View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. compression high...
  2. Wideband or J&S?
  3. ok what to do with my wideband
  4. what else do i need?
  5. Roots Style S/c For A Vq30de?
  6. ptatohed's just-for-the-heck-of-it Cold Air Intake...
  7. Lame ET @ 119mph today at the track
  8. Replacing Belt need help
  9. how about this wide band
  10. Need Help Quick
  11. Fuel Pressure sender placement ?
  12. V2 idler tensioner pulley
  13. Curved discharge blowers
  14. Clutch Talk !!
  15. Should i get turbo or SC for my 5th gen auto?
  16. FINALLY...a 1:1-12:1 adjustable FPR
  17. u wanna stillen SC pipe??
  18. Does anyone want 00 Intake manifold??
  19. 2.62 pulley for sale
  20. 2nd Dynomax 3" Bad Again !!!
  21. new to the turbo world...how does everyone feel about this ??
  22. cam options Need to decide quick.
  23. what do you think of AEM UEGO Wideband
  24. Clutch question
  25. $hit, what pulley to use!!!!!
  26. Dyno Results 03/05/2006
  27. Would a wet nitrous shot max out a maf?
  28. wtb a 3.25 or a 3.33 pulley
  29. Manifold options
  30. Timing!!! 451/447
  31. Emergency Help Needed
  32. Stock ECU, Z32 MAF, 550's...explained
  33. In need of a suspension setup (boosted)
  34. Whose Max is this for sale? (turboed)
  35. Encountered one of these last night....
  36. Dynoing this friday again
  37. upgrade supercharger
  38. Dynoing Car This Sunday
  39. Cold Weather Start
  40. What fuel pressure regulator do you use?
  41. Do you guys feel ASP pulleys are just as good as Vortech pulleys?
  42. First dyno for the Max
  43. Nitrous/blower, fuel delivery Q
  44. G35 Turbo or SC fititng the 6th gen IMPOSSIBLE?
  45. Dyno'd today (pics)
  46. 2000 Max ECU cylinder map?
  47. Timing and SAFC corrections (data logs)
  48. Vids of my car...
  49. M90 Gtp Sc
  50. Injectors
  51. Fuel pressure regulator.
  52. gauge pod colors?
  53. AEM Wideband Controller
  54. 3.5L w/ SC is now underway
  55. post pic of your Js safegaurd
  56. How-to install...
  57. Stillen SC Charge pipe for 4 gens!!!!
  58. Please Help! Erratic ticking noise near my S/C!
  59. F.s. Walbro 255 Fuel Pump
  60. Advice wanted
  61. 3.5 turbo dyno
  62. Need help using greddy EBC...confused.
  63. 2.62 Advice
  64. Launnching with a boosted car. Techniques?
  65. Why a CCW Straight Discharge Blower?
  66. FS: Blitz Super Sound BOV - Vid Clip
  67. 2.62 pulley 4 sale!!
  68. Zeitronix and Serial to USB
  69. Amisoil hookup?
  70. alarm turbo timer vs stand alone turbo timer
  71. 3.5 swap worth it?
  72. FS: 3rd Gen Turbo ECU, JWT: 370cc inj.
  73. Blew the motor on the dyno!!
  74. Ultimate problems with emanage.
  75. exhaust question
  76. when do you usually start to pull timing...?
  77. Need help with gauge mounting
  78. Quick Supercharger Querstion?
  79. part number for 2000se 5 speed 17" ecu federal
  80. price Q on J&S
  81. since the tracks are closed....
  82. FS: Turbo Feed and Downpipe
  83. Advice needed!!! 2.62 pulley may be going on soon!!
  84. **Matty's SuperCharger Parts List**
  85. exhaust cut-out clip?
  86. Not shure what Clutch or Flywheel to get?
  87. wiring
  88. call it a ricer question if you want. bov?
  89. Please Help me Figure out this BOV problem ?
  90. HKS SSVQ BOV with Stillen Supercharger
  91. Emange Ultimate can advance timing...
  92. Code for Fuel Pump control module?
  93. Supercharger Question?
  94. Emanage Ultimate this weekend,woohoo!!!!!
  95. going to the dyno Saturday!!
  96. Anyone have HLH's compilation video?
  97. Cheaper price?
  98. Squeeling at startup with loss of power steering?
  99. Quick exhaust question
  100. The Wizard's and ptatohed's Water to Air Aftercooler project complete (pics)
  101. yup turbo vs s/c again!
  102. DIY supercharger rebuild
  103. Model # of V-2 Superchargers
  104. Highest HP daily drivers
  105. Possible SC upgrade questions
  106. What does this plug go to?
  107. Does anyone have a scavenge pump for sale?
  108. weird problem with the greddy EU
  109. 370 Injectors, Z32 MAF, some issues
  110. walbro fuel pump
  111. Got timing?
  112. Stock clutch on SC'd Maxima at 60k miles
  113. Compression check
  114. What do I need for emanage ultimate?????
  115. FS: Greddy Profec EBC
  116. Has anyone used Det cans for tuning?
  117. Fuel Hose Size ?
  118. Z32 MAF Needed
  119. Bought turbo for a VQ35de; need your opinions pls.
  120. WTB:Motor Mounts
  121. any one have a t62-1 turbonetics for sale?
