View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24]
  1. 12:1 FMU disk diameter
  2. VG30ET v. VQ30DET - compare/contrast
  3. I just sold my boost to GoldenGlory
  4. Oil return line hose?
  5. Sard FPR install
  6. Hooked up my EGT and FP..
  7. Boost exhaust question
  8. A new toy for cars with air induction :)
  9. MPG or per tank for turbo and supercharger people
  10. turbo question?
  11. bigger injectors. What kind of fuel computer/management?
  12. Is this Flywheel worth it?
  13. Last minute questions before SC fully reinstalled. please help.
  14. Does the UDP effect SC
  15. To all the recently blown maximas
  16. Boost gauge readings (Poll)
  17. HELP: Stillen part number question for 95-96 SC'd
  18. What readings to expect from Fuel Pressure and Boost gauges?
  19. Walbro FP
  20. Help...fuel pump question
  21. I thought that stillen s/c was suppose to make the car run rich
  22. Is this normal?
  23. Pics of my ghey gauges...
  24. SC troubleshooting scenario
  25. Benefits of Water Spray Kits
  26. I just changed boost gauges and..
  27. Auto Gone
  28. turbo question.
  29. I am officially SUPERCHARGED!!! But my Setup is VERY odd!! Check it out...
  30. passing emissions
  31. SC uninstall AND reinstall - Chapter 2
  32. Turboing an Automatic 5th Gen Maxima
  33. Should i get a different y pipe
  34. When changing boost settings on the turbo Maxs, how does one regulate fuel flow?
  35. Parts List?
  36. Where can I get the HKS SSQV inserts?
  37. Place Racing on s/c!!!
  38. SC uninstall - Chapter 1
  39. Supercharged Autos - Hitting the rev limiter?
  40. Why is my car boosting low?
  41. What clutch are you using?
  42. Valve cover filter?
  43. Any one have BOV for sale
  44. Info question: Goodyear Gatorback belt sizes?
  45. my ve turbo
  46. VI with boost - - always have it open?
  47. VQ30DET powered maxima will be running again soon!
  48. Anyone install their own Fuel Pressure gauge?
  49. does anyone have the HKS SSQV on their SC?
  50. Crnk Pulley woes
  51. Any kits to turbo or SC a Ve motor???
  52. Belts seem to squeek during cold starts..
  53. Im thinking of supercharging, many questions
  54. V2 Supercharger kit for sale w/ extra's
  55. Can a BOV hurt performance?
  56. Iridium plugs better than copper for boosting?
  57. Good Idea!!
  58. '95 SE tweeter + dual autometer gauge pod =
  59. Jumpin ribs.
  60. EGT probe location
  61. First kill.....
  62. S-AFC Dyno Results needed
  63. say goodbye to my gates belt
  64. Is 11 in HG for a 3.33" low?
  65. Supercharger is weaksauce w/stock pulley?
  66. Need help w/ supercharger belt size info??
  67. How significant is a free flow cat-back system to a SC’ed Maxima?
  68. Gauges in DIN???
  69. fact or fiction?...
  70. buying supercharger, have a couple questions
  71. How long is the vortech warranty?
  72. 5th gen exhaust w/ boost?
  73. What kind of T-fitting did you use for the Boost Gauge?
  74. Can you weld brass to steel?
  75. Car problems.
  76. anyone need/want a built engine?
  77. Should I get the Apexi S-AFC?
  78. aftermarket knock sensor?
  79. Quoted: $400-600 and 1 WEEK to install V1 S/C
  80. SAFC questions with test pipe
  81. V2 Dyno results (auto)
  82. Anybody have problems with their radiator hose blowing off?
  83. Anyone with Turbo & MEVI ?
  84. Painting Gauge Pod to match Gray interior?
  85. supercharger problem
  86. Turbo or Supercharge that the question????
  87. Optimal exhaust setup for turbo max?
  88. Are SAFC modules removable?
  89. Painting the autometer 2 pod pillar
  90. supercharger thermostat housing install question
  91. What should I expect to run the 1/4 in after SC?
  92. Is my belt too tight? See pic
  93. Hobbs switch
  94. ****en Check Engine light is on!!
