- alignment poblem on stillen s/c also cobra vs. max!
- BOV and crankcase connected back to air filter vs. atmosphere??
- V2 Belt Problem Solved???
- Swapping in new motor and LSD AE trans, have I covered all the bases?
- I'm ready to ditch the Blitz SBC-ID
- Need Help! Car bucks and stumbles while driving...
- unorthodox SC pulley with a stillen s/c???
- Do I really need a resonator?
- V1 Plate, on 00'-01' Engine
- Oil feed and retun lines.
- Maf location question (pics)
- Part Numbers for bolts.
- Different turbos
- Technosqaure ECU S/C Program!
- RPM reading too high on emanage/PRofec E-01 ?
- BOV + auto?
- F/I Engine Displacement options
- Gasket
- Cost for a Tune at Jeff's - (approximately)
- More toys on the way!
- Dyno Results/emanage Question?
- 370cc injectors ?
- Complete Turbo Kit
- i have to share the news!!
- WTB: 3" Race pipe
- Emanage Clamp
- SC differences?
- '99 chassis with '98 engine?
- Does this mounting plate look normal? Pictures
- I need to know something.
- hks twin power dli
- Where to mount Wideband o2 bung? Front bank, rear bank?
- Dyno Results
- Complete Fuel System Question
- Need a contact for a shot peen shop
- lookin 4 sc in los angeles area
- HELP!!! Need Emanage tuner in ATL
- turbo exhaust
- dont know which turbo
- Vortech Charge Cooler ??
- Why is everybody selling their sc kits?
- z32 maf question
- If you could do it all over...
- question bout exhaust and SC
- Intercooler Dimensions
- Lamda readings
- new car
- Turbo 3rd gen, Need help please!
- FS: Stillen V2 superchager - 5th gen
- Does anyone have a boosted car w/ a 6spd?
- oil pressure problem
- Did my first dyno ever at Stillin day last weekend...
- T4 With A 1.15 A/r?
- 3" Ypipe
- GT30R and watercooling??
- Maxima Turbo Kit CAD files?
- Question on fuel management
- FS: 90 degree mandrel bend.
- FS:Stage 3 Spec Clutch.
- JWT ecu question
- supercharged w/ nitrous fuel question
- Anyone polish their blower?
- cOST OF PARTS & LABOR
- 8 to 10 psi
- Tranny Issues / Rebuild Advice
- Tranny cooler options
- <<<<New member in the boost forum
- Kit dealer list?
- Progress on the Kit (pics)
- Clutchnet problem
- just bought a V2 s/c
- Stock FPR and AFPR
- My new air /water intercooler
- Dinan bov for sale
- Cattman 3" catback exhaust...
- 3" Cattman catback exhaust - interested?
- Ignitin coils upgrade
- Any benefit to getting an 'unkinked' SC outlet elbow?
- highest fuel pressure to use with FMU?
- might be a noob question
- hey
- good idea or just an idea?
- Opened up the blower
- flywheel recommendation
- What is easier (Installation Question)
- 4th gen SC on a 3.5?
- what kind of time? for 1/4
- difference between v1 and v2
- 05 altima or maxima w3.5 supercharger kit available
- Advancing Ignition safe or not?
- Taking the blower off today - need advise
- FS: Vortech Supercharger and pulleys
- Got 2 belts for sale & 3.125 pulley (mods please don't delete)
- Cleaning intake with supercharger?
- Best place to buy a J&S Safeguard?
- Some oiling questions
- Some Pathfinder TB Questions ??
- Emanage timming maps.
- FS Stillen V1 SC kit
- Funny and Stupid SC Questions
- Whats the best filter to use with a V1?
- S/C uninstall??
- Blow Off Valve Sound Clips
- help with oil presure and oil temp gauge
- H-beam style rods strong enough for f/i application?
- If I wanted to get my blower rebuilt, call Stillen or Vortech?
- 3" charge pipe question
- MEVI installed
- How can I correct My SC Max from running rich?
- Idle Issue?
- Problem with MAP/Barometric Sensor
- belt alignment
- Since everyone is posting about trannies, i need opinions on which route to take
- Bad Luck Continues....Tranny related.
- Turbo question??
- Wow A V2 S/c For Sale $2400 Shipped
- stillen super kit?????
- need help
- Weird Idle
- Temp effect on Dyno?
- Deburring, shot-peening, and cryo treating what tranny parts?
- New 3 inch exhaust
- Columbus Ohio turbo 4th gen?
- rough idle?
- Advice on Injector Install !!
- boost eats tranny??
- Turbo coming for a 2nd gen...
- Low Boost...HELP NEEDED!!
- Question on ignition wire on ECU Help???
