- rising rev limits
- Im in the market for a new clutch...
- Axle Question
- Unboxing of my new Mizu Radiator
- I need help...getting ready for the race season
- 00VI or SSIM on boosted 3.0?
- 6spd 6th gen TURBO (Pic Heavy)
- Ranmas 5.5 Gen Turbo Build
- quick spooling low pressure turbo choices?
- What do I do with this?
- GReddy Emanage Ultimate
- inHg Questions
- MAF Issues - Sputtering/Bucking
- FS: Homemade GReddy A/F harness
- NY WTB 5.5gen Turbo manifold
- Sparkplugs on a Boosted Maxima
- Finally trying this supercharging thing
- Sputter/power loss under load
- Strength of 6 speed transmission?
- emanage ultimate problems
- My car has a dang gremlin i cant get rid of...NEED HELP!!!
- Best way to get coolant to my turbo
- Possible part out....
- V2 tensioner rode quick question!
- emanage ultimate
- Good price for the turbo?
- Turbo manifold and Downpipe specs
- Getting exhaust work done need input/advice 3" vs 4"
- Stalling problem form turbo How to correct it with VAFC2
- 3.0 Stock header Limits for high HP
- 2003 oil pan (turbo)
- Installing Aftermarket Radiator Slim Fans
- Turbo Failure, its done!
- MY S/C IN MY 5TH GEN
- Lost some boost ??
- HELP!! identify turbo????
- For those with Fuel pressure problems
- Now Supercharged
- Unplugging Battery....Running rich
- Boost Controller help wheel spin?
- AN fitting checkball
- Oil pan taping PLEASE HELP!!!
- Max_King's Newbie Turbo Build
- Emanage Questions
- Alternative to bigger injectors
- Stock Driveshaft Axles OK for boost??
- 600CC, Fuel pressure, MAF voltage, Timing
- Help me with a wideband choice
- S/C input needed .problems inside
- Options on SC setup
- V2 bracket without stillen tensioner bracket?
- Anyone Upgrade there v2 Impeller? Link inside!
- exhaust
- AN fittings and braided lines..
- Fuel Pump/ FPR/ FMU electronics for vq30de
- Vortech oil feed fitting Q
- Does anyone have experience with this kit
- Another Haltech thread
- where to get vq30det
- Oil Cooler - some notes
- Fuel help/suggestions on turbo Maxima
- PCV on Boosted engines.
- I Need Help!!!
- How To: Replacing Seals on Vortech V2 Blower
- I seek enlightenment. Turbo Wizard's Step In.
- 300ZX MAF Boos leak problem
- 150k to much for boost ?
- Piston hit plugs? Or detonation?
- Boosted exhaust question - resonator or cut-out?
- greddy boost controller e-01 profec
- maf
- Tial 50mm opening at 18psi
- OOOoops !! I did it again
- My Dyno results
- emanage utlimate help
- 07 SC questions
- How to prepare your vehicle.
- Seeking Advice!! Going boost need stage 2 Clutch & ETC...
- s/c questions
- Hey Guys..
- Vac/Boost & FMU questions!!!
- Is this all I need to tune and log?
- fuel injectors
- HELP!! Removing Vortech Supercharger
- Stillen 350z Supercharger
- 7k redline supercharged? Who's done it?
- Head gasket replacement???
- BorgWarner Turbo Selection Link - Hot Rod magazine
- 2.25" vs. 2.5" Charge Pipe
- Look inside---i30dvr's turbo setup
- Oil Leaking After V2 Install...any help welcomed!
- Seafoaming supercharged max Good or bad idea???
- Can't Lean Injectors at Higher RPM, Emanage.
- 2011 Backyard Turbo Build
- Any turbo Guys in CT/MA ?
- Anyone with EMU and 600cc injectors, step inside!
- Emanage Ultimate Timing At Idle 5 Degrees?!
- EMU Injector Scaling Lag Times. Help!
- Supercharger Gurus, Please Step Inside! :)
- injector/fuel help please!
- How much horsepower/boost can a stock 3.0 maxima Handle?
- 3.5 SC possibilty
- Z32 with 2.5" Charge Piping
- 4thGen: Which intake manifold is better for turbo?
- What's the best turbo for street use(4th gen max)
- Bees in the can!
- Ignition Timing Stillen Cam Sensor Bracket
- Cold Air Intake for S/C Worth it?
- dual exhaust setup, H-pipe, X-pipe OR neither.
- what is this?
- Charging for mpg: turbo vs. sc
- Supercharged/Tuned Car Bucks, Need Advice.
- My HX35 build
- Been a LONG time.. but Fuel prices force me to bring it back!
- Looking for stock 5 speed open differential
- Precision SC61 6152E Turbo, need advice.
- 99' S/C acting up, emanage blinking constant red
- 2002 Turbo Maxima
- V2 Supercharger Slight Belt Movement
- 4th gen Charge pipes in 5th gen, and other Q's
- 3" exhaust silencer
- Charge Piping 2.5" or 3"?
