View Full Version : Audio and Electronics
  1. 2004 3.5SE Premium bose stereo speaker sizes?
  2. Would another amp make a difference?
  3. TV Problem
  4. Sub with Bose system???
  5. system setup
  6. Need help With Alarm installlation
  7. OK done with beat setup YAY!!!!
  8. Need to know if this System sounds OK
  9. Hooking up subs in ur room??
  10. 95 Maxima Getting System
  11. inifinity kappa 62.5i
  12. Interconnects
  13. Help!!! - wiring PAC SWI
  14. Need Recommendation on speakers! MB Quart, Focal, Polk, or ???
  15. 8 gauge wire question again... plus a few others from an audio newbie
  16. having trouble with my keyless entry...
  17. How many of you have a PS One in your car due to its small size?
  18. Bose amp inputs?
  19. 2 alarm instalation questions
  20. radio question?? GROUND ISSUE !!HELP PLEASE!!
  21. Put a new head unit in and now my antenna always stays up, help!
  22. Need advise on Pioneer DEH-840MP ASAP
  23. Calculating Cubic Feet for Sub Enclosures
  24. Installed aftermarket HU and having some issues now...
  25. aftermarket speakers w/ bose worked fine?
  26. check out my new box
  27. Subs
  28. i think i blew my sub....
  29. Need recommendations on a sub.
  30. Mtx model # help
  31. Alpine Title Problem
  32. Ground locations for 3rd gen
  33. CD changer for 96 I30--options?
  34. 5 channel amp
  35. Best place to mount Tv tuner Antenna
  36. Installed neons and custom switch (pics)
  37. need a cd changer
  38. 6.5" or 6.75"?
  39. Valentine one hard-wire how to request
  40. I installed my Panasonic Sirius satellite radio. Check it out.
  41. Installed my Panasonic Sirius radio. Check it out.
  42. Subwoofer placement...back, front, up or sides
  43. 5th gen door speaker thread?
  44. radar detectors. which one should i get?
  45. custom in flush screen
  46. How do I replace a fuse?
  47. How do you insert or attach a picture to share with forum?
  48. Bose speaker blown-any direct replacements?
  49. 1995 max alarm installation help?
  50. stock speakers to aftermarket
  51. How to run wires on new install (2003 Max) ?
  52. CD Deck Installation help
  53. Bose VIN # input?
  54. Playstation II or regular dvd player?
  55. replacing stock HU requires new door speakers?
  56. SWI-X PAC for only $43, steering wheel controls
  57. Sirius install with stock non-bose head unit
  58. audio question
  59. $278 for install?
  60. Wtb Cd Player
  61. Aiight boys - help me (LED wiring)
  62. converting 9007 to 9004 headlight? possible?
  63. how much is Dynomat?
  64. Need help with XBOX installtion in my 95 MAX!!
  65. how to seal a leak????
  66. wheres the antenna wire???? HELP!!!
  67. HU Upgrade - what to do??
  68. redmax screen install... help
  69. Speakers???
  70. I have 50 free second skin peaker kits to give away as holiday gifts
  71. Question on Pager Alarms
  72. MY HOW-TO INSTALL AUDIO/VIDEO, 7” DD IN-DASH TV! W/Pics!
  73. Money is here, need advice on system
  74. 7" LCD for 1995 max ?
  75. Connecting a CD changer to Bose, Connector?
  76. 97 Bose wiring diagram?
  77. Front Door Spacers?
  78. Help me install basslink
  79. Sound dampening for CD changer in trunk?
  80. any opinions on kenwood amps?
  81. Does changing the shape of my enclosure matter if. . .
  82. Will these components fit? What speakers for rear fill?
  83. hu unit starting to die, need some ideas
  84. Bose headunit not working after negative and positive jump wires switched!
  85. 1996 GLE w/ Bose- Keep Bose fronts or replace w/ 6.75" coaxials?
  86. Is this possible?
  87. Best way to get speaker wire from interior into front doors?
  88. tinsel leads are hitting eachother...
  89. amp turns off when i play cds
  90. Jl W6ae
  91. which alarm to get?
  92. Let Me Watch Your Tv
  93. eclpise
  94. TV install power?
  95. Microvision Monitor Help, can't turn off??
  96. Amps and wattages
  97. Sirius: A Review
  98. Headrest TV
  99. Microvidion Monitor Help Needed
  100. Is there a PIE adapter connector for the Maxima?
  101. Adding passive crossovers to Stock Bose.
  102. Pioneer DEH-P4400
  103. Help Need Advise On My System!!!
  104. Door speakers
  105. TV TUNER, recommendations?
  106. Advice on retaining steering wheel controls w/ HU
  107. Got new speakers... some questions
  108. ANY1 in the NJ/NY area want to help me install 7" screen ?
  109. How many watts, be4 alternator grenades?
  110. 2way speakers for rear doors?
  111. remote start installation help
  112. Self-Install of Sirius Radio
  113. I need remote start help
  114. Want toi install new head unit in 2000 I30 with bose system
  115. Possibly selling JL/Planet Audio system
  116. Help, Car Alarm Question/keyless entry
  117. Radio turns on speakers no sound.
  118. aftermarket HU wired directly to bose speakers
  119. My Christmas Shedule Appointments
  120. MA audio
  121. PESWIX Steering control
  122. Custom Subwoofer Box for 2K Max
  123. 4th gen Bose Rear Resitance
  124. dynomatted trunk, and it still rattles bad
  125. What Exactly Do I need for my 7" screen? HELP
  126. Amp Problem
  127. Anyone using Eclipse aluminum sub(s)?
  128. HELP!! TV problems!!
  129. Mounting PS2
  130. Best sub for 1 cu. ft.?
  131. UDP and 2000 watts
  132. Where to get head unit bench tested in PA/NJ area?
  133. Lights please healp!
  134. rca cables on stock hu?
