View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. I think I broke an i30
  2. Relist of my custom pistons for sale
  3. VG Turbo with 10:1...
  4. Mounting Gauge on Steering Column ??
  5. TRE transmission build is complete
  6. 0104 (Speed Sensor) ?
  7. 12 psi on v2
  8. Dyno numbers
  9. gauges for s/c?
  10. Need some help
  11. NOPI Nationals
  12. No Hydro.pressure On The Cluth After Boosting! ON MY 1993 MAX. WITH THE VE30DE MOTOR
  13. Going to the track.....
  14. Aluminum Griffin Radiator (New Toy)
  15. charge piping diameter
  16. Purchased the PLX R500 wideband O2
  17. Carnal c30???
  18. Methanol Injection?????
  19. Need help on boost controller!!!!!!
  20. bucking and ish..
  21. FS: JWT-ECU, 96' 5spd
  22. anyone have any emanage setups they wouldn't sharing?
  23. I have 3 trannies and going tp prep the internals for cryo who.....
  24. Supercharger question
  25. Looking for a V2 Supercharger
  26. Anyone is ditching their oem foglights?
  27. Anyone have pics of VQ30DET manifolds?
  28. My Emanage Ultimate is here!
  29. 550cc injectors
  30. New Track Times
  31. Few questions on maitence
  32. Advantages of a: Built VQ35 vs Built VQ30
  33. Walbro & FMU/FPR Install Questions
  34. S/C or Turbo'd max with 142,000 miles
  35. how will this turbo perform on a vq30de
  36. SC Problems
  37. 00VI or MEVI???
  38. How Much Boost?
  39. Maf and nitrous question...
  40. What are the part numbers for the hex head bolts holding the V2 to the plate?
  41. V2 Blower and Plate on Ebay
  42. Supercharger Vs. Turbo
  43. 01 turbo question
  44. When will this turbo spool?!
  45. What are you Using for Cold Air Piping ?
  46. What plugs?????
  47. how much??
  48. WTB Stillen 2.5" charge pipe.
  49. Supercharger Pros I Need INFO!!!
  50. Oil feed and return lines
  51. Emanage Pressure Sensor help: orientation of harness plug
  52. counting my blessings.. and learned a lesson..
  53. i can get a supercharger insalled for $700 need help
  54. Clips of Non-NA max
  55. Stillen Supercharger. Whats a Good Price?
  56. jay25 MOD
  57. Got the Cartech FMU, Aeromotive FPR and Walbro 255:Anything else I need?
  58. Put the car on the dyno (A few issues)
  59. WG spring regulated boost question
  60. 3" Exhaust
  61. J&S gauge install...
  62. Just finished SC install!
  63. AN hose sizes converted to inches
  64. Oil line kit for turbos - all in one place, inlcuding BSPT fitting for block
  65. for those of u that want to squeeze a few more ponies
  66. Green flashing active light on e-Manage
  67. melting coils
  68. FS: NYC 3" Ypipe
  69. Need Help With Fmu Disk
  70. Blitz blow off valve adjsutment
  71. Dyno update...should I be dissapointed???
  72. What is our max oil pressure under normal operation?
  73. People with MAP sensor for boost referenced tuning, what one do you have?
  74. ??
  75. anyone know boosted95??
  76. Why two Blow off valves???
  77. Track times at US 41 Friday.
  78. Just Got My Turbo Maxima Back** Need Help
  79. 410cc Injectors & Z32 MAF is in....PROBS!
  80. A32 ECU, Z32 MAF, 550 inj and 10psi results
  81. Custom internals possible for sale
  82. Grand National Turbo?
  83. jdm vq30det
  84. JWT Cold Start - NProbe Data
  85. BOV and Wastegates
  86. Oil feed and return lines
  87. Where's the missing boost pressure?
  88. V6P link for FI issues...
  89. F/S: Calsonic r32 Intercooler (pics)
  90. polishing a turbo..
  91. SR20DET swap?
  92. another 3" charge pipe question
  93. what do think about that turbo
  94. Brand new stillen kit for sale
  95. Dead Spot when Cold !
  96. Measured 3rd gear thickness of 01 AE LSD - 14.31mm
  97. V1 rebuild with V2 internals?
  98. Has Anyone had problems with the VB Mod?
  99. gauge pod pics
  100. how much did u guys pay for a turbo
  101. Thoughts about MAP-ECU?
  102. Possible for sale : Quaife
  103. more air?
  104. VQ30DET and VQ30DE differences?
  105. FS: Cromex Stillen Piping
  106. where to buy 4th gen SC?
  107. Pics of the Engine !!
  108. JWT ECU, Z32 MAF, and 550's are in....
  109. Rough Idle when Cold
  110. Two quick set up questions
  111. MAP Sensor Code.
  112. who has achieved torque numbers well over 300 with a SCer?
  113. just one question: what do i need for 10 psi turbo?
  114. shops in the northeast
  115. Is a 100 PSI Fuel Pressure Gauge enough when running a small pulley?
  116. Turbo or SC?
  117. What would be the ideal pipe diameter from blower to TB? 3"? 2.75"? 2.5"?...
  118. Anyone running the Innovate Motorsports Standalone Wideband Gauge yet?
  119. PVC as charge piping?
  120. down pipe
  121. Interesting JWT discovery.
  122. TURBO OR TWIN TURBO ?????? maxima 95
  123. thought you guys might wanna know about this site...
