View Full Version : Supercharged/Turbocharged
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. 00VI and 290ccs at 10.5 PSI
  2. Turbo project part out....
  3. few questions: built n/a 3.5 and use later for sc
  4. Why is my belt squealing?
  5. V2 NOISE IS THIS NORMAL?
  6. ok spool problem! comes on at 2500rpms
  7. Lexus idler pulley
  8. A question about turbo manifold design...
  9. Compression on a Bored engine: VG30ET
  10. FWD vs. RWD: VQ35 SC Dyno Comparo at 13psi
  11. Injector info needed
  12. weird smoking problem
  13. Garrett T25 non-intercooled on VQ35
  14. 3.5 build up time
  15. Can anybody post pics of where they mounted their gauges at?
  16. I need emanage ultimate software cd
  17. What clutch
  18. STS turbo size question for a 3.5
  19. V2 supercharger finally installed and running!
  20. MAF position in a boosted application
  21. Methanol injection- need a how to posted
  22. does eu cover it all?
  23. quick turbo questions
  24. swaying under boost!
  25. My boosting crossroads... please weigh-in
  26. Turbo ?
  27. SAFCII safe tune?
  28. SFR Turbo re: 02 VQ35 Alti.
  29. Stillen SC and PCV
  30. Stillen S/C ---> Vortech S/C
  31. Plugs and Gap Recommendations for Turbo setup
  32. FS: Vortech T-rex fuel pump and FMU
  33. Adeiu, Fellow Boosted Maximas!
  34. Need help with installing belt on blower, crank pulley, etc..
  35. manifolds
  36. Need parts to rebuild VQDEK (2k1)...
  37. WOW! Just got off the phone w/ Corky Bell
  38. Things i need to know before droppin in SC
  39. SARD FPR Leaking
  40. going from s/c to turbo whats the best turbo around ?
  41. Clutch Master Cylinders
  42. Anyone has pictures of the SC parts?
  43. Can I use msd 8735 for launch control and.....
  44. Turbo Checklist
  45. Turbo experts step in
  46. VLSD Not working?
  47. FS: Performance Transmission
  48. Oil cooler on an SCed Maxima.... can we use our existing oil feed line?
  49. Little black box connected to Auxiliary Fuel Pump Switch?
  50. Feedback on Innovate Motorsports XD-16
  51. s/c blower question
  52. E-manage ultimate, wideband for sale
  53. Apexi NEO
  54. Looking for a oil drain back hose for V2 kit!
  55. Upgrades: T-Trim, FMIC, Mondo, Projectors
  56. looking for greddy blue wiring diagram
  57. Should I be concerned about Walbro noise?
  58. FS Stillen vortech fmu, aux fuel pump and hob
  59. Dip Stick blowing out.....suggestions!?
  60. Poor oil circulation due to Oil Cooler?
  61. F/S vq30det manifold/ and tial 40mm wastegate flange
  62. Replace Autometer Fuel Pressure gauge?
  63. F.S. 410cc injectors off BAGS old max
  64. My fuel rail adapter is leaking again :(
  65. Cheap turbo....why?
  66. What kind of power would I make going with 9psi pulley instead of 7psi one?
  67. How do I differentiate between blower trims?
  68. Rich or Lean Condition ??
  69. Temporarily going unboosted, fuel pressure help
  70. Is there a turbo writeup
  71. FS: V2 blower/ plate
  72. Tunning with EU
  73. anyone using the Greddy Type RS ??
  74. new turbo set up Tell me what you think of it.
  75. V2 officially on board. chalk another one up for CA
  76. sc odd idle
  77. Fuel pump/injectors?
  78. Independant oil reservoir
  79. Intercooler Cooling Kit, Worth it?
  80. Nitrous + Turbo, will the nitrous caue spike in boost?
  81. Maxima "Engine Kit" with Forged Pistons
  82. Broken Pintles :(
  83. Total Cost for a turbo for my 03
  84. Is HKS the only maker of AN fuel rail adapter?
  85. Rear Mounted Oil Cooler
  86. noises during boost...
  87. FS: New turbo parts
  88. Turbo Question
  89. Is this the right oil filter stud?
  90. Exhaust/Muffler Setup
  91. manage
  92. How difficult?
  93. I want to charge my max by next summer will I get about 270HP/230WHP?
  94. How much boost???
  95. oil filter relocating?
  96. Part number for z32 Maf
  97. 5.5 gen turbo help...
  98. EU install & now have a question
  99. Feedpipe gasket? where?
  100. Leak at Oil Feed Tee
  101. How to calculate Maximum Air used by engine
  102. S/C intercooler
  103. Anyone have a pic of where you're T-ing the BOV?
  104. Need help with vacuum lines on 3rd gen turbo
  105. VIAS is stuck, can boost cause this?
  106. Pressure drop after VI opens
  107. Parts list
  108. Any 5gen with V2 kit have pics of how air filter is setup?
  109. crankcase breather clarification
  110. pathy throttle body Q
  111. Stock Injectors w/ 3.12 in pulley and a V1?
  112. Orgers who relocated their windshield washer reservoirs: Step on in!
  113. new turbo desing idea, what size pipes?
  114. Reliable boost with T-trim
  115. What's the mileage on org members with turbo or supercharger?
  116. TIAL 50mm BOV question
  117. How to writeup - Reclocking the blower
  118. Where's the videos at?
  119. Where can I find these bolts?
  120. another boosted 4th gen PICs AND VIDEO
  121. v1 plate install in progress need help quick
  122. Clutchnet Fiber Carbon clutch pics 56k no no
  123. Found some alternate 5 speed gear ratios for our transmission
  124. what if no dump pipe on the wastegate
  125. can Engine Restore damage turbo seals?
