View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14
  1. Squeaking around the front end on bumps
  2. probally the most obvious TPS Q
  3. Leakdown Test w/ broken timing belt
  4. car sputters and dies when "cold" outside
  5. 86 automatic axle, fit an 88 stick shift.
  6. Help needed (brakes)
  7. stupid question
  8. Replacing Ball Joints
  9. One eye willy!
  10. What are the KYB part # to change from electronic setup.
  11. Engine won't run...
  12. Speed-o...
  13. spyware issues on the org?
  14. ECU Trouble Codes
  15. Tune Up!
  16. Best Muffler 88 max
  17. $139.90....good deal springs
  18. Hey Sarin!
  19. how the h31! do I remove the dash board?!
  20. Found why my speedometer not working, might help others.
  21. What is this part, coming from the rear of the 5 spd trans
  22. Quick Q - AAV
  23. won't shift
  24. Motor mounts
  25. Checking for spark
  26. Purchase a 88 max and having issues
  27. How can you tell the diff. btw the 88's?
  28. Spinning 18" of love! (56K, go to hell)
  29. 2nd gear low..
  30. Heat Issues.
  31. Back to using NGKs
  32. how hard would it be...
  33. I'm missing at least 25whp and 25wtq.....crap.
  34. 87 Factory Service Manual for sale
  35. DigiDash-Standard
  36. busted max for sale
  37. Found Engine Number
  38. changing the timing belt
  39. power mirrors
  40. strange squeal
  41. Auto tranny drain plug... of spooky doom!
  42. Now what???
  43. Turbo Selection
  44. SENSOR light on dash bar
  45. Brake light comes on...
  46. engine number
  47. Transmission wont shift past 2nd gear...
  48. "new" 88
  49. Factory Radio Setup Anyone?
  50. Help with air filters
  51. 87 maxima cold start
  52. 87 Max Tran slipping!
  53. No more indecision...
  54. Help
  55. Rear spoiler
  56. Temp Gauge Creeping Up
  57. Its been along time since ive posted so hears an update
  58. Smoking. Smoking. Smoking
  59. I am sadly leaving the .ORG
  60. light stays on even when lights are off?
  61. Power Steering Problem
  62. Clutch issues in Sentra
  63. Where there's smoke.....
  64. 84 temp sensor wire
  65. 87 Max No Start - Distributor?
  66. looking for rear upper strut mounts for '88 Max
  67. How do I use mode II on ECU?
  68. "Crying fuel pump" Good brand for fuel filter?
  69. a quick Q
  70. fuel injectors
  71. Best cleaners/wax etc. for a white '87 GXE Sedan
  72. instrument cluster part 2
  73. fix lights or exhaust?
  74. 1987 Factory repair manual for sale
  75. RL4F02A trans...need diagram....
  76. Checked ECU today and got 'ignition signal' code
  77. Auto seatbelts, revisited....
  78. What N/A mod adds the most power?
  79. 88' Maxima SE 5sp Transmission Question
  80. Intermitent electrical issues.
  81. I need to replace my 'In vehicle temp. sensor' Auto Climate
  82. AHH Dash Crack!
  83. How to check ECU without removing seat??
  84. Replacing front & rear suspensions...Any tips?
  85. stalling after running out of gas
  86. Canadian Engine Mounties
  87. tranny fluid change...
  88. picked up an '88 today
  89. Leaking exhaust manifold
  90. Is my car REALLY that UGLY?
  91. Auto Seatbelts, Airbags. When did they start?
  92. Auto Tranny Swap---Remove Engine?
  93. Gone for 3 days, look what happens!
  94. Taking soooo long to warm up as weather gets colder...
  95. foglight question
  96. Seafoam lots of smoke under front..
  97. Air filter question.
  98. Throttle Body?
  99. Anybody ever use Lucas?
  100. Aftermarket stereo advice
  101. ATF / Filter recommendations
  102. A/c recharge in a 85
  103. 85 Maxima steering pump
  104. Contemplating O2 sensor replacement
  105. Auto Climate Control Woes**Need Help**
  106. Tach conversion
  107. how do you guys like these wheels?
  108. updated pics
  109. 1983 Maxima Limo E-bay
  110. Finding KYB-GR2s in NY area
  111. Intake pictures
  112. power window motors
  113. Mass Airflow Sensor (MAF) removal...
  114. More pics for the masses....
  115. how do I install a remote for door locks
  116. Various tune-up questions
  117. Urgent question: Fuel cutoff in case of accident? Override?
  118. Back on the road, new problem.
  119. RL4F02A Rebuild
  120. engine removal...
