View Full Version : Supercharged/Turbocharged
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24
  1. Went lean at high rpm
  2. Finally!
  3. Will Stillen sell us S/C misc...
  4. Can you Clear it up???
  5. cylinder heads
  6. Ordered my pistons yesterday!
  7. Clutch sticks
  8. Upgrade fuel injectors?
  9. supercharge automatic Maxima?
  10. Got a Link?
  11. VQ35DE Twin Turbo Kit *Videos*
  12. Where to buy 370's, MAF ??
  13. Linuxr Bad Clutch vrs a Subaru WRX
  14. Which model Cartech FMU?
  15. Issue with Fuel Pressure, keeps changing at idle....
  16. advice needed: Lowest boost S/C on stock auto; is it safe?
  17. coolant question for Garret GT series turbos
  18. Video: Jay vs. NSX and bags part II
  19. ? on SARD FPR
  20. Video: Bags turbo @ 8PSI vs SCed Sleepy @ 8PSI
  21. Help, Gas attedant put 87 octane in my supercharged max!!!
  22. Best Exhaust for S/C ??
  23. FMU Question
  24. my new throttle body
  25. Air to Air-We'll see Soon!
  26. Turbo Auto
  27. T25 turbo too small??
  28. Turbo question...
  29. New to Boost!
  30. need help in gapping plugs
  31. S/C Fuel Delivery
  32. SAFC2 KS monitor
  33. Nismo FPR
  34. I need everyone's advice! Turboing this Mofo
  35. Need T adaptor for S/c
  36. Greddy E-manage, boost controller and more!
  37. S/C sound
  38. jet vforce power control module good/bad?
  39. Does anyone have a dyno plot I can look at for turbo with 7000rpm limit and MEVI
  40. If you had an N/A JWT ECU would you keep it to modify to FI specs later or just sell
  41. Help me figure this out...
  42. Red top injectors
  43. question about changing pulley for more boost
  44. Want to put intercooler on supercharged 01'
  45. 370cc or??????
  46. SC + dry N20 setup questions
  47. fpr, fmu and walbro
  48. welding tips
  49. Speed Shop/s in Las Vegas
  50. I would like to give props to all turbo/sc max's
  51. Price for VERY slight used T3/T04E PFI kit?
  52. Just ordered my new turbo T04R
  53. 14.7psi 96%DC 4.67v@MAF 7krpm and third gear has enough!
  54. How many miles is too many?
  55. Can you SC with stock exhaust?
  56. How do you define knock count?
  57. Wideband O2 or EGT
  58. 12.9psi, 4.62v@MAF, 82%DC, 7100rpm
  59. Sx7r Fuel rail off-fitting
  60. Can I still get decent gas mileage?
  61. Redmax Destroyed
  62. New Turbo for vq35de
  63. Vortech MaxFlow Power Cooler
  64. vq30de specs
  65. Looking for 4th Gen Turbo Project
  66. Start / Idle Problem
  67. To turbo or not to turbo?
  68. Opinions on turbine/compressor
  69. Project update
  70. Quality Turbo Kit Interest?
  71. Which exh. is better?
  72. Selling V2 w/ 3.125 blower only, must go
  73. Anyone looking for a set of 370cc Injectors?
  74. 8 VIDEOS 9.7PSI turbo max vs 10 sec 03 cobra, SC IS300,15PSI 300TT, Bags vs SC IS300
  75. Installed WSP's 3" exhaust
  76. turbo install in los angeles area?
  77. Any 01 Turbos out there?
  78. Possible Problem with New Engine......
  79. Got the new bracket, the drama continues
  80. oil return for turbos
  81. lookin for a BOV
  82. Cartech FMU or Walbro?
  83. T4/TO4R for 3.3L ...
  84. What ever happened to...
  85. Is This Possible?
  86. See anything worng with this turbo?
  87. Out with the OLD... IN with with NEW
  88. Turbo Kit for $3,400
  89. Does anyone know this guy?
  90. More FAQ type stuff...
  91. Please Explain This One??
  92. External wastegate w/o the nipple on turbo?
  93. Daily Driver, or not?
  94. need help bad! loooong
  95. Turbo sizing for automatic trannies..any different?
  96. GSS342 Installed!
  97. Smell Fuel on Start up
  98. ??? for turbocharged
  99. Bags VS Modded EVO.....
  100. E-manage help...
  101. Help! AEM Adj FPR install
  102. Cost > value ??
  103. Looking for another turbo, have question
  104. Anyone had low vacum readings?
  105. T4/T04B Turbo Shopping.....
  106. Is there a MAX meet on 03/07 in Maryland??
  107. What trim turbo is everyone running?
  108. What is the difference in a Turbine A/R .83 and .63?
  109. Want to supercharge my 93
  110. Aquamist Power Gain
  111. Think I found my leak
  112. problems with turbo kit
  113. Supercharger facts. directions, part numbers, belts etcc
  114. Lets start a Turbo FACTS ONLY right now! POST AWAY
  115. Thinkin about turbo.. need some insight
  116. 1 step or 2?
