View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24
  1. Where do I buy a boost Guage?
  2. SC Installed!!!
  3. FMIC core size
  4. problem with supercharger install, need advice....
  5. Do you need a bigger battery/more cranking amps when you have an SC?
  6. Belt Alignment tips
  7. SC Install...day 1
  8. got a problem...
  9. Venom-400
  10. spark plugs?
  11. Urgent help!!!!!
  12. My BOV sounds funny
  13. Stripped the threading into the SC....am I screwed?
  14. Post part numbers to the supercharger want to post a sticky etc..
  15. Lightweight Fly vs Lighweight Pully
  16. Is there any special tools i need for the install
  17. sneek peak
  18. Problems with AFC1
  19. I am buying the stillen kit what else do I need?
  20. Correct Hex bits for SC
  21. Car not boosting at all???
  22. T03/04 spool?
  23. Is There Such Thing As...
  24. Anyone using a Vortech S-FMU?
  25. all boosted max's... question for ya....
  26. Gaping of spark plugs
  27. What is the best Sounding Blow off Valve?
  28. 99 VS 95-98 SC mounting bracket differences...
  29. PS line install (for SC)
  30. Max boost for stock injectors of a 4th gen???
  31. Car is not running...HELP!
  32. anyone interested in a sard bov??? i am looking for an hks ssq
  33. custom turbo
  34. How essential is dyno tuning?
  35. Should I change FMU Disc from 8:1 to 6:1 I'm Running Rich??
  36. changing fuel pump
  37. Did Stillen crush bend this?
  38. A few pics
  39. Just installed Fuel Pressure Gauge. Kinda off?
  40. Why an SC and not a turbo
  41. pricing on fmu disc...
  42. Is there an upgrade for the Oil pump or Water pump??
  43. How much HP does 1 PSI Equal???
  44. Shaving S/C mounting plate
  45. If you could reprogram the ECU on your blown VQ30....
  46. I wanna go boost? advice needed.
  47. T3/t04 Vs T04
  48. tax time
  49. What's the difference between these..
  50. I dynoed yesterday
  51. SC Pre-Install Install questions
  52. finally got around to mounting the guages
  53. Adjustable fpr question
  54. Experience with Kev's car :eek:
  55. Looking for SC piping "elbow"
  56. Question about SC'ing (I know nothing)
  57. I am in the boosted crowd
  58. what parts of the engine differ the vq30de-d and the vq30de-t????
  59. Car dynoed/tuned at 5psi with t3/t4b Turbo
  60. does anyone know the compression ratio of the vq30de-t from japan???
  61. SC efficiency advice...
  62. bov question
  63. 3.125 pulley questions
  64. Is this safe? I need to cut some costs :(
  65. Turbo owners, need help, increased boost to 10psi now having problems....
  66. OK, stupid question...
  67. First shredded belt, Not even 3 months of use!!!!
  68. What If your AFC isn't set at 40 and 39 percent?
  69. ACT Clutch ???
  70. Installed CAI last night
  71. I have been running super LEAN all the time. Need advice~
  72. Who else has killed their tranny
  73. New Brand SuperC ?
  74. How Can A Turbo Shatter?
  75. boost guage fs
  76. stock or aftermarket cams...help me decide
  77. New SuperC Kit??
  78. Do I really need big brakes?
  79. How many dyno runs does it take
  80. ecu upgrade?
  81. Turbo Creep?
  82. Part number of K&N
  83. quick question 'bout fuel pump...
  84. do i need a y-pipe?
  85. Free turbo?
  86. Question about SC
  87. turbo auto, SC auto, convert
  88. Dyno result = very lean mixture....Help!
  89. SUPERCHARGER price reduced. (click)
  90. Boost guage?
  91. Exedy clutch
  92. 103k on original motor and i have s/c recomendations.
  93. What are the pre-dyno settings for the S-AFC2?
  94. new gauges are here <pic>
  95. Turbo when is he takin orders
  96. FMU Disc question
  97. Finally got my new toy!
  98. Can air temp sensor affect your boost?
  99. SC auto vs. TC auto....which pulls harder?
  100. Where can I mount my S-AFC II?
  101. Turbo installation questions
  102. Who was the first org member to supercharge their Maxima?
  103. List of boosted with VIAS (MEVI)
  104. Aquick injector question.....
  105. Garret ball bearing T30 turbo??
  106. intercooler core design question
  107. 9psi, 3rd gear, but didnt feel like she was pulling???
  108. Correct NGK copper plug?
  109. question before getting a V2
  110. List of all boosted Maximas, did I miss anybody?
  111. SC people, will you do me a small favor?
  112. VG-T custom pipes are back finally....
  113. Other Hish Flow Injectors Besides 300ZX
  114. RECOMMENDED BOV, turbo gauges, boost controllers...
  115. Exhaust wrap, how does it continue to smell?
  116. For those planning to go FI, i've got some gauges
  117. T40E, T40B, 60-1, or some hybrid
  118. turbo size???
  119. SC sounds like a can full of nuts & bolts
  120. EGT probe, where
  121. 500 hp = blown block
  122. Important Question
  123. custom turbo
  124. oil return line
  125. Say your belt shredded in the middle of a desert
  126. SC: Cold Air Intake, or Functional Hood?
  127. Fuel Injector - facts thread
  128. the almighty tiny 2.87 is back to her daddy!