- s/c'ed with air/fuel prob, need some help
- FS: EGT+ FP Gauges
- Clutch is almost done-need advice.
- Boost on a daily driver??
- auto & 5spd FP
- deatchewerks 555 installed!!!
- RPM dropping issue after 1s gear
- FS: SC Parts
- supercharger maintenence?
- which pulley?
- what type of exhaust manifold do you have?
- Oxyacetylene welds
- Putting down the power
- Intake Manifold Design
- FS:2.5">>>3" silicone couplings
- '96 SC kit --> '99 Maxima, what do do about power steering cooler?
- Should I Go With This Fuel Regulator?
- O2 Clamp for "lean tip-in"
- 02 sensor info..split thread
- Autotune for eManage WB02 users..SOUNDS AWESOME
- Interested in Turboing my 93 GXE
- 90 Degree elbow "Vortech Owners"
- The effect of afr on power and other parameters
- Need some help on 3" exhaust part!!!
- need some data or info...about ecu tune (those with the JWT S/C program)
- what is the difference between 4th gen and 5th gen stillen S/C kits?
- 400cc injector install problems
- My New Toy Arrived TODAY!!!!!!!!!!!!!(pics)
- Anyone ever thought about remoted mounted turbo ?
- Interesting Find Re: Race Gas Fuel Cell
- Kenne Bell Boost-A-Spark
- My turbo install pics!!!!!!!!!
- oil pan spacer
- F/S : intercooler (This Boosted Related please )
- 00VI and 4th gen lower IM for sale
- E-Manage
- New 3" exhaust ocmponents....
- Impressions and feedback of My recent mods
- Auto's and Turbo boost..
- Wrong Gas at Mobil
- 95-01+VQ35+Pathy heads+Stillen SC
- Water/alcohol injection installed.
- Wideband O2
- 3in warpseed test pipe
- WANTED: stillen supercharger
- Anyone got tial pics install!!!
- Dumb Question
- What FMU disk?
- test drive
- VQ35 + Boost in a 4th Gen
- New track results. 106 mph traps
- Anyone have a extra 6:1 FMU disk they will part with?
- Cheap inj solution, Maybe
- Marbles-in-a-can noise is gone
- Dang dealer unplugged my fuel relay box..
- Anyone use a FMIC with inlet/outlet on same side? Spearco 2-115
- SARD R2D2 bov
- Greddy RS BOV Installed but its not working!
- No time/bad computer...
- Dyno Options
- SCC said there was an I30 at JWT with a new hybrid SC/TC setup
- Few Questions on the limits of stock parts...
- Guaging Interest
- Stock ECU, Z32 MAF, 740cc, 23psiFP...
- RT Cats suck
- 6:1 FMU disc question...
- VQ30DET intake mani., anyone got one?
- kock senor pulling time way back
- fuel system upgrade complete
- Puzzled By Wastegate
- PFI Turbo Install Diagram
- compression question?????
- What afpr's can you set base pressure as low as 24-26psi?
- Car Is Finnnaaalllly Done!!!!!!!!
- Which is better...
- Best place to buy vortech fmu?
- Fixed my boost problem
- Vortech AWAC vs air-air FMIC
- 3rd gen turbo question
- How do you datalog with a wideband that doesn't have a dedicated RPM output?
- S/C Idler and Tensioner bearing #'s
- SAFC install questions...Help
- 300zx MAF Harness
- Car is finally tuned, but is it to rich?
- GM sensor identification: 1bar vs. 2bar vs. 3bar
- Fuel Pressure question?
- Done with the valve cover oil drain
- f/s vortech 3.33 sc pulley
- Intake Heat Coating ?
- Drag Radials and 11lb rims FS
- Wrapped car out to 9k+RPM
- A lot of WHP but FWD
- Turbo
- Clocking Blower
- O2 in Cattman resonator..Use it or lose it?
- Will this work for the Outlet side ??
- what vacuum line to tap for boost gauge
- What are you guys using for timing control?
- fuel system upgrade S.O.S.
- Using e-Manage's VTEC function as an rpm switch?
- dynoed my 3rd gen turbo
- Apexi Turbo Timer Write-Up
- Options for Building a VQ30DE to Withstand Higher Boost Levels Reliably
- Another Ecu Option
- What's Up With the Zemulator for 4th Gens?
- Could this be my problem?
- What size intercooler?
- fuel lines
- ecu+mevi+555 injectors
- running 11's
- ecu install
- Test pipe and smoke
- Going to be booosted with in a year... what clutch should I get??
- Looking to speak with any Turbocharged 5th gen's
- emanage question
- installing turbo timer
- Update on the car
- exhuast(muffler) help ?
- boost and engine damage?
- 5th gen muffler beneficial on SC'ed Max?
- Got a quote for turbo piping, need your advice.
