- Battery cable questions
- Timing belt parts
- meeting for the LA autoshow 1/10 sat....
- Horsepwr
- Diesel Maxima specs
- Problem on the horizon...
- running hot
- Newbie and a water pump question!
- Door handles
- struts for 87 Maxima
- why is?
- PIAA Xtreme White 9004 question
- 1st gen carpet set?
- Fuel Pump Hum -1987 Maxima (5 sp Manual)
- struts
- Got me a wee bit of a problem.....
- Got the new bumper on!
- fuel meter guage
- RIP my Maxima
- fuel filter replacement?
- 87 maxima intake??
- BMW Headlights and heater question
- gas smell
- aftermarket deck instal
- brake problem
- The MaxPC
- engine problems
- 86-87 Maxima ANTI THEFT HELP??
- 1988 Maxima VG20ET
- 87 SE Maxima engine trouble...
- 87 Max on E-bay
- The worst night yet
- Starting Problems
- cup holder?
- idle adustment?
- Finally got some pics!
- Hey guys, got stuff for sale...
- idler pulley assembly
- 88 maxima stalls when put into gear
- Callin' all BAY AREA 2nd gen owners!!!
- Hmmmmm
- 85 Maxima Oil Filter Location?
- Transmission rebuild book and/or #
- Halogen vs. Normal bulbs
- I need some 86 Max info
- Ebay 92 Max
- Pics!
- Speed Test
- ebay intake
- photoshop wheels
- 82 max with small block V8
- Anyone got extra headlights?
- what other transmissions will fit...
- Stupid Question Time...
- Door Handle Needs Repair
- Sacrilidge...
- Question for those who have dont the 300zx ECU swap
- Search function?
- grinding while movine
- AAV replaced...still high idle
- Voting for Maxima.org's calendar is taking place now!
- Working on the Cosmetics
- Need to change rear seal in 85 Max.
- big brakes
- I love my Max but...
- air regulator/part number?
- fast idle control
- reading the ecu
- "whering" noise
- '87 Maxima, spark plug torque specs
- dieing at idle
- motor mounts
- gunmetal wheels
- adjustable suspension
- Dashlights
- sputtering/backfiring
- Check This Out
- speakers
- Stereo Question
- Maxima Compilation
- SE or GXE?
- Nicotene (?) Stained Paint
- stereo
- Couple Of Questions
- got 2 87's but there diffrent inside
- Maxima.org 2004 Calendar...Would you like your car to be featured in the calendar?
- Tranny swap complete
- Woot woot
- Washer/bolt from Heck
- Buying my 1st gen Maxima today!!!
- Where can i get this peice for my Max
- Temp Woes
- $600bux 87 Max?
- diesel engine swap
- Got a couple questions...
- antenna question
- Is this true?
- Another 1st Gen on the road
- 87' Maxima tranny swap
- 87 Max Specs.
- Cassette player won't release casette
- 1988 Maxima Interior smells like smoke
- better buy?
- Where is front pump located on transmission?
- finding/accessing the oil filter...
- 3 Problems Black smoke, voltmeter, lo power
- 3rd Gen 5spd Tranny
- performance camshafts
- fix one problem find another (orange fiber shake pics inside)
- Maxima Diesel Help!
- 88 auto to stick swap almost complete
- 2nd gen intake
- Door Locks won't lock!
- Got one but need the other
- reverse lights
- need info on the u11
- best spark plugs to use?
- which 2nd gen should i get?
- 85 vacuum system hosed pt. 2
- Control Arm Bushing Alternatives?
- air conditioner compressor clutch
- Wipers don't work - 1st Gen
- Rear bushing for front lower Control Arm
- Help - 1985 security system problem!!!
- Oil pressure woes. Help!
- timing belt question
- color
- What a nightmare!
- Suspension/Brakes
- Pricing/Ordering for 2nd gen CAI now available.
- pedal jam
- I need some help plz~
- Front End Suspension Noise on 88
- car inspection
- Injectors not functioning tho Ecu is fine
- i pulled my radio
- when i go to sell my max how much do you think i should ask, pics of it are inside
- mounts and PS lines
- guage lights...
- Finally, a true 2nd gen CAI running off the TB.
- WTF Accelerating and Braking
- 5 Speed Convos
- Oil Changes
- Friend with auto tranny problem 88
- Don't mean to brag...
- Still a really fast idle
- Possibly Parting Out 87 Max, Guaging Interest
- Lowered Suspension
- 85 max wagon trans prob.
- ACK! Rust?
- Stupid Teenage Girl 1, Maxima 0
- C.V. Boot solutions
- anyone want CAI?
- High beams
- Coolant recommedations?
- o2 sensor
- 87' Maxima running bad
- Detailing Questions?
- Electrical problem found...
- IT FINALLY DIED! (need a seccond opinion though)
- More Problems! Advice Needed
- "Check Engine" light never goes on except...
- Need them clear signals or numbers
- Rebuilt Engine/overhaul
- Question About Procarparts Guages and Fuel Capacity
- Throttle body mod?
- Electrical problems...
- Maxima SE 5spd?
- The Wagon Runs Again...???
- Can someone donate some web space for a few turbo max articles?
- buyin a 87, need your advice
- General Info
- Low beams don't work
- water useage
- thinking about buying the 2nd gen
- i need to make sure the battery is connected right
- I have a 1987 Maxima with GOOD parts
- which is better.
- Stalling in Portland Ore
- Wagon update...
- 88 max door lock question--please help!
- sensor light...
- Can I install the battery myself?
- What Rims Fit 87 Max?
- Ideas?
- alternator question
- Oil loss mystery?
- Ground effects
- driving a 5speed?
- EEK problems
- black/tan interior...
- Grrrrrrrrrrrrrr!
- timing belt question ???????
- Needs some leads
- Final Farewell
- swapping 3rd gen onto my 2nd
- Wheel Spacers
- Auto Trannies
- exhaust system noise advice
- Another update...
- 82 Diesel Max tranny Q's
- timing belt change
- I think I've found my muffler!
- Installed the SilverStars!
- lost my maxima =[
- Cheap way to replace struts on an 87
- 2nd gen Maxima was the best generation ever?
- Where can i Get a full exhaust kit
- Make a Bluebird???
- Anyonr have a modded wagon?
- ac idler pulley needed.
- Timing
- Super-HICAS?
- General Info
- 88 max se for sale for all you 2nd gen lovers
- Just letting you know, turbo intake for sale
- 89 diff in an 85-86 tranny???
- Maxima Sits
- Since the org is going to be down...
- wheres the trany fill plug on a pre 92 5spd
- Quick Stereo Question
- 82 Max Diesel
- 82 Maxima Diesel
- Rear ended and written off
- Motor Oil Question
- Cylinder Head Temperature Sensor
- Performance Exhaust
- Lights in Blue.
- Horn doesnt work
- Tires?
- I've recently noticed...
- acceleration noise
- 300ZX compared to Maxima
- EAS Front struts
- Compression on VG30E
- Knock Sensor
- Electronic suspension conversion -- confused!
- Replacing Positive Battery terminal junction
- 86 maxima 99 altima spec. challenge
- Allignment woes
- Window Regulators
- Need advice on replacing rear hub bearing
- Best Cost for Performance?
- Not be around much for a while...
- ok now i am confused...
- Help info onTRANS
- pricing
- decisions decisions
- Ohio?
