View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24
  1. Time for new injectors...
  2. Trust 300zx maf plug - HELP from jdm parts people
  3. Where did most of you get Your SC for the 2k???
  4. belt size?
  5. Lower Compression Engine
  6. Suggestions for wiring boost controller, turbo timer, SAFC
  7. MY Vacumn line question
  8. Turbo Preparations
  9. Which Turbo kit is better Hals kit or PFI's Kit?
  10. Vacuum Line Routing with Wastegate/Turbo/Electronic Boost Controller?
  11. Anyone heard anything about PWR barrel awics?
  12. exhaust problem when boosting?
  13. Rotten Egg Smell...
  14. volumetric efficiency estimate
  15. A Semi-Unpractical Question...
  16. Ok, Guys I am gonna sound stupid but VE30DET
  17. How do you run the lines for the Vortech FMU WITH a SARD FPR?
  18. Maf's and other car
  19. How many of you guys run the stock fpr with Walbro?
  20. turbo 3rd gen
  21. To Charge or not????/
  22. To clear up the MAFS placement issue..
  23. Redmax Engine Blown!!!!
  24. Turbo installation
  25. What adaptor do I need to hook my AEM FPR to my fuel rail?
  26. Questions about Supercharging
  27. Which turbo kit?
  28. Who is using an oil restrictor?
  29. My EGT gauge bobs with my music!! Help...
  30. update on my project
  31. Tial Wastegate
  32. i swear im dumb---need help with turbo kit info
  33. injectors
  34. Supercharger N00b Question
  35. How can I lower my FP with the Walbro and Cartech?
  36. Air/fuel curve..
  37. Q for high torque boosted ppl
  38. HEADS UP: UR SC Pulley is now available!
  39. intercooler goes woo woo...
  40. Oil Return Lines for Turbos
  41. I'm thinking about getting a later model 4th gen and transfering what I can...
  42. Anyone with a Z-32 MAFS?
  43. BOV discovery (a tad long)
  44. Fitting turbo kit into early 5th gen
  45. supercharger V2 for sale
  46. where is the instructions on how to install the walbro pump???
  47. Pating Out SC Parts.. Here's some deals for you boost whores :)
  48. is a Apex-i AFC II worth it
  49. New custom turbo design.
  50. supercharger intercooler?
  51. what electronics are needed for turbo? :)
  52. Exhaust size questions
  53. Where to get a used SC for a 2k???
  54. Anyone regret getting boosted?
  55. Can someone explain how our "stock" bosch bypass valves work?
  56. day & night boosting diffrents?
  57. Where o where to mount the MAF on a boosted car??
  58. Oil coming from crankcase vent?!!!?
  59. New mod/ replacement
  60. *I THINK* I found the cause of my high EGT at partial throttle
  61. What is safc telling me in regards to air flow?
  62. is it possible to s/c a 2k2?
  63. oh my god!!!!!
  64. aux. fuel pump question?
  65. Stillen Exhaust vs 5th Gen
  66. At what boost pressure do you have to start worrying about the head gasket?
  67. upgrade time....
  68. FMU Question
  69. Insurance Rates
  70. Turning up the boost!! need help.
  71. Fuel Worries
  72. standalone fuel management
  73. Taking out S/C
  74. Turbocharger Question
  75. stock pulley!
  76. Oil Qs
  77. My changing role
  78. fuel setup
  79. sc guys plz help!!!
  80. engine still stalling!?
  81. BOV - it did not fire @ 10psi?
  82. Vortech FMU disk change
  83. Installing Electronic Boost Controller WITH Wastegate Questions
  84. Manual Boost Controller question
  85. engine stalling problem w/sc?
  86. Question about boosting turbo and SC
  87. SC CAI question
  88. Turbo being installed
  89. just got my newest mod, actually 22 of them
  90. a/f guage how accurate is yours?
  91. Poll..... Upgraded ECU or SAFC??
  92. What's the "Stock" SC FMU disc?
  93. Do I need to grind the plate for a 3.33" pully?
  94. Compressor Maps
  95. Turbo Help and questions
  96. smaller pulley or 7000 rpm redline
  97. Supercharger + Engine swap question
  98. Supercharger Pully Bolt part number
  99. V2 s/c air filter replacement?
  100. what does ur boost gauge read when cruising?
  101. Anyone boosted with a high knock count?
  102. Which Piggy back???
  103. Anybody have experience with the Vortech Super FMU
  104. sx7r Need your opinion on these
  105. 300z TT Injectors
  106. Compression Test
  107. passenger window..and blinking airbag light
  108. Turbo and UDP
  109. Thinking about fuel delivery.. opinons wanted
  110. Stock internals how much boost?
  111. where to install superchargers in San Antonio/Austin area?
  112. Crap, It's time for smog!
  113. Gutted Random CAT
  114. Dyno/FMU Problems PLEASE HELP
  115. SAFC Settings / Functions
  116. buying parts from Stillen for a 2nd hand S/C, any problems from stillen?
  117. Tuning/timing retard stuff..
  118. Do you think that boosting an 100K car is good?
  119. 80 psi fuel pressure...at idle!