  124. Most basic supercharger setup
  125. How many hours to remove heads and timing mechanism? Weight of shortblock/crank
  126. UR overdrive pulley
  127. Opinions piecing together a turbo kit
  128. Postion of wastegate
  129. what clutch should I get???
  130. s/c tuning?
  131. solution to v2 kit?
  132. Good info on vertical flow ICs
  133. difference between intercoolers
  134. About to by boosted95s max have some ??
  135. How beneficial would this rebuild kit be?
  136. Anyone using a HKS 40mm wastegate?
  137. Intercooler Depth
  138. How much did you spend on your FI setup?
  139. WTF is the problem with my car!!!
  140. power range with injectors
  141. Gauging Interest: FS: V1 S/C Plate
  142. FS: 370cc injectors and weapon r afpr
  143. Pics Of Jeremykedel's Custom Trubo Setup In His 2k2
  144. installing fuel pump
  145. question on vacuum lines
  146. Hks-ssq
  147. update on z32 maf on noncharged side
  148. wastegate spring rate
  149. dynamic/carbon seal???
  150. switching pullies
  151. Quick BOV Question ?
  152. Manumatic Help
  153. clucth changes
  154. EVAP Code with JWT
  155. intercooler size
  156. best type of resonator for sound supression?
  157. Installing a quaife from a 4th gen to a 5th gen trans?
  158. 91 turbo VG pics
  159. Greddy's Profec E-01 ...
  160. Z32 on Charged Side Update
  161. 550cc injectors from a 2JZ
  162. Pop! goes third gear...
  163. Boosted timing?
  164. what a/r
  165. 2nd gen + 8 psi = x
  166. Just a little up date
  167. Swap after FI?
  168. for all boosted
  169. Need Some Turbo Explanation
  170. JWT ecu/timing question...
  171. Installing a AFPR....
  172. Oil Feed + Return Line (make $$)
  173. Article on tuning with EGT
  174. looking for used SC for 5th gen
  175. MAP Sensor Code.
  176. Problems with Emanage?
  177. Symtoms of a Bad MAF ??
  178. The weakest links of the vq
  179. Stock Shortblock
  180. I got a laugh outa this. (ebay link)
  181. Noob to boosting
  182. 5.0/5.5 gens...PE380cc injectors(used)
  183. F/S Chrome 3.125 pulley+ gatorback belts
  184. Why did my base FP drop? MEVI related
  185. Oil Coolers
  186. anyone have a S/C on stock parts?
  187. Plug Gapping ??
  188. FS: J&S SAFEGUARD
  189. Xterra Supercharger
  190. FS: Cartech FMU
  191. stillen blower parts
  192. Hmmmmm....i Don't Knowww....
  193. Got the car back FINALLY.
  194. Where to buy compressor wheels
  195. clicking from top of the motor...
  196. i found a pretty good turbo-to-engine size chart
  197. 9 lbs boost with 3.125"??
  198. looking for used 4thgen V2 kit for 5speed
  199. 4th gen V1 kit to 5th gen kit parts?
  200. z32 placement question
  201. Well All my Stuff is in, Problems !!
  202. EGT and hottest Cylinder?
  203. Any of you guys need a 300TT fuel pump?
  204. How tight do you adjust your bov???
  205. Difference in Z32 Connector
  206. Ways to test MAP sensor?
  207. Went to the track for the first time...
  208. vortech fmu with an afpr??
  209. sard fpr vs aeromotive
  210. bad BOV
  211. Detonation and preignition
  212. how do you take off the pulley from the supercharger??
  213. What are the specs on the Stillen/T-Rex pump
  214. Anyone want to Sell, Trade for, or let me Borrow their Emanage Support Cable?
  215. Tranny Fixed - Getting Stuck in gear - turbo / exhaust piping vs linkage ?
  216. pfi turbo owners
  217. (Pulling my hair out) s/c question
  218. boost only at 7-8 psi in 3rd but 11psi in 2nd?
  219. FMU Needed after JWT install
  220. Pipe diameters (t/c)
  221. Well hell. Blown motor.
  222. looking to SC, Qs about tuning
  223. Any thoughts on the Greddy emanage ultimate ?
  224. E-manage & injectors: whole new can of worms
  225. s/c being discontinued?
  226. Turbo not spinning at idle - sometimes
  227. Got the new motor running after the swap - knocking noise though? Worried
  228. Increasing air flow to SC CAI
  229. Where do you guys get you SC CAI From?
  230. very odd happenings
  231. How much is a V2 rebuild?
  232. Reliable/Reasonable tune shop on Long Island?
  233. Next best mod?
  234. Who has a Built Engine? (List)
  235. Found an old video...
  236. Finally Fixed my car
  237. HELP - Best Way to Run Vacuum / Boost Lines
  238. Opinions please
  239. Cracked Oil Return Line on V2
  240. do i need a jwt ecu to run a z32 maf or can i use a safc
  241. i'm about to bu ya turbo, but.....need your help
  242. Injector Install Question
  243. headers
  244. supercharging without a LSD
  245. Turbo kit discovery
  246. z32/j30 maf?
  247. who here has water injction
  248. Z32 370cc Injectors FS
  249. emanage problems
  250. More delays in getting the car back on the road.