  121. Rear Brakes
  122. Does anyone want my spare midpipe?
  123. Alternator/generator upgrade
  124. 87 maxima axle
  125. found on e-bay(I do this alot..lol)
  126. Brake Pad Squeal
  127. nissan v8's
  128. suspension rattle
  129. Sticky the 5-speed conversion
  130. interesting little blurb
  131. Keyless Entry
  132. alternator belt
  133. how do I redo the boots on the rear end of a 83
  134. Floor mats
  135. Cylinder 3 not firing and there is oil on the spark plug
  136. problems with my 88
  137. Auto Transmission Woes
  138. Need help picking a NTK O2 sensor for 87 Max
  139. Not the right thread, I know.
  140. Windex on your headliner!
  141. Front bumper concept image
  142. Unorthodox Underdrive Pulley for sale
  143. Decisions
  144. Found some new rims for my car!
  145. parts that dont fit or dont ship
  146. Wrecked my 97, bought an 86
  147. Hi all, new to site. how to read ecu codes??
  148. any1 feel like measuring their rear rotors diameter?
  149. How to fix a leaking sunroof
  150. The 5 lug conversion is now worth it!
  151. Engine Swap
  152. Pimp My Ride - Maxima
  153. Instrumentation from gas to Diesel
  154. i need a front exhaust manifold
  155. newbie
  156. Axles are fun?
  157. Exhaust question
  158. engine bulid sticky isnt working
  159. Maintanence at 80,000mi
  160. I have no idea what's wrong with my Maxima.
  161. Future Modding Plans
  162. torqe converter
  163. Seat Covers
  164. Cold Start Idle Problem
  165. Help, 1988 rh inner door trim piece needed!
  166. Speaker Setup for 1st Gen (For Sale)
  167. Signature Picture Guidelines. Read before posting signature pics!
  168. 88 Maxima auto transmission problem
  169. muffler idea
  170. '85 Maxima Sounding like a Diesel!
  171. 1985 Maxima FSM
  172. replacing the EGR?
  173. AC Question
  174. 86 300zx engine in a 90 Maxima?
  175. 86 300zx engine in a 90 Maxima?
  176. one of those really bad things
  177. message for DR J
  178. Fuel octane and 2nd Gen Maximas
  179. turbo anyone??
  180. She Speaks!
  181. Which had the better TB?
  182. auto tranny problems...
  183. wagon guys
  184. help.. overdrive went
  185. Diesel max 5 speed
  186. '87 Maxima V6 Turbo
  187. Mixture Ratio?
  188. Looking at some paint options...
  189. GL-4 or GL5 tranny oil for the Maximas?
  190. Shocks n' Struts
  191. AC problems
  192. Upgraded ECUs for 87-88 2nd gen
  193. Power Window...
  194. Air Condition Problem
  195. Starter motor is grinding every morning
  196. Emission Fixes
  197. LOL! A snip @ $18,000!
  198. Good To Be Back!
  199. 1985 wagon transmission slip into 3rd gear..
  200. random questions.....
  201. transmission cooler lines
  202. back with a vengence
  203. Starter Questions
  204. Top Speeds
  205. Realistic price for 1st gen
  206. Cleaning Intake Manifold
  207. Custom Intake!
  208. Lower control Arm for 88' Maxima SE
  209. wish I was around NJ
  210. P/s Leak!
  211. How can i tell what kind of Maxima I got?
  212. LD28 Longevity Maintenance
  213. size of hoses around the gas tank
  214. help car is runnin like ****!!!
  215. Eibach's Own.
  216. Eibach's Own.
  217. Still have one midpipe for sale
  218. Stero System for '87 Maxima
  219. My wagon tranny swap pic
  220. Help!!!!
  221. oil pressure erratic
  222. So this is odd...
  223. 17 Gallons
  224. where is the fast idle control?
  225. Total Engine Management
  226. electrical problems... yay
  227. Oil Filter Location....
  228. Selling Unorthodox Underdrive pulley
  229. guy selling lowering springs?
  230. Anyone?
  231. SE limited question
  232. KA24e throttle body and 5 spoke rims
  233. new here
  234. motor question
  235. ST springs on 85
  236. Got quite a few parts, need to sell.
  237. Handbrake Light
  238. help with oxygen sensor
  239. help with engine issue
  240. Brake Lights Don't Work
  241. 87 sedan electrical problems??
  242. Nissan Maxima 87 sedan engine wont start
  243. my poor car
  244. MAXIMA '85 station wagon FS
  245. Speaking of Body Kits .......
  246. Help the NewB's
  247. Gauging interested, ST Springs
  248. Idler Pulley help
  249. 1994 Sentra XE
  250. Air Flow Meter unplugged
