- Window wont go up
- Suspension Upgrade?
- wear is everyone from?
- seafoam
- newbie with a qustion about an 87 maxima
- Front End issues
- need some help
- Why
- Who got the turbo for their 1st Gen?
- Buy a rust free 1st gen, or paint the one I have?
- Exhaust manifold gasket?
- 87se at the track
- 1ST GEN P/S Leak!!!
- 1st gen 5spd conversion?
- 86 Maxima will start but will not accelerate
- trying to pass emissions
- Got a new car....
- 87 fuel system recall
- what size?
- Tachometer sticks at 2.5-3k
- Runs crappy in higher gears
- Q45?
- Radiator leak - replacement or sealant?
- 2nd Gen. Infinity's
- Where do i put this thing.
- anyone ever park their car on about 43rd and glisan?
- wiring question?
- leaks and clicks.......?!?!?!?!?!?!
- Carbon Canister reaching critical mass?
- best place to get an axle...?
- 86 coil and power transister
- Did I find a diamond in the rough?
- 87 gxe suspension
- WHat did i Do??!!!!
- New Headlights
- cold start/running problems...
- Where is the PCV Valve located?
- Valve lash adjustments L24e and LD28
- Oil Pressure Problem
- 86 Maxima Cooling System
- 1st Generation Mystique
- 87 Max timing belt successful
- Anyone have a 1st Gen without a Sunroof?
- end of the road?
- what lowering options...
- Codes 2,1 & 4,1
- Clutch question
- 1988 Maxima RPM Problem
- 86 maxima help ME!!
- Some help with an 82 diesel.....
- Alignment with S/T springs
- 1982 Maxima 5-speed for sale in WA....
- headlamp removal...
- wanted 84 or older maxima
- Oil Cooler conversion coming
- That rubber timing belt!
- stalling - part 2
- Servicing the LD28
- To warm up, or not to warm up?
- setting idle?
- 2nd gen intake manifolds.
- starting problem
- New to the moding cars
- need a pulley
- Exhaust question
- Brake Maintenance / Upgrade
- oil pressure?
- Vg33
- suspension
- Need help Please Read (Not Enough Power)
- Spark Plug Trouble
- 1988 Rack and Pinion and Pwr Steering Pump
- need opinion on non-maxima related dilemma
- body customization
- Tranny
- over-heating
- Drop it like its hot!
- My old Max
- new to the maxima world
- speedo gear
- Always something...
- pimp the max!
- fuel injectors
- 4 questions
- Brake switch location 1986
- intakes...
- To those with hot start issues:
- literature about VG20E engine
- one irritating problem, then another
- 83 Maxima in need of help
- 83 datsun/nissan 810 maxima
- much atf
- Complete Performance/Upgrade Parts Lits
- Converting gas to diesel
- How Many Diesels were sold?
- LD28 Diesel
- where does one find...
- intake manifold disassembly
- Bosch Oxygen Sensor
- Cool link on how to tell if you have a VG30 A/B block or VG30 W Block
- Stalling on highway
- 1987 maxima wheels
- anti theft
- Shifting Question
- Does anyone here actually have the
- 2nd Gen SS Braided Brake Lines Group Buy *Please Look & Post*
- 2nd Gen Stainless Steel Braided Lines
- 1986 maxima handmedown, i need alot of help!
- Anybody had to replace the speedometer cable
- question for those with S/T springs
- Does anyone have dyno results
- What the HE11 is wrong with my radio!!!!
- Anyone got an extra center hub cover for an '87 GXE?
- Power flush---good or bad? '87 GXE
- Electrical wire color (TPS and Air Flow meter)
- I can now drive my car, but
- Tinkering
- Two Simple Questions!
- power mirrors don't work...
- 240sx brake rotors
- Broken strut cartridge nut?
- Let's see some pics
- 81 Max... when all else fails, go back to the basics
- How Much is it Worth ? Mint Max.
- List your mods!
- dash help
- werid noise
- Some photos from today...
