- looks familiar. somebody might need it
- Leaky Blower
- Looking to add S/C with out changing parts
- leanest and richest cylinder
- HKS SSQ BOV with chrome pipe
- E-manage Or.....?
- FS Nissan 370cc injectors
- when is the v2 supposed to reach full boost?
- Thinking about getting CAM Springs w/ no cams so i can raise the rev limiter more.
- Looking to find Gatorback or dayco Poly-Cog belt for 2.87 V2 supercharger on 98 max
- Okay just about ready for the installation of this 2.87 Supercharger V2 Look inside
- Adjusting the Cartech fmu
- Compressor Surge???
- Times and power
- *TURBO* CarDomain *PICS* *WHEELS*
- Preparing for Boost?
- Nissan ECU Info
- E-manage 101
- STOCK CLUTCH w/ 9lbs of Boost
- Supercharger Installation Instructions
- xterra supercharger
- set of 350z injectors for sale.
- fa: garrett turbo a/r .60
- Custom supercharger?
- which Walbro 255 will fit my car?
- Z32 MAF?? Do I get it?
- 370s and Z32 MAF sale
- What to Look for in a Wideband 02 System?
- walbro gss342???
- Spec Stage 2 Clutch
- Charge pipe coatings
- Anybody with a welder want to help me with something?
- Oil Residue Under Blower
- FMU Replaces stock FPR?
- BTM Neded???
- IS this everything i would need for E-Manage?
- Las Vegas Speed Shop???
- Stillen Part Question
- Did i buy the correct ECU for my car to be modified by jim wolf? I have a 1998 SE, MT
- A little help if possible please: trying to set up the 2.87 pulley i have this
- Injector options?
- 530whp at 14psi
- Maxima Turbo Question
- S/C problems....pulley broken and belt snapped
- Why does boos tincrease in colder weather?
- boost is falling off drastictly in high rpm
- 6500+rpm on stock ecu, timing?
- v2 sc kit walbro cartech safc2 check it out
- Wana Trade.... Come on in..... I will tell you....
- Turbo - intercooler needed or not?
- oil return for turbo.
- Ordered JWT
- 3.33 Pulley with stock clutch?
- Is this a reasonable price for emanage
- Dumb Question
- Where can i find the Z32 MAF?
- What is the best adjustable FPR for boosted cars 1998
- what is the best adjustable fuel pressure regulator for boosted cars?
- is anyone selling a used sc
- 2.87 or Nitrous?
- 4th Gen Trans Vs 5th Gen
- What plugs for 98 Max. w/ blower/meth?
- Apexi SAFC2 Opinions
- f150 lightning MAF
- wtb: up pipe for turbo
- Turbo or SC max VS SRT4
- Stumble at idle ??
- turboed 4th gen.
- A32 ECU+Z32 MAF+500cc+adjustable FPR?
- 300zx injector ?
- 3" Question
- Turbo Kits
- got bored, went to track
- Fuel press. question
- Bolt Holding 3.33" Pulley is STUCK!!!!
- whats the best sc setup ?
- 4th gen sc?
- Question about FP for SC Guys
- Where to get exhaust manifold flanges?
- Dynoed today
- EGT Temps ?
- FS: 2.87 Pulley and Belt
- cartech manual
- catech adjustment question.
- Where did you get your turbo manifold?
- 2.87 to 3.125 brackets shaved need help
- Bad Track night
- Someone jump on this...Nismo 555cc $600
- tilting the motor when sc'ing????
- 99 max ..wat route should i go?
- FMIC Piping
- fuel pressure Nightmare!!!!
- New PLX WB02 AFR gauge...looks like AEM~!!
- dum questions, please dont be a jacka$$
- walbro fuel pump
- Intake filter
- Has anyone tried secondary fuel injectors?
- Transmission Upgrades
- 370's or 550's ??
- PLMS datalogging
- What af do you idle + cruise at?
- wtb cartech fmu walbro 255 fuel pump
- 0-80mph performance; supercharge or turbocharge?
- Need some expert help
- Walbro O-Ring
- need some help with a map
- what to get Safc2 or Vafc2
- Tach Stopped Workin
- wtb 370c injectors walbro 255, fpr and a safc2
- Selling Greddy E-01
- just got sc need help
- Tuning ??
- Any 1 know what size the fmu inlet is? 1/4NPT?
- Where do you get your boost reference from
- Has anyone considered a 7th/8th injector?
- What do you guys think about this exhaust product..
- Anyone using wide band O2 monitor?
- I need a favor.... checking the ground on the coil packs...
- Do I need more to Tune with ??
- Lame question. Garrett T3 GT fitting?
- SARD FPR installed, idle issues
- Safe pulley size?
