View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14
  1. just got a 300zx ecu.
  2. body kit?
  3. security system
  4. 87 Y-Pipe needed
  5. Cleaning and Detailing
  6. She locked me out! '87 Max SE in NY
  7. tornado, fuel magnet K&N filter Gas savers?
  8. Diesel owners
  9. Fast Max!
  10. Fast idle
  11. 1 and 2 gen information
  12. %$#@!&$%^%
  13. 85' headlights wanted
  14. 5 lug conversion is nearing....
  15. Vacuum hose diagram
  16. Aaahhhh!!!
  17. Sun roof window
  18. Pics Coming soon!
  19. Just posting cause nothing ever happens here
  20. !chts!
  21. Painted Intake Manifold Cover
  22. Bearing Noise
  23. Air Intake
  24. Udp
  25. sunroof seal
  26. pimp my ride
  27. cylinder head temp sensor?
  28. 1st Gen on Pimp My Ride tonight
  29. Time for another Engine
  30. carpet kit/speakers
  31. Battery
  32. Foreign Object In Combustion Chamber
  33. Simple 1st Gen Question
  34. 94 Sentra XE
  35. Clean bill
  36. Need Manual Speedo Gear
  37. Pimp My Ride!
  38. 87 Max Tranny Question
  39. Thanx!!
  40. A/C not blowing cold
  41. Funny story, maybe...
  42. Instrument panel
  43. Wheel stud/nut Issue
  44. Putting Maxine back on the road
  45. Help!!! Car Won't Start!!!!
  46. Digital Instruments Good or not.
  47. My correction, sorry
  48. Fresh Update
  49. UDP and Unothordox timing mark misprint
  50. who has the talking lady ?
  51. What's holding the power steering pump in?
  52. My car's starting to make me mad!
  53. Turbo anyone?
  54. Sold the Honda
  55. So I finally hit the track for the first time
  56. Alternator question?
  57. Keyless entry Master code on 85 Wagon
  58. Please help w/87 maxima problem
  59. :)
  60. Progress report
  61. Ashtray light
  62. Studs!?
  63. Transmission...
  64. New Gen 2 Owner - Suspension Upgrade
  65. New Gen 2 Owner - Tranny Swap
  66. New Gen 2 Owner - Intro (bought it last night)
  67. air dam question
  68. Power Steering Leaks
  69. Cold-Air Intake
  70. computer question???
  71. bypass hose replacement
  72. Ouch! My to do list keeps growing!
  73. Idling problem
  74. 1985 Maxima
  75. Specifications for LD28 Diesel
  76. Happy NEW Owner of a Maxima 2nd GEN!
  77. ATF fluids...
  78. exhaust setup?
  79. Is Maxima.org Up And Running Fully?
  80. What does a Auto tranny weigh?
  81. help....yet another q' :)
  82. 30% off Nissan OEM list ends April 30 2004
  83. Front Motor Mount
  84. forum is dead...someone build me an intake
  85. Vapor lock????
  86. Problems removing seats and VSS question
  87. Hello, im new here
  88. 88 Maxima replacing rear brake pads
  89. EGR Valve?
  90. Radio swap on 85 1985 Wagon .. ?
  91. help! quick Q'
  92. what sensors and parts should I pick up?
  93. 1st Gen Audio Question...
  94. rear suspension install problems
  95. Rear shocks
  96. Finding Parts
  97. SE front bumper wanted
  98. Disc brakes....check it out
  99. getting there...
  100. ALMOST Hydro Locked
  101. Hot Start Woes
  102. Im Rich!!!
  103. Shocks???
  104. Need advice on vacuum lines and seat
  105. Keypad Beepy Going,going,gone..
  106. Pics of Stillen Exhaust (56k warning)
  107. Gen 1 door fatigue fix
  108. DYNO question to members of the org.
  109. Tips + tricks on pulling a second gen motor
  110. Need To Restore 1986 Maxima
  111. hope to be getting back into the maxima picture
  112. Swap!!!!
  113. Curing a Rough Idle Problem
  114. New 2 Board
  115. f/s: '85 maxima
  116. Gen 1 AT trans mount for diesel
  117. Anyone driven/ have both 1st and 2nd gen?
  118. Maxima meet in MAY please read!!!!!
  119. Very Good News!
  120. 5 speed wont go into reverse
  121. I need a 5-Speed Drive Shaft for 1st Gen
  122. replacement struts
  123. whats the demand for second gen parts?
