- Water on the driver side front
- Looking for
- Seattle Streets: 5 Sarin:0
- Did the states get a factory turbo 2nd gen?
- I know it's been asked but,...How do i check my ecu on an 88?
- tranny part number?
- NITTO NT 555s...............
- MAF Upgrade question...
- Cone filter replacing stock filter
- Final Installations.......
- Northwest Maxima Meet
- Went Profile Hunting
- Maf
- 86 keyless entry
- running trouble
- Finally!
- dash board lights
- 87 maximas with rims?
- 87 Maxima - model difference
- tranny slip
- will a 87 transmission work on a 92?
- Introducing myself
- I want more power
- 87 maxima bad egr valve?????
- H.I.D.s That is, if you really want them........
- Tricky Hood
- sunroof problem on 1st gen...
- some new parts and my max feels like new!
- Trunk pop and spring probs?
- 87 Maxima - sluggish power
- 87 Bogs At 2000-2500k
- Come in from the cold...
- Exhaust gas sensor...error code 33....
- Idle Problem(s) with my 84
- Need Center Console For 84 AT
- Nissan Bluebird SSS
- Audis, Bemmers, and Opels........Oh My!!!!
- Engine Mount
- These coming weeks
- fuel gauge problems.
- JDM intake manifold arrived
- 87 Maxima PARTING OUT
- Turbo 88 comin
- Rear oil Seal blues
- Reverse won't work - 87 5sp Maxima
- AIV Removal
- Q: Parts Catalog on CD or other available media
- Alright
- Q: Speedocable head gear (88 maxima M/T)
- Parting out my max
- Buying an '85 Maxima soon, need help!
- power transitor
- Rearview Mirror info.
- 1st gen backfires/rough when cold
- Max Won't Start
- Chassis braces/stiffening
- Transmission Swap
- 87 gxe runnin crappy-bad maf??
- Anyone with climate control...
- Finished alarm install!!
- 87 Maxima with adjustable struts are worn, what's the cheapest solution?
- Q: How do you remove the instrument panel?
- i've spotted a few 2nd gens with body kits lately...
- 81 wag. brake upgrade
- Dang it! or AHHHHH!!!
- 1st Gen Rear Windshield
- Engine Swap
- Digital Dash Dead
- cold miss
- Offset question
- Sunroof not opening
- Aiv
- my second max is R.I.P...parts any one?
- keyless entry???
- how to change what underneth your users name
- Tennessee Maxima Meet!!!
- electric door locks
- Fuel odor in car?? How to remove injectors?
- Need an A/C switch for a 2nd gen
- 88 Maxima is running like a top...FINALLY!!!
- Washer pump..
- Condensation in headlights.
- Sarin's Tip of the day
- 2 part question.
- Reverse Indiglo Gauges
- FSM/in depth help(MAFS related)
- Speedo not working
- Water in Headlights
- spirited maxima driving
- Pulling Codes on an 87 SE
- Where do I start?
- Be out of pocket...
- Out of time? or something else? Help
- max alarm install
- Parking brake cable
- clutch slave cylinder part 2
- Catalytic Converter
- Car wont rev past 2000 rpm
- system for sale if your interested. In Atlanta
- Power steering fluid...
- Power Steering?
- Rack & Pinion...
- Off Topic Story.........
- car died
- The L24E engine and head
- Motor Mounts Bad
- anyone looking for parts from an '88 max...
- 87 transmission strangeness
- Need an `88 for parts or fix?
- Rims
- power steering? tranny flush?
- Curious about MAX fuel economy look here
- About that Gen 2 station wagon sunroof
- Lip Spoilers Cheap!
- Mods to add to the list
- over filled tranny
- engine support?
- Still confused about octane...
- Need some experienced help.
- mesh front grill
- So Im driving to Temple
- Gen. 1 rear repairs
- Mirrors
- 87 Max Died Suddenly, Won't Start (Continued)
- Lip Spoiler
- 2nd Gen Yahoo Group
- 2nd gear doesn't synchronize unless...
- 86 max sheard timing pin need advice
- Glasspacks
- Auto - 5 spd swap?
- New Pics
- 87 An Interference Engine?
- Im pissed!
- Sunroof Fun!
- Digital to Analog Dash Conversion
- elec. shutoff switch
- The Maxima/Supersentra
- 87' wont start?
- Back on the road!
- Well, the results are in...The reason my 88 Maxima won't stay running is....
- Cracked windshield...
- Rotten Egg....smell
- Air Regulator Repair Info
- springs
- flowmasters?
- a/c fan location
- Door Dash light flickering
- Cams...
- 87 Max Stopped while Driving! Wont start back up!
- thermostat?
- PaceSetter Exhaust
- power doorlock problems
- Crazy fuel level problem
- ECU issue
- This is still odd...
- 'SNAP' went the bleed screw...
- Coming Soon, FSTB
- YET ANOTHER QUESTION: When I went to start my 88' Maxima this morning...
- clueless about the 1st and 2nd gen..and got really confused when i saw this
- Vi
- Help!Cold idle adjustment?
- 88 maxima gxe fuel delivery issue
- My idle drops to about 500 when i put it in drive, but returns to normal in park.
- The Junkyard Hunter, Part 2.........
- Hot start issue
- rust
- 2nd gen steering wheel?
- Tranny?
- early Z31 wheels on a 2nd gen Max?
- Clutch Fluid Leakage
- 85 Stereo help
- 1986 Fuel Filter
- crate motor
- Heating woes...
- Need 2nd Gen power and advice.........
- Spring question
- shifting
- Timing Belt Estimate
- Pulled a Explorer V8 :D
- The Junkyard Hunter......Part 1
- Adjust Idle Speed
- Why ??
- 86 Max, 96 visors.....
- 1983 Max problems
- Transmission swap information needed--please
- Removed the rest of the door trim
- 300zx Engine in a 86 Max
- Clear Bumper Lenses
- Which parts exchange?
- bad alternator?
- engine question
- Tracking electrical problem (ideas + facts)
- dash and heater lights
- Top 10 Member Rides
- Dynamat
- CV boots split
- Maxine wont talk
- First Gen Service Manual
- ATTN: motor mount
- Harsh shift 1-2, 2-3....
- Fuse under hood
- Brake shims....
- 89 & up engine in a 1987?
- flasher location 1985
- Is it possible that a battery...
- ******* 2003 Polished Titanium SE Maxima For Sale *******
- QUESTION: Could a bad air regulator...
- cheap nos
- How do I repair my starter
- Another clutch question
- Help - Clutch petal on floor
- 85 automatic transaxle question (s)
- Got some new gear
- I'd like to find the guy.....(part II)
- No clutch peddle effort
- Turbo project update
- Shifter problem
- queries from downunder
- Thinking of making a custom grill
- Cabin fan crapped the bed on me
- engine fails in extreme cold weather operation
- 1988 Maxima vs. 1989 Olds Cutlass Supreme
- Catalytic Converter?
- I Need Help Badly
- Strange scratching noise on cold car....
- rims
- which years?
- Maxine wont start
- Attn Newbies
- New member
- Keyless Entry
- Oil Pressure Sender part 2...
- Break problem
- New wiring harness?
- who has a FSTB?
- My turbo project.
- VG30E internal parts swap???
- I need some opinions........
- Wheel noise from back left
- Engine turns over slowly when starting..
- how do you take the window roller off
- How-To's...
- They want $300 labor only to do the rear shocks.
- CAI for 1st Gens Coming Soon!!!!
- roll call = frankencar
- Spark plug write up
- 1st gen mods
- New shocks for the rear