- Help w/ JWT SC tune
- Clamping MAF..
- injectors
- 97_Roadrunner's built VQ35 thread ;)
- HX40 1.00AR vs. .70AR turbine
- OPTIMAL dowel pin/cam drilling position on 4th gen vq35de supercharged
- V3 SI Anyone?
- Weird Starting Problem. Fixed
- Will a Z31 300zx MAF work instead of a Z32?
- Need EU help...
- Another Boosted 3.0
- v2 belt tenioner wtb
- MEVI activation with SC
- supercharger feedline
- Need help - 4th gen stock timing
- Fuel Injector Install Question
- Just curious. what is the efficiency of my turbo?
- JWT ECU question
- Supercharger Kit question!
- Builded VQ35 and twin RMT Built thread.
- Running ERG and Boost
- Turbo inline oil filter
- Using lower Octane fuel for road trips
- Ignition Timing for Turbo 5.5 Gen
- divided manifold
- E-85?
- I need a turbo manifold.
- Questions: turbo rebuilds, BOVs, and turbo manifolds
- For those that make your own feed pipes.
- MAF: Q45 vs Z32
- Why am i adding so much fuel up top?
- Well it finally happened..
- 3.5 SC'd Dyno Results!!
- Beware of ACT Xtreme PP
- THE Wideband Thread
- let's get started
- supercharger questions
- Safc2,Vafc2,Neo
- Couple quick questions about my SC 3.5
- Ford Mustang Cobra 39# Injectors
- HKS 50mm or knockoff help please?
- VQ35de uneven bank AFR (Evidence inside!)
- 3rd gen turbo build
- Need help w/Greddy EU *ASAP*
- meth injections,
- VQ30 HP/TQ Potential
- EU questions... Please step in
- 13.9 @ 101.8 mph - Now what?
- BOV before IC or after?
- PCVs and turbos
- Built 3.5 Compression test results...
- Blown Motor??? I think
- Big Problem...Help
- Well it turned on..
- Adjusting Timing with EU + J&S Safeguard for knock detection.
- q45 install?
- Any JWT ECU timing logs out there?
- NGK BKR6E white residue, not on the tip.
- Finished: 3.5 turbo swap into '99
- Dynomax VT muffler (review)
- Where to buy small tensioner pulley?
- V2 370CC Injector z32 MAF problem
- Starting I35 Turbo Build
- Defi controller & Auto Meter gauges
- Help me Understand A/F ratios from a Boost/RPM POV and Tuning Advice.
- Any current/active members running 2.62 pulley?
- 96 turbo build
- turbo ???
- V2 with BOV fluttering issues.
- How to start up a new turbo setup???
- Pyrometer Location
- Oil choice/help with turbo thread
- Streetz Dyno (Low boost)
- Took the SC off yesterday..I have a quick question
- wastegate opinions
- supercharger or turbo???
- Greymax's Coil Booster with pics
- Engine blowing oil, now what?
- car feels like it hits a wall
- need help with fuel pressure problem
- MAF Delete Successful
- DevilsOwn Stage1 Methanol Injection Kit - Install and review
- V2 SC Kit
- V2 SQ supercharger question
- turbo 3rd gen dyno vids
- Z32 mafs for sale
- Two turbo 3rd gens going at it on the track
- Exhaust Reccomendations?
- Injector question
- EMU quick questions: I/J maps and A/F auto tune
- test on my turbo maxima and the result ....
- Supercharger
- Please Help With Locating A Decent Resonator
- What clutch? Exedy Stage II?
- 3inch Exhaust
- Tune runs sweet.. what do you think?
- $10 fog machine
- can i go on a 12 hr trip with my sc ?
- 2.5" or 3" exhaust
- My fuel pressure isn't rising
- Gas Millage with supercharger post your MPG!
- Bypassing KS but still be Safe.
- Compression ratio on a VQ30DE turbo
- EM-U help
- Equal length forward feedpipe
- Whos running a holset?
- Mrood1986's Build Thread - Start
- super n000bness
- Surging? Z32, JWT ECU supercharged Max
- PFI kit on a 5.5 gen
- What type of turbo manifolds are people using?
- My new 3.5 TB TPS Bracket
- SAFC decel air
- having a starting issue
- a/c with turbo setup ??
- Have anyone boosted tried IFR6E11 iridium plugs?
- EU vehicle speed pulse ??
- AEM Fic in 4th gen
- Cheap exhaust flanges for VQ30/35
- 3rd Turbo in 9 Months
- Has any SC 4th gen guys done the 00VI swap?
- 3.5 supercharged clutch?
- Soaked Plugs
- Z32 MAF on 5th gen........
- J&S Safeguard
- whats a good size intercooler for a 5.5 gen
- VQ35 with ATI C2, Running JWT 95 ECU.
- Checking fuel pressure on VQ35.
