- Off-set??
- I just bought a new ride
- cheap little improvements for the engine...
- leaking power steering fluid... again...
- 86 maxima to the test
- no spark from ignition coil
- 86 maxima or 90 accord
- My new Rims are on tell me what you think
- cruies control
- Stock Radio
- question about 9005 and 9006 bulbs
- 2nd/3rd Gen Comparison
- headlights...
- battery light...
- Shifter bushing replacement
- Stupid Question Time...
- my 87 max vs. mid 90s probeGT-- max victorious!
- exhaust
- Hesitation
- How can you tell what model Maxima you have if...
- JDM 33 Laurel body
- posting pics...
- Q about oil pressure...
- your exparences with airfilters (the good ones)
- new ride?
- Horn Doesnt work
- darkness ahead...
- radio problems
- Got the Tranny Out!
- Front Mount...
- Got MAF?
- August 23,2003
- finally got pics....
- Help!! Runs Very Rough
- Front Suspension Question
- Sluggish Engine Fixed (Possibly)!
- burnout
- need parts advice.....
- Front suspension is done
- my black 86 maxima
- Fuel Temperature Sensor
- whats the stock power?
- Inline 6 vs. V6
- Fuel pump going out...
- Pics of some of the new stuff for SE 86
- Pulling out the transmission...
- Gas smell after running
- Power antenna whip replacement
- Transmission Whine and Engagement Problem
- Compressor tensioner pulley loosens itself...
- max88q, could we...
- Parts car in Los Angeles area
- PCV Valve (part II) and hose
- New fog bulbs
- Does It Matter?
- short circuit/battery draining
- Power Transistor
- PCV Valve
- Test Pipe
- A/C Compressor pully and oil?
- Power seat belt diagnosis mode
- More new stuff for SE86!
- Post your pix , My pics inside
- yet another t-belt q...
- a pic of the new wheels i just bought
- trunk switches
- Timing belt installed, Max runs fine.....
- Loud Noise Got Need Help
- Is this anyone's maxima?
- Any easy way of replacing the rear engine mount?
- finally something good happend with my car...
- Need Bolt Pattern
- overheating problem!
- FS: 83 sunroof panel
- History of the Timing Belt part I
- exhaust manifold
- EAS shock/strut question
- Need purchasing advise
- I get my Maxima back
- newbie replacing t-belt on 86
- throttle problem....
- Laptop in car?
- Can anyone help me?
- 2nd gen injector plug mismatch
- Rotor comes off distributor shaft
- 87-88 spolier. please make offer!
- foglight suggestion
- engine problem...MAF ?
- blew out my exhaust pipe.. replacements?
- coolant boil-over tank
- uhh any suggestions?
- Finally! Dyno!
- Whizzeeels and Sprizzings
- Radiator Fans not turning
- Head Unit Installation In 2nd Gen
- headlight bulb
- Gas Mileage
- How do I get to the fuel injectors!
- ok...probally another stupid question
- Where can i find.....
- Auto tranny shifting problem.
- Timing Belt Question of all Timing Belt Questions
- Clutch, springs, struts and shocks and bushings
- Couple of problems with my 2nd gen
- tail and stop sensor
- A/c recharge
- Remember the problems of the vaccum leak
- Power Steering
- Power Steering
- Antenna Button
- New Pics.............
- Hella Supertones!
- 91 motor in a 86
- Rear wing on 87 Max?
- When it rains...
- Another idea bust...
- Ridin' On Rails!!!!
- Auto Trannies
- My pa wants to know..
- A/C R12 drop-in-replacement
- Engine dies sporadically!!
- Looking for sales sticker for 88 SE
- I'm back!
- those stupid little irritating problems
- I know i am new but i already got a Q
- Suspension Problem
- Wheel Size?
- 90 Max vs. 86 Max
- Bought a new toy!
- Need a driveshaft and radiator cooling fan
- Cruise Control Inoperative
- High Idle Problem
- Speedometer Problem
- Glove Box
- Ebrake?
- heater fan
- Algae problems in a 82 Diesel Max
- '88 Sunroof rattle...
- wiring harness available at best buy/circuit city?
- R&P Install Problem...
- Computers and Auto Trannies
- Anyone ever race there Maximas
- Question about A/C
- How to get coffee out of a rocker switch?
- where is the aux air valve at on a 1985 max
- Rattling noise during acceleration...
- help,digital dash 88' speedo intermittant, code 14 - speed sensor
- Battery Drain
- No shift into O/D
- pictures of wagon with tinted windows?
- Should I fight this ticket?
- man...
- I should have bought the Commodore
- My max goes in the shop today
- Rough Idle and then clears up once warm?
- Cylinder Head Temp Sensor
- which of these two dash kits should i buy?
- Coincidence? re: new o2 sensor..
- Diesel 82 Max... on the Mend
- Rebadged my trunk today
- common problems wiht second gen gxe wagons
- All alone?
- 88 Maxima SE vs. 89 Olds Cutlass Supreme SL - Part 2
- No More Water Leakage...
- Got some stuff for my car :D
- need new suspension
- Shake, Rattle, And Roll
- It's official - The Maxima's Back!
- Looking into possibly getting an Short Throw Shifter
- 87 Maxima - A/C debris-goes where?
- 87 MAXIMA A/C recharge
- Possible Opportunity...
- Ultimate 1st Gen Max------a limo!
- Looking for an 86,87,88 SE
- Wtb front lip for my 87
- Poll.... need help.
- Lil Nismo.... RIP?
- the maxima's back
- 300zx ECU swap questions
- finding an L-series
- Another power steering update...
- Help car won't run right
- 87 maxima with VG30DETT?
- NWMaxima meet was today...
- Cup Holders For 87' max's
- Why cant I search?
- Hello
- ASCD what is it?
- broken head bolt
- hello all
- Attn: 86wagon
- I got me an Unorthodox UDP
- Hook Battery reverse car die
- 1st gen head gasket
- 1st gen slight problem
- cressidas are better than us?
- Spindle / Hub...
- Cone Filter Installation
- is this possible?
- Need Cheap Performance Parts
- Sealing Headlights
- New Pix
- 86 Max for Sale
- For Sale!!!!!!!!!!!!
- Installing a CD player
- top Speed of an 87 maxima?
- As soon as I fix one thing....guess what?
- Where Can i find a Nice Exhaust
- Help me find mfg. date for my new motor
- Rear passenger brake caliper stuck
- Car Repairs
- Fuse for mirrors
- Can't Find Sh.it!!!!
- sway bars
- I Hate Monroe Struts!
- Pulling Codes
- Opinions On which wheels i should get
- My First Time pix of my car
- bleeding clutch system 87 max???
- Posted new pics.
- Replacing waterpump myself any suggestions?
- 1st Leg Complete!
- 2nd gen motor mounts
- Engine Temps
- '88 Legran
- Lubricating throttle cable tensioner springs (or whatever they're called)?
- Stuff like this makes me laugh!
- A/C Recharge
- More problems with my exhaust then I though
- Motor Mounts?
- Chilton Manual
- P/S work update...
- Automatic stalling?!?
- Sleepers?
- 86 Max Ignition Mods
- Problems with my Maxima
- Hey Sarin!
- Z Car Injector Swap
- Z Car ECU Swap
- Thanks
- Suspension Mods
- 86 Maxima Engine Mods
- needs maf
- Last Day on My Computer............
- Had an accident, totaled?
- Need Air Filter Info
- 87 throttle position switch
- 85 Automatic wiggin out
- Wiring for remote-start/keyless entry.
