- new amp for 10" sub....advice please
- 12" IB install (plenty of pics)
- SPL peak tuning?
- Problem
- Sony Stereo problem
- Pioneer D2 Install. Where does the speed signal input connect to?
- New DVD/nav head unit
- Vid of my passenger door deadening
- amp hook up
- avic d3 install Q.
- Display mirror image on 7" screen up top with D3 or F700BT
- These should go well with my dyns :)
- Maybe Pioneer is actually trying now ...
- best double din DVD receiver - no navi.
- Sirius FM Wiring/Sound Quality Question
- problem with the HU in a 95 max
- Did some deadening and added a temporary amp.....
- $550 Avic D3 - good deal?
- Boston Acoustic ProSeries 5.4x & 4.4x
- compustar 2wfm as
- Batman(No Show),DB Drag Bass Race Show
- custom setup in a fourth gen???
- gxe trim kit
- BnR Alternators & Sarters (Ebay)
- wiring question...audio related...
- JL VS. Memphis Which should I get?
- **The Official Stereo Disguise (fake face) thread**
- Double-Din Stereo Question... JVC KWXG500
- Eclipse IPC-106 Looking for Input
- Kenwood DNX8120 Installation
- pioneer avic n1 and n2
- Reasons why BOSE sux per their website
- Can a Box with a Width of 38.5" fit in a fourth gen?
- Sirius Radio Antenna Question...
- '00 Bose sounds better than '02
- Aftermarket HU & Sub w/ Factory Speakers
- Wood vs Fiberglass
- 2004 max question
- Stop the torsion bars from rattling
- crutchfield friend referral code
- Power wire question
- So the dealer installed an alarm on top of my factory alarm? WTF
- Pioneer AVIC-Z2/Z3 Placement Questions
- Will a 99 Bose Head unit fit in my 95?
- Questions about IdqV3
- bazooka tube installation
- Nissan 2003 (5th Gen) Non-Bose System Upgrade
- Which adapter will work BETTER with the Bose?
- Infinity 1220se
- installation problem
- dynamat do i really need it
- Can My Car Survive At Least 1 Month With This Set Up?
- Some help with my system
- no sound...need help
- Charging System Questions...Help NEEDED....
- CD Issues
- Dynaudio this, Dynaudio that...who cares?
- Anyone Purchased from Ohio Generator...?
- Need help w/ negative battery terminal..Ground
- JVC KD-NX5000?
- 12" vs 15" FI Q
- Best Subwoofer for Low Power System
- Amp settings for the fronts
- Stock Non-BOSE sound system on '03 Maxima - does it have built-in crossovers?
- Anyone with a AQ2200.....
- General tweeter question..
- Wierd Stereo Bose Problem
- Help!!! Trying to get rid of Static Noise on XM install!
- Zenec amps
- thoughts on these subs (kicker comp 10's)...
- Eclipse AV8022 ?
- Eclipse AVN5500 shuffle
- Pleading for Help...
- self install or professional
- Question About Fuses...
- Sound Deadener Install in Atlanta
- Foam insulation
- HU Display Not Working
- Premier AVIC-F90BT or Eclipse 6610
- Upgrading Speakers
- AMP repair help..capacitor question for electronics peeps.
- Completely New System . . will this work?
- 350z head unit compatibility
- Happy Fathers day ...
- Speakers Dried Out?
- Opinion on Alpine Subs
- Is one 10" enough?
- newbie w/ no car audio knowledge...
- How many subs???
- New project.
- Mounting Mono Amp On Sub Box...
- What you guys think
- Need opinons on upgrade!!
- New HU
- Need help hooking up my system please. 300zx thread.
- Specific HD radio reception question
- Plz confirm: Factory battery ground cable not needed after Big 3
- Running speaker wire into the door
- 1/2 DIN Equalizers (Don, Anyone)
- Installing tweeters correctly
- Just bought two MTX Blue Thunder 1000w 12s w/ Kenwood 600w amp, boxed for $40
- Alpine Amps
- eBay tweeters
- my weekend project
- BOSE aftermarket HU Question
- speaker junkies help please
- Lanzar Amps
- Audio guru's thoughts on this amp?
- Dynaudio and TRU amps, I took a good listen
- Too sexy to resist ..
- Pioneer AVH-P4000?
- Opinion on Arc Audio
- Question about EV's
- What amp with 3 JL 10's
- Memory backup trick of HU
- Replacing Factory Stereo W/ Another Factory Stereo
- Wiring problem? Frying amps
- perfect fit sub box
- where do i hook the backup signal wire to
- Odd thump/buzz from sub woofer
- Pyle Driver amps, any good?
- Quick n00b question about 12v vs 14.4v amps
- Installed amp, Could use advice on good setup
- Eclipse AVN6620?
- Electrical Gurus, how do I size up the correct size Rheostat to lower voltage??
- Valor ITS 700w In dash 7" touchscreen
- Grounding a multi-ground terminal?