  129. Am I running lean?
  130. Boost pressure, why only when in gear? Wht not in Neutral?
  131. 2.87"/2.62" pulley checklist
  132. How long have you been boosted?
  133. Belt jumped!
  134. Mmmm just touched my S-AFC2!
  135. Turbo Kits and ATB Diffs
  136. Variable intake and Turbo/Supercharger
  137. More boost news with leak fixed
  138. turbo manifold/s
  139. Yearbook for boosted Maximas??
  140. in need of a Turbo mentor
  141. Keving & Lag... go hand in hand ... ?
  142. 2k-2k1 5spd complete Turbo Bolt on system vendors?
  143. custom turbo?
  144. Intercooler vs No Intercooler
  145. Group Deal for 300 ZX injectors anyone??
  146. NEW VIDEO: HLH0501 Turbo Compilation II
  147. Turbo Maxima -vs- Active Turbo BMW
  148. Apexi S-AFC setup
  149. Where to put the MAF sensor on boosted car?
  150. PFI Automatic KIT is Finished
  151. Valve cover vent?
  152. Hideous phum syndrome
  153. prep for turbo
  154. What are the options for fine tuning the AFR?
  155. Greddy Engine management system???
  156. 2k Max (Auto) and Turbo
  157. I'm finally boosted
  158. oh dear cf hood / SC found a slight problem....
  159. DOH! I am a retard
  160. How do I adjust my HKS SSQV??
  161. (Autometer) Boost Guage Mounting Location
  162. Ordering ASP pullies...
  163. Maps / Cfm
  164. Ordering a new V2 on Monday (BOV or not)
  165. VG30E, is it possible to turbo?
  166. V2 In - Stock Y-pipe Sux
  167. Fuel cut on 4th gear?
  168. How to swap pulley?
  169. 6 ribs to 5 ribs....plan to go down to 2.87
  170. would anyone be interested in...
  171. Why do turbos make more hp than sc?
  172. Turbo kit question
  173. Which Turbo is best for our Maximas?
  174. Stillen Supercharger Kit-V2
  175. SE-L Special Mounting bracket?
  176. Sc + Mevi + Ecu?
  177. Intercooler or Water Injection kit?
  178. Will pressure be too high if FMU is here?
  179. I wanna buy a turbo
  180. New clutch when installing SC
  181. Installing Stillen SuperCharger on 1995 Max
  182. Installing Stillen SuperCharger on 1995 Max
  183. Blow off valve install question
  184. What's the optimal AFR?
  185. Let's talk V1 SC Torque Fellas
  186. Does anyone have a write-up for the Apexi S-AFC II Install?
  187. V2 SC install issues
  188. CAI on a SC
  189. I've decided [Supercharger Questions]
  190. BOV inquiry - Blitz Dual Drive
  191. ok I am boosting an experienced engine.
  192. Autometer boost gauge
  193. Engine life with turbocharging?
  194. What weight oil are you guys using?
  195. Interesting find on blower...
  196. Question for the Turbo guys....
  197. turbo for auto 2k2
  198. What is boost bleeder valve?
  199. healp please listen......my SC need advice
  200. What I did during the Super Bowl
  201. turbo, supercharger??
  202. Dyno (finally!)
  203. Compression test results :)
  204. So how long did your auto last?
  205. Just changed spark plugs, now I keep getting the 0115 code...
  206. There's gotta be a way to boost sooner w/o changing to a smaller pulley...Rods?
  207. Rebuild Decision Criteria
  208. Running Max during rebuild
  209. How can you tell if you were running rich or lean from looking at used spark plugs?
  210. Why does my BOV sound better facing passenger side than driverside?
  211. Walbro FP installed, have a few ?'s(long)
  212. 2000 Maxima Turbo or Supercharger
  213. Turbo piping
  214. Need Help converting my boost gague reading.
  215. Just got my intercooler in-what you think?
  216. 15psi I could not believe my eyes.
  217. My car completely died on the highway today
  218. Progress report and alternator question
  219. To NOS or not to NOS that is the question!
  220. Intercooler
  221. How to adjust alternator belt with the dam Blower in the way?
  222. Check this out
  223. ok car is broken...LONG but need HELP !?!?!?!?!?
  224. 3 options of Motors....help decide
  225. Completely lost on this fuel pressure stuff....
  226. Warning: Low Fuel Light started fading in and out, but my fuel is not low?
  227. Who has a walbro fuel pump on a 5thgen?
  228. Hobbs switch mod help
  229. Need part no. on for these two parts of SC
  230. what is everyones fuel pressure at idle
  231. Does anything else need to accompany a smaller pulley??
  232. Fuel pressure equation
  233. How reliable is a S/C Max?
  234. What are the chances of blowing my motor with the 3.33"?
  235. ASP Pulley puller?
  236. S-AFC Setting after a 5SPD conversion. Will is the be the same as when Auto?
  237. OK.. I'm lost again..
  238. turbo kit
  239. Boosting and OBD II
  240. belt size for a 3.125 SC pulley
  241. What is wrong with my SC max?...poor dyno results
  242. SC setup guage ?
  243. Final Chapter - Belt replaced, but not aligned
  244. Adjusting the idle speed
  245. Turbo Dyno......
  246. More fuel pressure than expected
  247. I Need Honest Advice On Pulley Size For V2
  248. 3.33 Pulley size "6- Rib"?
  249. Changed the nylon hose and I'm still getting 10Hgmm
  250. HELP~ the blet is running off the idler pulley~ HELP