- Redid my SAFC2 wiring and now the car is acting crazy
- Apexi BOV
- Pro S/C install on the east coast.
- CARTECH FMU Install?
- S/C Oil ??
- Where is your EGT probe?
- 99 stillen supercharger
- Z32 MAF ?? Final Verdict
- pics
- Walbro Install
- How to wire up the Z32 MAF
- need Heeeeeeeeeellllllllppppp
- When do we enter open loop?
- Running SUPER RICH ??
- How to wire up a shift light?
- FS:370 injectors
- Charged MAF
- Fuel injector colors
- Any dyno's of stock vs. Pathfinder TB?
- Turbo Ve finally Dynoed..pic inside...
- Stock Fuel Pump..
- 370's Question ??
- Anyone have a 3.25 SC pulley for sale?
- E-manage melts coil packs?
- 370's Question ?
- Opinions on the ACT extreme clutch?
- Question on 555 injectors?
- ECU Pinout - speed sensor?
- Those turbo'd w/emanage
- Quick question about MAP sensor and boost
- FMU Question!
- Time for raxles?
- got on the dyno
- Has anyone else seen this?
- getting money...advice for turbo and etc.
- 740s are in
- Bov Flange Help!
- MEVI.. I'm sick of backfires.
- OEM nissan rods pistons, and crank.
- Cartech FMU issues....Help Stephen Max!
- cheapest sc/turbo?
- cheap supercharger from fronteir on vq30de???
- Those with the Z32 MAF.. what airflow do you see????
- Anyone else seen this webpage? VG30ET compressor maps and tables
- How do I know the trim of my compressor wheel?
- Fuel Pressure Problem Part 3
- Calling on people that ahd auto to manual swaps done
- Car running lean as ****.
- 1+1+10+1=??????
- supercharge & turbo pic
- Where do you get couplers??
- Equal length headers
- EIP fuel pressure regulator vs Vortech Super FMU
- supercharger
- Other good technical turbo forums?
- Anyone have a V2 Supercharger Kit at a good deal?
- Z32 MAF size vs A32 MAF
- Blow-off valve for superchargers
- Clutchnet Cluth Questions
- Opinions wanted on my new SC set up
- ecu injector pins?
- Leaking off max boost with BOV for smaller pulley?
- How much would it cost to get boosted including lsd....
- Best Price on BOV's Online...
- Want to put HKS blowoff valve on my v2 supercharger, what size mounting flanges need
- Did you install your own turbo kit?
- Hals Done!
- Alcohol injection
- Tial 35mm vs 38mm wastegate. Interchangeable?
- do they have a tc or sc for 03 max
- chopping and cutting
- Transmission problems HELP!!
- Want to feel boost in my A32 E-spec Max
- little help needed
- Building&Tuning High-Performance EFI book?
- Blitz RVIT w/SBC-iD...speed based boost?
- supercharger weight
- Looking to buy SC/Turbo Kit
- 555cc injectors on ebay
- What's the largest intercooler that can fit under the bumper support
- 3" exhaust inlet with dual tip?
- Greddy E-manage or upgrade ECU
- Will this BOV work w/ V2?
- What is this???
- emanage VTEC output - for MEVI?
- What is MISSING from this SC kit?
- Shaking her down...
- Whats your Vaccum Setup ??
- Boosted 89 Maxima help?
- Jgtc Vq30dett 350z
- Need FPR for my car, where can I find one???
- Let the donkey-pumping commence!
- has any one attemted this?
- Cartech FMU and SAFC2?
- Got a few new toys!
- compression on my motor
- Supercharging Guys PLEASE LOOK
- What gauge is more important ?
- Who's got an Oil Catch Can?
- Atmospheric BOV vs recirc
- boosted guys with battery relocated
- Z32 MAF messing with your timing?
- Boost activated "Virtual Exhaust System"
- Lets send some "car" magazines to JAY25
- The cost of FI
- NA vs FI
- Fuel Pressure Problem Part 2 ??
- How much do pfi kits go for these days??
- JWT ECU Data Logged AFR!
- master power t4 gt45 1.05 a/r
- Turning up the boost
- Round #2
- Wastegate/ PFI kit question
- 5 Speed Tranny For Sale
- Where to mount the EGT sensor
- SC/Turbo Max Poll
- HELP! have 3.125 pulley on s/c but only running 5psi, why???
- Thinking about running a 2.87 pully on my charger WHAT DO I NEED?
- Boost gauge options?
- Exhaust cut-out questions?
- Fuel management with the Stillen Supercharger kit and Turbo's
- safc 2???
- Apexi Gauges & Blow Off Valve
- sc price question
- What do you guys think about this wbo2?
- Autometer Cobalt Series Gauges
- Blow off valve for Stillen SC