  117. Aquamist before or after the SC??
  118. Boost with lightened Flywheel ??
  119. what sparkplug is the best for turbo max
  120. VQ35 for $500
  121. Blitz BOV owners, I have the filter on my BOV, would you sell your little metal horn
  122. Possibly Buying a V1...
  123. LeBaron turbo on a Maxima??
  124. How many miles when Boost Began ??
  125. OBD 2 Scanners
  126. Sound clip of V2 ??
  127. New for 4th gen?
  128. Belt Shredded! FCUK!
  129. Look what arrived at my house for my project....
  130. Clutch...ACT ??
  131. 2nd Gen Turbo
  132. AWAC ?'s
  133. VI with S/C
  134. turbo questions
  135. Comprehensive dyno comparisons
  136. Anybody have an extra Manual boost controller laying around?
  137. what kind of clutch is FI people running??
  138. How to hook up the turbo timer. The two main ignition wires to look for, read inside
  139. turbo question
  140. to the supercharged: i need your help
  141. Zemulator
  142. Is it fair to say each drop in pulley size = 10HP?
  143. Timing retard?
  144. Extreme Kit for maxima?
  145. 3 inch SS Resonators
  146. intercooling help?
  147. Anybody boosted on State Farm Insurance?
  148. R32 Intercooler?
  149. how much can a stock motor put up with?????
  150. Emanage ignition tuning...any input is appreciated
  151. Turbo Setup Questions
  152. Useful links
  153. Are JWT cams ok for forced induction?
  154. OIL return problem.
  155. Useful web calculators for FI guys
  156. 89 air flow meter cfm rating???
  157. Fuel pressure: OEM FPR vs OEM FPR + 4:1/6:1/8:1 FMU ratio
  158. New Turbo Kit
  159. I just had an intersting discussion...
  160. SAFC settings for A32 ecu, Z32 maf, 370 cc/min injectors
  161. The Uncorrected DYNO numbers ARE HIGHER!!!!
  162. Differences between V1 and V2 mounting plate.
  163. ?s about uping boost and hp on v1
  164. Tomei Z32 plug/pigtail?
  165. Boost or not to boost that is the question
  166. PICs of Auto anyone
  167. Misc Turbo parts. Where do you guys buy?
  168. vortechs phone number
  169. anybody have an auto with a 3 " downpipe?
  170. 30.5x8x3 SPEARCO intercooler -CORRECT SIZE??
  171. Blitz Super Sound BOV : Any Good
  172. Congrats to Bags and Ramius on very impressive numbers
  173. V1 or V2?
  174. supercharger question
  175. 3" Exhaust installed.
  176. ????big brakes guys??
  177. Greddy ignition Harness, Code 0201 Quick help please
  178. Turbo timer Turbo Boost and blow offvalve?? take a loook thanks
  179. Thinking of SC'ing, or geting a turbo for my Maxima
  180. slicks and rims
  181. build kit?
  182. safc sensor type setting???
  183. Fuel Hose Help
  184. 5psi never felt so good
  185. problems with my max
  186. Turbo intercooler Size??
  187. GSS342 Walbro in-tank fuel pump works for VQ35s?
  188. Does anyone have a recommendation for a replacement idler pulley ?
  189. Fuel system, ECU, ignition timing, what is everyone running?
  190. turbo question
  191. Which spark plugs to use?
  192. HomeMade Turbo ....an option
  193. I've sprouted another gauge
  194. Is buying a used SC worth it?
  195. gator Belt 2.87
  196. Fuel Pump Walbro
  197. 7th Injector?
  198. Maximum Tuning Valvebody
  199. aerobearing turbos
  200. what do these symbols mean
  201. for all turbo guys help choosing thr right one
  202. bov and wastegates
  203. Sorry common newbie question
  204. SH*T, I think there is water in my motor oil...
  205. You guys see any problem with...
  206. turbo prep question
  207. is this a good turbo???
  208. Turbokits.com?
  209. Insurance Covering car with a Turbo?
  210. can you use a udp with a s/c?
  211. 5th gen injector options including VQ35s
  212. Need your help guys
  213. Greddy eManage installed, finally works! Pics
  214. water injection, lowered compression, bore
  215. Hey guys! Just dropping in.
  216. 555 injectors
  217. Any1 selling there supercharger?
  218. Supercharger worth the money?
  219. Compression Tested!
  220. What kind of times are you getting with turbo / SC?
  221. Need help taking the S?C off
  222. custommaxima tubo kit
  223. Does the CAI drop temperature w/V1 or V2? took some readings using OBD-II read on
  224. i made my own turbo kit, HOW DO I INSTALL?
  225. Engine Internals?
  226. Intercooled S/C setup
  227. Vortech Supercharger Install????
  228. She's up and running good !!!!!!!!!!!!!
  229. which company to go to for ECU
  230. Goodyear gatorbelt number
  231. Stock CR VQ.......Aquamist WI and J&S
  232. Tell of your most exhilarating boost moment
  233. problem with 93 max turbo
  234. trubo project pictures
  235. fuel pump: necesary?
  236. FYI: boost Conversions
  237. Finally got this damn AVC-R to work!!!
  238. Hit 7PSI on stock 3.60 SCer pulley/Pancake filter
  239. Supercharge? Or go with Eclipse GSX?
  240. DSM fuel rail conversion
  241. Higher Octane on turbo?
  242. turbo and intake question
  243. poll: who runs slicks
  244. spotted turbo max in the making
  245. what do you think of my turbo?
  246. First MIL!!
  247. 5th gen V2 in my 95 max, late night pictures
  248. I Cant Believe I'm Back On The Road
  249. Spill the beans
  250. Englishtown