  95. Good idea to replace all fuel hoses?
  96. SC pics... a little confused
  97. I just noticed something odd about my VI!!!!!
  98. 9 psi with what pulley and at what rpm?
  99. Successful S/C install, thanks to Jaime
  100. How does fuel cutoff work in our cars, esp. under boost?
  101. Who is running the stock FPR with their Supercharger and are you running rich?
  102. 2002+ Fuel systems, my knowlege and yours
  103. V2 tensioner assembaly HELP
  104. Weird squeeky sound coming from S/C..
  105. Where to get missing parts for autometer gauges??
  106. How do I depressurize the fuel??
  107. where are u guys geting your sc
  108. Who was the person complaining that their car was stalling after installing your BOV?
  109. Narrowed it down to EGT/Boost/FP via Autometer Phantom.....help an idiot out.
  110. Need a good source for SSQV flanges??
  111. Let's talk about EGT gauges and disscuss what means what.
  112. does hks make a univeral blow off valve?
  113. HKS has them, but are there any inserts for Greddy BOV's?
  114. Shopping for Boost and EGT gauges
  115. Reinstalled the V2 for the second time
  116. Why not more SC+MEVI people?
  117. Is there such a thing as an Allen key ratchet?
  118. What a VQ35 w/ 13lbs of SC boost dyno might look like
  119. SC CAI install results in blown MAF
  120. BOV, do I need an aftermarket one or Bosch will do?
  121. Anyone tries a Turbo XS H BOV?
  122. Measuring the tightness on the belt
  123. Opinions on setup
  124. Follow-up - cold start rattling noise fixed!
  125. Belt jumping the pulley!
  126. Sh*T! I still have to grind with a 3.33" Pulley
  127. A nice SC info write up...
  128. stronger head gaskets?
  129. Which way should the pulley on the blower face?
  130. FMF disk price......I got ripped I think
  131. Tuning my SC further (long)
  132. what does a turbo maxima exhaust sound like?
  133. Supercharger deepens exhaust note?
  134. S-AFC or something else??
  135. What does a bad V2 SC sound like?
  136. Boost gremlins
  137. can a supercharger exist with turbo?
  138. Ive decided to go back NA
  139. Placing a turbo kit on an atuo....
  140. You won't believe this!
  141. Boost controller question.
  142. Finished Install, But Car Won't Start
  143. Hey Did You See This?
  144. V2 belt shreds.....
  145. What pulley do you guys recommend for me? 3.125, 3.33, custom 3.25, ect. Need SC help
  146. Supercharger CELs.
  147. oil cooler sandwich adapter fits okay?
  148. Goodyear Gatorback Belt Part #?
  149. What RPM does your BOV open?
  150. is a maxima capable of being a 10 second car?
  151. Which form of boost would be best for me...
  152. Congrats to Turbo95max another Moderator:)
  153. Congrats to Mardigrasmax..our new Moderator
  154. Need Help, SC Stand-off bolts won't fit :(
  155. 5speed vs. turbo
  156. What part of the supercharger plate needs to be shaved, im lost
  157. Why did I get a 8:1 with my FMU?
  158. Belt sqeaking...
  159. I am a nut!
  160. Rattling noise after SC install
  161. V2 Stillen supercharger instructions
  162. supercharging a 4th gen with an auto tranny....
  163. Colder plugs?
  164. 5thgen owners.. Where did you get your gauge pods?
  165. Which 99s need the special SC Kit?
  166. Those Melting Pullies!
  167. Finally can ask questions on s/c
  168. V1 kit with 3.25" pulley - 1 step or 2 step colder plugs?
  169. How long did Vortech get back to you after they received your SC Blower?
  170. nitrous and stillen supercharger
  171. Blitz Blow-Off-Valve Install on 5thGen V2 Setup????
  172. Which pulley remover do YOU use?
  173. Congrats delio...... another moderator
  174. Congrats to JAY25..... a new moderator
  175. why is turbo knocked for auto's
  176. Turbo Timer?
  177. Hopefully someone can adapt Kevings future 3.0L turbo to 3.5L turbo
  178. BOV installed, car stalls
  179. turbo?