- A mod for you guys that dont kno for :calvin:members only!!!!:calvin:
- talking lady voice box
- Runs great when cold...
- where can I get a GOOD alternator?
- 88 max likes to be difficult
- Broke a timing belt....
- SR20DET motor?
- That Damn Box
- Chts Q
- vg20et?
- CHC Guys! Check it out!!
- Battery, alternator, or other
- A wierd noise from engine
- Very Strange Steering Problem
- F/S:New KYB GR-2s 4 Dirty Cheap
- Stalling...
- Looking for a 1983 Maxima 5 speed trans
- Keyless Entry
- moonroof help needed
- ATTN dslsmoke
- Parting Out: 86 black SE 5spd
- water in vent?
- 2nd gen OEM clear front turn signal lenses for sale... check the classifieds
- tranny?
- some *pix* of my ride
- Who has the part number for a CHTS?
- 86 Nissan Maxima Audio Help
- Headliner removal help needed
- I need a driver side fender!!
- fuel injection
- Need some advice....
- what size is a second gen axle nut?
- Some problems with my 87
- Insurance Bull****
- Front Suspension.
- changing the rear valve cover gasket
- 2nd gen setting timing?
- Timing belt is gone
- replacing the front brakes need help
- Rough day, car might be dead
- Starting problem, 88 Maxima GXE
- Headlight Swap
- Sunroof and Trunk -- Please help!
- anyone know where i can get a turn signal arm?
- brake suspension upgrade parts
- Just Run!!!!
- 87 Max Exhaust Question
- Tranny problems! Help!
- Kalifornia?
- F/S 1984 Maxima stock grill
- Pinpointed my problem.
- so where do i find the break booster line?
- Nice Rack!
- blower motor resistor
- My friend's 1st gen...
- fuse/fuseable link for parking lights?
- alternator not charging
- Window pain
- What is this mystery part?...
- Advice from the crew on 1987 Maxima gle
- Where do I find this part???
- Sarin... Did Ya Get The ECU?
- 88 max aod help
- AT filter
- 1988 door panel removal?
- Cure for plastic headlight hazing
- HID's for Sarin.....
- ebay auction
- Keyless Pad
- Audio Installation for 87 Maxima
- whos got an extra grand to play?
- Throttle Body Position Sensor
- o2 sensor install
- 86 Wagon Questions;Electrical;Power Steering
- 87 max help
- 88 Rear Strut removal/replacement
- some info for the jdm conversion guys..
- 81 with an idling problem
- 87 FSM and Haynes manuals for sale *Make offer*
- 910 bluebird nose on 1st gen max..
- Alternator pull on 87
- poor lighting from the headlights
- car won't run... where do i start?
- Aftermarket sound and OEM Warrenty
- 1981 Max got wacked....need a bumper
- headlights dim
- Trunk lock
- Did a little more troubleshooting today.
- can i get an intake for my 86?
- leaking fuel, need advice (Pic included)
- Complete turbo conversion items
- Will a doubledin stereo fit in a 2nd gen?
- can't decide
- Parting out my 1987 Maxima
- Moment Of Silence Please...
- Help 85 Wagon Wont Idle
- Exhaust size? First gen
- Torque-RPM chart
- New Nissan on the block
- Always something!
- Hook me up with some Munro Sensitracks
- Running WAAAY too rich.
- Old School Wagon
- 2nd gen front grille
- should i sell the 2nd gen?
- Some new pics ( engine and Rikens ) 56k - crash into a ditch!
- opening up exhaust?
- AC/Heater Control...
- Coolant temp sensor and CAS on GA16E
- aav question
- Opinion on a 1984 Maxima
- Someone buy this!
- Wipers gone wacky
- '82 Max getting parted
- The 22 freeway
- Need a Part Number? I can help!
- Stripped Spark Plug
- How difficult is it to...
- Perfect Maximas
- Nissan Maxima 87 clutch separated from air compressor
- Wylie stopped by (56k blows goats)
- checking codes with scanner?