  135. recommendations on a system
  136. Remote Starter with stock keyfob?
  137. Clarion Specs on non-bose 2k3 max
  138. RockFord Amp for Infiniti Subs?
  139. Sony?
  140. Need some help
  141. Components in the $200 range and 4 channel amp
  142. How To Program Keyless Extra Remote on my 97 Maxima Se?
  143. fuse holder or circuit breaker?
  144. 0 guage under or over?
  145. how much of a spl increase...
  146. power inverter question
  147. UPDATE about FM sensitivity with Alpine HU
  148. I have a 99 SE and I want a TV. Any recommendations?
  149. Polk Amps!
  150. need help wiht amp install
  151. 5th gen with a built in 7in lcd screen?
  152. question on rca and line lvl inputs
  153. basslink review
  154. stolen faceplate from headunit
  155. Which aftermarket components for 2k2 non bose stock headunit
  156. 2k2 stock bose subwoofer in rear deck
  157. FM sensitivity with Alpine HU
  158. Power cord
  159. custom radar dectector mounts
  160. Help: Ported Box for 2 12" Kicker L7's
  161. JL Audio
  162. Wiring subs to a 2 ohm load?
  163. Pictures of Scotche vs Crutchfield kit, anyone?
  164. Just bought pioneer 3500, considering kove speakers
  165. Alarms...
  166. Advice on Free-Air Sub for 2K3 Max
  167. Opinions on Phoenix Gold amps?
  168. Extra battery in trunk // Harder on alternator or does it ease the load?
  169. Opinions wanted on 10" sub
  170. about to install Head Unit... QUESTION
  171. it is worth it?
  172. Does anyone have the Panasonic CR-SRF100 satellite radio installed?
  173. Anyone using kick panels for there componets?
  174. Anyone seen or heard these new kenwoods?
  175. Can anyone supply a pic of the back of a Bose HU?
  176. Ok, Time for Don and the Expert Audio Installers...
  177. Ported box for 12" kicker solo baric l7
  178. how are the Alpine 6.5" Type Rs? (SPR-174A)
  179. 1-Ohm configuration
  180. installing crossovers???
  181. need help installing 6.5's
  182. How to build a box(please help, its a christmas present)
  183. Best 6.5's
  184. Wiring Info. For Remote Start or Security
  185. Cutting back deck for 8" Sub
  186. Which amp best for 10' Eclipse subs?
  187. Anyone not drill to run amp power wire on a 4th gen?
  188. Power invertor questions
  189. wireing question
  190. 4th Gen Wire Codes for Alarms inside
  191. How powerful of an amp do i need (i'm an audio newbie)
  192. where can i get info on diamond hex or other 6.5" speakers?
  193. Max2K remote keyless entry spec?
  194. Quality of U.S. Acoustics?
  195. Steering Wheel Control Help
  196. How to install door speakers??
  197. How much do JL 6W0's go for?
  198. HELP- I am flaming mad!
  199. Doors Rattling
  200. Silverstar suck!!!!!! Dont buy
  201. need to buy my gf a HU... help me.
  202. how to remove dash and a pillar for tweeters???
  203. got a amp for sale
  204. For anyone looking for car video, look inside.
  205. it ok to mix different ohm subs?
  206. XM question: FM mod or cassette adapter in Maxima?
  207. Has anyone ever heard of Alumipro
  208. new speakers
  209. will the 3rd gen Bose system fit in my GXE?
  210. How hard to install alarm w/remote start?
  211. Alpine Guys (CVA-1004 or CVA-1006)???
  212. Better SIRIUS sound quality?
  213. Three 8's
  214. Arc audio/Rainbow....
  215. Front Speaker wiring on 2K Max w/Bose
  216. How do I get music videos on DVD? What does VCD mean?
  217. How durable are Viper Responder remotes?
  218. got a question?....
  219. ? for you electronic masters...(long)
  220. Have you every measured your system's db?
  221. Rear Deck Rattle Revisited
  222. 2004 Nissan Maxima Aftermarket Stereophonics
  223. ID Max Owners: do not keep anything in your trunk!
  224. good looking dash kits?...
  225. anyone have Pioneer DEH1500?
  226. adding cd changer to bose system...possible?
  227. bose removal harness?
  228. Alpine SPR-174A 6.5 coax install question
  229. Is PYLE a good company ?????
  230. Crutchfield Kit or Scosche for HU
  231. polk momo sub
  232. Rockford Fosgate HE2 sound way louder than Kicker L5's
  233. 5th gen scosche kit install help!!!!
  234. What is the best location for 2 chn. amp driving components 2k3 Max
  235. What speaker wires for Components/Basslink?
  236. Can't seem to find...
  237. differnece in antenna adaptor
  238. 12'" subs and bandpass box
  239. crossover vs ecu
  240. Good $100-$150 amp for Kappas 60.5
  241. Getting through Firewall in 2K3 Max
  242. Has anybody put an LCD screen where the factory bose radio was?
  243. Playing MP3's on an Alpine Deck
  244. Install Question/DIN Sleeve/Pocket
  245. Aux Input Adapter for Bose HU
  246. Redo of PAC Adapter
  247. PAC SWI-X Adapter Pics?
  248. 2k2 Bose users wanting to upgrade - ANSWERS WITHIN
  249. Question about stock bose HU
  250. Advice on Head Unit