  124. Questions from a Newbie-Swap, throttle body, shocks
  125. friend of mine just got a 2000 cavalier...
  126. doors wont open ...........Help!
  127. Where does the EGR hook up on 1st Gen?
  128. I need some help
  129. What happened here? Oil leak + no idle issues (pics inside).
  130. Headlight Problem seeking advice
  131. HELP PLEASE with manual transmission problems :(
  132. everyone here is gonna hate me.......
  133. H2O on the ground #*@&#$
  134. Need Help!!!!
  135. Brake bleeding
  136. help: squeaking noise
  137. Any Ideas ?? Help here***
  138. Stick shift problems (position?)
  139. plugs
  140. bolt on mods for HP
  141. fuel/emission problem
  142. Is 0-60 in 7 bad?
  143. VG30DET's for everyone!
  144. ignition
  145. Don't have new pics.....
  146. 87 maxima parts car, PRICE LOWERED, now $200
  147. Erratic fuel gauge
  148. Antenna woahs
  149. Boom!
  150. paint touch up
  151. Manual Swap a Success!
  152. transmission
  153. Parts
  154. Throttle body
  155. 300zx ecu
  156. Can anyone with a manual max help me?
  157. Does anybody has parts for an 81-84?
  158. Online used parts?
  159. A/C belt and others
  160. Nissan Master Tech for Hire Ohio area
  161. driver side wiper not working?
  162. driver side wiper not working?
  163. Engine Cradle
  164. Digital Dash...
  165. losing power (87 maxima)
  166. Possible Down-grade...
  167. Power Windows problem..
  168. How much hp am I looking at?
  169. Auto Tranny Woes
  170. Exhaust issues...
  171. Installed a Stillen Exhaust on my car.
  172. I think I found my wheels...
  173. Resetting keyless entry code 1985 Maxi
  174. which struts?
  175. y-pipe...gutted?
  176. 9004 > 9007 headlight conversion
  177. Wheel Heigh Measurements on 1st Gens?
  178. Wheels, this question again...
  179. is it possible that.....
  180. Shifter/brand name question
  181. 87 Won't start
  182. My dilemma that some of you may know about
  183. what weight oil should i use on my 88 sedan
  184. I did a few things too...
  185. IM BACK (new pics)
  186. crazy idle
  187. Tires...
  188. P/S pump...
  189. Glad To See Ya Back MaxWgn
  190. "Spot Light" in 1st Gen Maximas?
  191. New clutch in now I need...
  192. If u need parts check this out, Maxima f/s $300.00
  193. general performance parts questions
  194. auxilary fan
  195. Need Exhaust
  196. turning steering wheel does not turn front wheels
  197. just wondering........
  198. Did a few things today.
  199. Larger MAF
  200. 200k club
  201. Woo Hoo!
  202. Wiper Question
  203. how strong is the '82 rear end
  204. Anybody with an '83 or '84 service manual?
  205. replaced thermostat...much better
  206. Havn't got my CAI yet
  207. Addco Swaybars for 1st Gen
  208. Where is flasher located on 87?
  209. Questions on my 86 Max: Help?
  210. back to maxima.org....
  211. vacuum hose kit?
  212. Got a ?
  213. FS: 87 SE stock tape deck and EQ
  214. how in gods name do I remove this pulley?
  215. tires and lowering
  216. 87, having crazy idle
  217. changing belts on 87 Max...
  218. High Beam's quit working!
  219. Takes forever to warm up in winter!!!
  220. Timing belt...
  221. Newbee with a question
  222. Manifold CRACK! HELP
  223. shift knob
  224. headlights
  225. squeaking engine
  226. 87 lower springs?
  227. Time to replace the starter...
  228. New wheels!
  229. Getting some studdering...
  230. What could cause hi readings of HC at idle?
  231. not exactly a L.E.D. taillight mod
  232. Just thought i would give u guys a heads up, I might be parting out the max
  233. Finally, a decent battery!
  234. Warm start problems.
  235. R31 Skyline - looks just like a Maxima!
  236. Lookin 4...87/88 Maxima parts
  237. Still experiencing starting problems...
  238. Looking for a wheel upgrade for my 1st gen
  239. output ?
  240. cold no starts
  241. FS: 87 Maxima
  242. Paging MaxWgn!
  243. anyone have a 88 factory service manual handy
  244. cork in hose?
  245. got a ?
  246. autolite??
  247. recall?
  248. can anyone tell me what trim i have
  249. how do i read codes?
  250. My car is stuck in reverse?