  120. Lower compression pistions
  121. when do you see peak boost?
  122. Oxygen Sensor Voltage Readings
  123. Freaking Oil Leak!
  124. Who sells turbo kits for our cars?
  125. Simple Turbo Question
  126. auto S/C question
  127. DSM T25 Turbo
  128. sc cai piping?
  129. Starting my own turbo project
  130. bigger injectors
  131. Blown Engines
  132. Installed the Dayco Poly Cog Belt
  133. Surface Fatigue on Idler Pulley
  134. Don't you hate screwing in Bolts #14 & 15?
  135. Turbo Maximas: have ANY of you gone to the track yet?
  136. auto or manual conversion?
  137. Ok.. I am going to an 8:1 fmu
  138. DYnoed today - interesting results.
  139. is there a fi 02 or 03 car out there?
  140. OK - I need ideas
  141. Backfire at mid RPM
  142. new supercharger
  143. ok guys... what's next? (SC question)
  144. WTB- 3.125" Pulley!!!
  145. Anybody have a 3" pulley they want to sell?
  146. Abslote Pressure Sensor?
  147. Turbo question
  148. Question for turbomax's
  149. FMU Disc with 3.33" pully
  150. need help with supercharger
  151. Can I SuperCharge a 1999 Maxima
  152. If you want a cheap manual boost controller .. here you go
  153. My Blow Off Valve Stopped Functioning
  154. 3 Questions
  155. Turbo boost bleds down the closer I get to redline
  156. True or false: 370cc injectors can be used with unmodified ECU
  157. Turbo Maxima on LI NY?
  158. sc guys need your help!!!asap
  159. questions about S/C kit
  160. for does who have put a turbo in their max
  161. Take me off the SC list
  162. A question about SC and auto tranny's
  163. Shop to install SC in CT/NY area?
  164. Questions for SC Masters????
  165. Made a change to car...seems safe enuff
  166. &$%&# Clutch!!!
  167. need help. still stumbling.
  168. how fast should i be?
  169. Manual Boost controller or New wastegate spring?
  170. Turbo question
  171. Can I get some help? (ATTN: turbo97se)
  172. My newest addition
  173. Diff between 97-98 and 99 supercharger kits?
  174. used SCs
  175. do Boosted auto magics trannys last?
  176. For those that have not seen my turbo kit!!!!
  177. I need help with alo tof vacuum lines.
  178. FPR question
  179. wtb used supercharger
  180. Couple Turbo questions...
  181. Wtb: Fpr
  182. V1 or V2 supa
  183. turbo
  184. question about fmu
  185. More fuel woes
  186. S/C the max again?
  187. Twin Pipes into turbo.
  188. Power Yields for 60-1
  189. How long a NEW engine before...
  190. Start up problem
  191. Toluene...
  192. RT Cat concern
  193. Code 0803 manifold absolute press sensor...
  194. 0707 Code and it's relation to boost
  195. Need help identifying SC parts
  196. MAF sensor placement when boosted
  197. Another oh ****.
  198. What's the size of the belt and stander pulley for SC?
  199. Just uploaded new pics
  200. VERY rough idle upon start up???
  201. To those with turbo's what rpm do you see the boost start??
  202. for charged and turbo'd max's
  203. Blower Question
  204. Lag under partial throttle
  205. 3'' exhaust
  206. Would you switch from a s/c to a turbo?
  207. Time for me to replace the drive belt again?
  208. coolant lines for turbo
  209. Belt snapped and bolts stuck
  210. SC guys (mainly V1): More power and an Eaton roots sound...belts DO make a difference
  211. Gates or Gatorback - where to buy?
  212. Turbo Reliability
  213. Who is that sells just the MAF
  214. compression test and running lean
  215. Supercharger Or Nitrous?
  216. Question About EGT Reading. It's Too Low!
  217. Need Quick Help!: Belt Size to run with 3.125" pulley??
  218. launch w/ s/c
  219. Another Turbo???
  220. how much power?
  221. I Really Really Want A Turbo!!!now!!!
  222. Autometer Bulb Change ...
  223. Sound Clip of Blizt BOV?
  224. what the hell
  225. I need some faith from the gurus
  226. Results of my compession test :)
  227. Turbo in my Maxima
  228. vq35 supercharger
  229. Will a company like greddy produce 5thgen turbo kit??
  230. ? about S-AFC2 knocking sensor
  231. Jwt Ecu Sc Program?
  232. True power of a SuperC ?
  233. where do you guys usually put the egt probe???
  234. smaller sc pulley?
  235. Blow Off Valve?
  236. For those of you thinking about being boosted...
  237. Switching to 3.125" Pulley
  238. For thoes of you just getting started....
  239. My dyno graph
  240. Replacement stock V2 intake..
  241. Turbo kit suggestions
  242. Porting headers...
  243. High EGT = no race against a Prosche Boxter
  244. SAFC question
  245. do miles matter (for motor building purposes)?
  246. Used Supercharger
  247. Fuel Issue
  248. FMU and fuel info needed please
  249. Fuel Pressure Gauge
  250. my car pulls stronger @ 3/4 throttle than full throttle at 4th gear.