  126. F/S: Idler pulley
  127. greddy profec a setup help?
  128. how about these gauges???
  129. Pretty Interesting..V1 + V2 Plates
  130. Noticed something odd on my pulley
  131. finally I took some pics of my setup
  132. People with V2 kit and V1 plate please step in!
  133. Lexus Metal Tensioner Pulley Part Number & Pic
  134. Vortech Bolts - Timing Cover Leak?
  135. joined the SC club
  136. 6th gen S/C?
  137. FS: foward feed pipe
  138. Intake manifold for Supercharger??
  139. anybody need a pancake filter?
  140. Some More Questions for ClutchNet Owners
  141. T trim Vortech superchargers
  142. 3 Bar MAP volt ---> boost conversion, anyone?
  143. Compressor wheel needs balancing??
  144. WTB: Modified tensioner belt bracket for V2!
  145. FS: PLX R-500 wideband AFR datalogging computer kit
  146. Just ordered my twins (need opinions on spool up)
  147. breaking up after 6speed swap
  148. Electronic Boost Controller for 20 bucks.
  149. SC: 5th gen vacuum line placement & fuel line final questions
  150. F/s z32 Maf with pig tail
  151. turbo rebuild kit for T3/T4
  152. Boost, 370 injectors, 300z MAF, and no JWT? Come in!
  153. supercharger with fuel problem hellp!!!
  154. wtb vq30det exhaust manifolds
  155. What kind brand and weight are you turbo maxima using?
  156. Oil feed Line Help
  157. Does anyone have a Greddy oil catch tank
  158. 4th Gen Turbo Kit?
  159. Cheap WBo2 setup
  160. Home made Oil Cooler !!!!!!!!!!!
  161. Looking for VQ35 Harness
  162. F/s: Fmu 12:1 & 8:1
  163. Emanage Blue pressure sensor (do i HAVE to use greddy?)
  164. more troubles after the 555 install and z32
  165. Vortech FMU Question
  166. soon to be SC have some fuel and gauge questions
  167. What causes psi to drop when removing air filter?
  168. 5th Gen Turbo kit quest
  169. VG Turbo Lag?
  170. Something for the VQ30DE
  171. WTB Stillen Supercharger Kit for 01 Maxima
  172. SMt-6 or 7 Base Map Needed ASAP
  173. FS: V2 Stillen Supercharger Kit
  174. max not doing so good
  175. FS: Build auto transmission
  176. Found my leak: its the MAF
  177. any 370cc injectors drop in my 91 max?
  178. grey smoke while trying 555cc
  179. Getting a quote for the Emanage Ultimate
  180. The ORG's opinion counts......
  181. Need flanges
  182. Looking for a BOV
  183. Intercooler/aftercooler selection
  184. Stillen Supercharger BOV Confusion
  185. Brown 370cc Injectors?
  186. Swapping to V1 plate, tensioner clearance
  187. 3.5 swap progress...
  188. s/c pulley calculations re: boost @ redline
  189. apexi auto timer
  190. s/c intercooler question
  191. Brand new Snow Performance water/alcohol injection kit FOR SALE
  192. Performance shops who install sc in south jersey/philly area?
  193. V2 Plate Question
  194. Upgrading V2 Pulleys?
  195. is my 520whp a reality ? hope so we'll see with these upgrades
  196. Disappointed with my SC
  197. New intercooler setup
  198. Emanage Ultimate Help!!!
  199. Intake Air Temperature (turbo)?
  200. Question: Auto with supercharger / Turbo?
  201. F/S: Two FMU's 12:1 & 8:1
  202. Guys with WB02, hows your car on start up ??
  203. Wtb 3rd Gen 1992 Ve5 Custom Turbo Set Up
  204. more clutch/tranny problems
  205. What piping to use on 00VI swap?
  206. Help me identify what im missing from my V2
  207. Supercharger Part Oil Tee adapter assembly
  208. sandwich plate on VG
  209. SuperCharger to replace PS pump?
  210. 550 with a32 maf
  211. To those that are running over 10psi! Q"s
  212. turbo - good deal for who?
  213. So I've grown tired of being N/A...
  214. HELP ASAP Superchar 2.62 pulley
  215. Installation directions for supercharger on 5 gen?
  216. Turboing my cef.
  217. what kind of power you think? heres the specs
  218. Defi Link Gauge System, White face FS
  219. Same side FMIC inlets. Which to pick from?
  220. WTB low comp pistons
  221. FS Turbo Feed Pipe
  222. final part out.
  223. Q45 Maf on a turbo max. Turbo inlet side piping.
  224. On a Supercharged Max, what is the drain interval
  225. smoke from pcv!!
  226. still need some advice on timing
  227. Been searching but can't find it.
  228. any thoughts on 4" exhaust?
  229. Stock Clutch with Supercharger
  230. I want to turbo my car, Advice plz
  231. 350z or FI my Max?
  232. Massive Part Out
  233. Emanage Blue support tool
  234. a few supercharger questions, oil feed/return, pulley
  235. Critique my turbo set-up
  236. Turbo forsale!!!!
  237. SC oil drain back hose problems
  238. turbo kit pics
  239. Shops that Install Superchargers
  240. OIl Pressure?
  241. WTB: 3.60" Pulley and Belt Tensioner bracket..
  242. Who here is using Emanage Ultimate, a wideband, and a J&S Safeguard?
  243. In the wake of the DET craze..
  244. I'm looking for some FMU ratio disks.
  245. emanage blue tuning questions
  246. Car is Detuning itself
  247. Interesting Turbo Find....carborated.
  248. v2 stillen supercharger for sale
  249. 563whp/557tq stock vq35
  250. Underdrive pulley