  122. Any reason not to do a DEK in my turbo car?
  123. Stillen charger pipes on EBAY!
  124. Question on types of exhaust piping.....
  125. FS: Level 10 auto transmission 1995-1999
  126. Motor build????
  127. ATP VES installed and wooweee!!!!
  128. For sale 370cc Z32 TT injectors
  129. Question on 3" charge pipe for 5th gen
  130. Need A New Flywheel (suggestions?)
  131. Observation: Boost accuracy.
  132. Isolators
  133. Forced Induction Questions?
  134. Header Install
  135. what do 5th gen's do for injectors?
  136. Turbo or swap
  137. All You Supercharged WannaBees
  138. Next steps for the SC setup
  139. Before I get a Headache - WTB: Smaller SC Pulley
  140. About to start the project finally
  141. sr20 turbo on 97 vg30
  142. First Drive..
  143. Rebuild Vortex SC
  144. Digital Boost Gauge ?
  145. Boosted w/cams
  146. New Live Edit
  147. Weird CEL code...
  148. cartech fmu
  149. Got my Wideband In
  150. Top 10 ways you know you own a turbo maxima
  151. bit the dust....
  152. Fuel injectors, flow rates, fuel system
  153. making cai for s/c v2, but bypass valve?
  154. Greddy B-Spec II EBC questions.
  155. Help gas canister leak fuel!!!
  156. Obx HLSD differentials
  157. walbro fule pump?
  158. It's 4 sale
  159. NEW: Garrett BB center sections for T-series
  160. Going Turbo
  161. Excellent article on Detonation and Pre-Ignition from an expert
  162. VQ35 Eagle 4340 H-beam rods $600
  163. Now what Muffler ?
  164. Another one
  165. ACT Clutch questions!!!!!!!!!!!!!!!!!!
  166. turbo XS UTEC fuel managment system...
  167. Installation of a recirculating BOV???
  168. Where to buy piping for 3" Charge pipe??
  169. 1 step or 2 steps colder?
  170. EU Rev-Limiter works! Timing seems too....
  171. CS problem
  172. Any of you boosted guys need some Place Racing poly motor mounts?
  173. apexi power FC
  174. Injector ?'s
  175. VQ30 rods/pistons are SCRAWNY!
  176. will the dek with-stand boost
  177. Stock VQ30 internals pics?
  178. roll bar
  179. 5 Gen owners........
  180. Cold Weather & Turbo Maxima ?
  181. Finally got my car back today...
  182. Weird Fuel Pressure Readings
  183. anyone know the part# for the vortech blower for 99max?
  184. What to do for tuning
  185. ok houston we have a problem!!!
  186. Helical or straight cut gears?
  187. 4th gen 5speed trannies
  188. 5speed gone?
  189. New turbo Y pipe setup with pics
  190. acc video of the turbo vg check it out
  191. a little shot of my boost gauge
  192. On a SC'ed setup...which would be more efficient?
  193. help..sometimes car wont start...
  194. quick help please with white smoke comin' out of the exhaust
  195. Ouch...info@greddy.com response to my IDC issue
  196. FS: Z32 MAF and pig tail
  197. hoses - lines - fitings?
  198. Bosch Bypass Valve adapter?
  199. hoses - lines - fittings?
  200. VQ30 HP record?
  201. FS: *NEW* V1 S/C Plate Kits...
  202. 3.5 supercharger?
  203. Weird Buzzing...3" with DynoMax Super Turbo
  204. Dummy question(s) regarding FMU and Fuel Pump
  205. FPR/Walbro fuel pump question
  206. wideband o2 question
  207. Greddy E-manage install write up???
  208. Interesting Tuning Info
  209. Turbo Sing in
  210. hx35 on a maxima 3.0
  211. help with turbo timer wiring
  212. Look at this shaft...wtf
  213. MAF charged or not charged
  214. Gotta replace an engine.....
  215. Pics of my progress: turbo install (56K bad...)
  216. anyone have SAFC 2 wiring diagram?
  217. Zeitronix Wideband kit
  218. Standalone availability/type and pricing
  219. Fuel Pressure regulator for S/C?
  220. Anybody got videos
  221. FS: 2000-2003 PE380cc injectors $425
  222. JWT S1 cams w/springs...new in box..$1000 shipped
  223. Emanage+GM Boost Solenoid = EBC for $10.32
  224. Oh the joys of a turbo I30
  225. Another piggyback choice for you guys perhaps
  226. how much timing is added with SAFC?
  227. which one is easyer to put together?
  228. best place to get a electric cut out
  229. Engines + Boost(Which one)
  230. ? for those that want to turbo their max
  231. Who just tuned their 2001?
  232. spec stage III reveiw
  233. Pic of reclocked blower and 3" piping.
  234. Haltech...
  235. Q: Running with a 3inch exhaust cutout
  236. Official, SC Rebuild TIME!!
  237. Injector question on an engine swap.
  238. ran at the track
  239. Ram air for the track with turbo
  240. Turbo hosing
  241. Missing 14mm nut for the tensioner pulley
  242. vq35 injectors?
  243. Sharif got the two step working on the EU
  244. Stillen
  245. Oil Cooler for sale!!
  246. anybody played with E-85 yet?
  247. Hey guys, need your thoughts...
  248. Any 5.5 gen with SC here?
  249. Water Injection
  250. Found some useful information.