- Opinion on INFINITY REF7541A
- Amps to choose from..what ya think?
- Wtf is up with eclipse amps?
- aftermarket hu with bose system
- Adding Speakers to Bose System
- Help Jump Starting Alarm won't turn off
- Another new toy ..
- Bluetooth question
- if i bypass the bose amp......
- Yay Box dimensions
- need advise on a alpine installation
- New amp and woofer wireing
- ghetto sound deadening idea
- Anyone recommend Arc Audio FD6000 component speakers?
- In dash navi question
- Just need a lil help deciding.
- Looking for some HT stuffs ...
- Stereo Woes
- Looking for an amp
- *Can an EXPERT audio guru tell me the specs of this box??*
- ipod location
- need quick help deciding on which amp...please and thank you
- Trying To Install These Tweeters in Door Panels
- Can I wire Two 4 ohm dvc subs at 2 ohms from a mono block amp? (pic inside)
- Bose headunit question. Yes another one and of course I searched.
- Today was a sad day...
- 2v vs 4v Preamp outputs what is the difference and which is better
- need a new headunit which is better AVH-P4000DVD or DDX512
- CD7200 MakII
- Window Roll Up or Down module
- 5th gen Bose sub question
- rd audio
- Where to Wire Crossover - 2002 BOSE
- Bose amp and subs only 2 pre amp outs how do i hook it up?
- Audio Install - Recommendations
- What is a good double din in dash DVD player for $400 or under?
- Look What I Got...
- New Plan of attack - questions
- how to series wire subs??
- how do i hook an amp to a Headunit without a subwoofer (non fader) pre amp out?
- Avic-D3 Bose Wiring
- 1/0 gauge adapter
- Which Head Unit is better Clarion VRX765VD or Pioneer AVH-P4000DVD
- 2002 BOSE HU removal
- 2002 Bose Sound system
- How do you wire these damn cross-overs?!
- 8" midbasses & subs in my doors & deck (log thread)
- Slight farting noise from left midbass driver
- happy bday to me
- Painting dash kit?
- hi gays :)
- need help removing stock cd player
- Put on new wheels, subwoofer now broken
- Whats the deal with rainbows?
- Mmmm goodies ..
- Mounting 10" subs on rear panel
- AVIC-F90BT
- Just had a wicked good install done: Wanna see?
- Blew A Speaker After One Day
- Bose Amp Bypass Harness
- 4x25 enough to power front channels?
- Laying Wire For Speakers
- Speaker Wire?
- Adding Ipod/Aux input to stock 2003 maxima bose
- Prestige APS410 Alarm help
- THE orgy GD of the year !
- Battery Connections
- '63 Corvette build
- what needs to be done for rear trunk rattle 5th gen
- Keyless Entry Remote
- push button/remote start compatiblity?
- how do i take out my stupid radio
- Replacing the Front Driver Side Speaker
- where is the pink wire suppose to go? need help ASAP
- New Deck
- 8" midbasses in a 4th gen?
- Looking For Wiring Diagram...
- Wanted: OEM Bose Head Unit for 99.5 SE L
- IXOS 4Awg kit GD?
- More Rainbow SLCs?
- Head unit pre-out voltage
- Pioneer Sound Build off...
- How to connect Ipod Touch to H/U
- Anyone Mess With The Arc Audio FD Series?
- need some direction with install
- Amp Kept Shutting Off Today...
- Dyn Esotar2 has arrived !
- best buy sound systems?
- Don't know how long this will last v. Amp Kit
- Alarm (Ungo brand) Not Working - Replace Main Unit?
- punch p3
- Best 2002 Single DIN kit?? PICS??
- MDF Ring spacers...yes, please.
- I am shopping for an amp.
- Non-Maxima stereo question...
- WOOFER BOX OR TUBE ???
- IVA-W505 Compatible With 00 Maxima?
- Bettery voltage?
- 5.5 Gen High OUtPuT Alts? Ne1 Got ONe?
- 04 w/ stock bose...adding sub!
- 2004 6th Gen/ w bose..Adding a Sub!
- Where to buy MDF?
- Been a special week..halfass build log...
- Where did you guys ground your system in the trunk?
- Using HP/LP filters on amp
- No power to H/U
- Yay for Scosche. Got my D3 in.
- Dim Lights? How do I remove faceplate?
- Brainstorm: Poor aftermarket radio reception
- Safe to Give 2500watts rms to 2 RL-p15's?
- Pioneer FH-P8000BT double din size.
- Looking for alittle bit more Bass
- Eclipse time-alignment
- Bose VS...???
- 03 Max Double Din Dash Kit
- Running new speaker wires 5th/5.5 gens
- quick question
- 99 to a 94 bose wiring diagram
- Crutchfield Referral Code ($20 Off)
- Going to install viper 5900..
- microvision + ipod
- Larger or custom headrests for LCD screens...
- New HU: Bose Speakers Popping
