEVI users
- NOS vs. NX myth BUSTER
- How do you guys launch?
- What intakes Do you have and Where is your Nozzles mounted?
- Track Night Scare
- Poor VQ
- Best place to find NOS part?!
- recomended items to use w/ auto
- Discussion NOS dry to NOS/NX Wet kit
- NX nitrous kit installation, What else do i need?
- n2o for MEVI
- Walbro install for 5th gen, major problems
- Variable jetting for smaller shots
- Dry Kit Fuel Pressure question
- Question on prices....
- Just purchased a used NOS 5124 kit w/extras
- Confessions of a Nitrous Junkie
- JWT Nitrous upgrade???
- Fuel Pressure Gauge INSTALLED!!!!!!!!
- 60 shot ok on stock Fuel pump?
- Billet Aluminum Bottle Brackets
- People that are good at guessing JET sizes:
- 4th gen: MEVI and DPI set ups
- chip on end of bottle fitting, will it affect anything?
- how to read EGT gauge??
- Fuel Pressure Tees seem to have a slight leak
- Jetting Question
- Need A Pic
- Nitrous on streets?....
- How does the Nitrous Pressure Regulator work?
- Can you tune the FPSS without a FP guage?
- How do you read an EGT gauge?
- How did you run your lines?
- APEX'i SFC-II
- Can Nitrous Go Stale? or bad?
- NX kit and MSD RPM switch
- important question
- Auto tranny, fuel delivery question
- Dont Know Anything About Nos!!!
- general nitrous Q
- NX wet kit - I have a hook up
- I will probably visit this forum more often from now on since I just...
- Going to the track for first time this Sunday..probable e.t.'s? tips?
- Want to run nitrous on automatic...
- Variable Intake and Wet Kit Completed
- how much hp loss on stock ypipe?
- Recommended Gauges????
- what is the most miles on your "juced" engine?
- Nitrous, Tranny issues
- Nitrous with stock heat range plugs
- Fuel pump question??
- California Smog Laws?
- Electronic EGT, fuel and nitrous pressure gauges
- Pyrometer?
- Which Is Better Wet Or Dry?
- I want to buy glowy gauges!Where to buy?
- Possible Zex dry kit conversion to wet?
- Bottle Pressure in a wet kit?
- ZEX 55 Shot has nice little kick......
- Which is more important with the NX wet setup?
- Just finished my NX install.. picture and link..
- What do you guys think of this nitrous pressure gauge?
- How noticable is a 35 shot?
- Anyone using nitrous with a variable intake manifold yet?
- You know you're a Maxima owner on N2O when...
- spark plug info for 2k2 on NX
- Is this the NX kit I would need?
- Help!!! More window switch problems.
- 50 shot nos
- Yet another FPR problem
- Search isn't working? Anyways ... got the NX kit ...
- Biggest Shot
- Is there such thing as an accurate A/F gauge?
- nitrous on a stock flywheel
- Best Nitrous Setup For me?
- Does anyone have a SARD FPR Install Write-UP
- NOS, is it worth it?
- Is a bottle blanket worth the $30 bucks?
- Need help on adjustable FPR install
- Nitrous question....
- WOT Switch with a VI
- Nitrous people....Do you want a yearbook for all boosted Maximas?
- Spark Plugs and Nitrous Qs
- Solenoid Operation Question.
- for those with NX kit
- N.O.S. users please help me again.
- first 2002 with NX setup up and running ! =]
- Help Quick Please!! :(
- F/S: Zex nitrous kit,autometer guages,purge kit
- Has anyone heard about this bottle heater?
- Another NOS window switch question?
- New heater install question.
- How long does it take for a heater to heat up?
- Autometer FP Gauge Lag?
- need help in socal installing NX KIT
- How long does it take you guys to get your bottle filled?
- Basic Nitrous Question
- NOS remote bottle opener any good?
- Installing NX Opener on NOS Bottle, Help!!!
- Who here has the biggest bottle?!
- Questions for you direct port guys
- nitrous how big of a shot?
- Compression at 130 or so on each
- When everyone on this board says they wouldnt run over 60 shot...
- recommend a FPR
- People running Direct Port.....
- Nitrous Fuel Pressure Problems
- Nitrous is RUNNNNNNNING now
- Nitrous dissappeared??
- Is there a place to purchase cheap flare jets for the NOS kit?
- need some advice
- hells yea... nitrous finally pulles thru
- N20 thoughts
- Looking for nitrous setup advice
- Tips on painting the nitrous bottle??
- Installing Fuel Pressure Gauge
- I need advice on Fuel Pressure Gauge!
- Where's the best place to get NX Stuff?
- just picked up a NX sponsorship..
- most NOS users using wet or dry kits?
- Where to Get 1 In 6 Out Nitrous Distribution Blocks?
- Window Switch? How do i know if it's working?
- First time spraying!!!
- Alternative Places to put gauges?
- What do I tell those who shake their head when I mention Maxima+Nitrous
- Where should I put the electronic N20 gauge sender?
- Difference in all the NOS types?
- home made bottle warmer?
- I suppose smoke coming from the MSD RPM
- What setup to get? and a couple ?'s
- 3inch ypipe necessary?
- Anyone with a 5thgen change their fuel pump ?
- Is a Fuel Pressure Regulator Necessary?
- RPM based nitrous controller for dry system. Inexpensive too.
- Serious question for nitrous users
- Gains for VI 4th gen + nitrous?
- How to install purge kit?
- how do you wire a "spray" switch?
- How often do you spray?
- Where I mounted my Zex NMU
- Anyone remeber the size of bolt/metal tapping screw...
- NOS Heater Parts Help.
- Nitrious laws?!?!:?!?!?!?!
- Nitrous / Spark pug question
- Hiding place for bottle?
- NE1 Have instructions to install a NOS Window Switch?
- Time for a new clutch upgrade to stage 2???
- ZEX not legal for sale or use in Cali (RANT)
- Smallest shot DPI?
- 100+ Dry Kit Jet Sizes????
- Zex has Wet kits for 4 and 6 cyl.
- Zex 75 shot
- Safest Nitrous Setup Possible?
- Nitrous Newbie
- Fuel Requirements for NX Wet Kit
- Blow down tube question
- Fuel Hose Clamps
- Another FPSS question
- buying used ZEX kit, need advice.....
- Fuel Pressure Gauge:Electrical or Mech?
- FPSS question
- yet another important n2o question
- New to Nos. Can someone help me out?
- 1 Step Colder Gap setting question
- Theoretical Nitrous Question
- Hook up on ZEX or NX!?!?
- Bottle pressure effect
- is the 300z/tt fuel pump enough?
- Does the NX remote bottle opener work with NOS 5124?
- Purge Kit Location?
- Installation Finally Done!
- tuner needed
- Basic N2O question
- window switch/tranny question
- SARD FPR adjustment write up.
- New Toys and Questions
- difference in ET between juice and w/o
- 300ZX Injectors....Ebay.....Good for any Applications?
- Couple of questions for install of NX kit
- Finally bought nitrous system!
- mini nitrous?
