View Full Version : 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. quick y-pipe question
  2. 4th gen HU
  3. High Mileage 1st & 2nd Generation cars
  4. need info fast
  5. expansion valve location
  6. how can I tell what engine I have in my car
  7. 240sx rotor swap!!!!
  8. major brain fart
  9. Always Sometin'!!!!!
  10. 88 white maxima partout
  11. Aftermarket struts and Springs
  12. What will fit our cars?
  13. speakers....again
  14. My 87 Maxima
  15. Air Intake
  16. 1987 maxx
  17. My max wont start!HELP!
  18. Timing Belt Replacement 87 Maxima
  19. Still Have Engine Whine
  20. FS: ST lowering springs + more
  21. Need help finding a clutch ASAP!
  22. Drove the 88 for the first time in a long time
  23. S.M.J ECU Connector?
  24. 87 Maxima Window Problem
  25. these engines are tough, how tough?
  26. idle problems......
  27. Serious Electrical Starting Problem, please help!!
  28. plug wires
  29. Koni struts
  30. Lighting Upgrades
  31. For Sale
  32. Looking for M.T. for 85'
  33. 1st Gen Radiator Upgrade
  34. 88' Max. need Fuel Injector connectors
  35. 1st Gen AutoX Pictures
  36. Gasket Won't come off!!!!
  37. 1st & 2nd Gen Pictures
  38. Porting intake and exaust
  39. Electrical issues on '81 Max
  40. T-Belt Tension Adjustment in '87 Factory Service Manual Revised?
  41. idling problem solved!!!....... hopefully
  42. 1st Gen Trailer Hitch Design
  43. F/S 87 Maxima
  44. Possible maximas for sale
  45. mo' ticking
  46. Any 2nd gens going to maxus?
  47. Wheel Studs
  48. 87 for sale soon
  49. WTB: Left corner light 87
  50. Engine Problem
  51. help
  52. Interest in car.
  53. New Turbo Project/Parts For Sale (Long)
  54. maxima + rain = ****ty day
  55. FS/4 KYB GR-2 85-88 max
  56. Battery Keeps Dying
  57. Car & Driver: 83 Maxima Diesel Sedan vs. MB 300SD & Oldsmobile Delta 88
  58. crank shaft pulley
  59. Moderator - How do we post for a trade?
  60. Help! (Abbreviated version)
  61. Engine Problem -- long
  62. When you do your timing belt make shure that you do it right or this could happen!!!!
  63. Lets do the wheel thing...again.
  64. Transmission Slipping in 2nd gear
  65. few mod questions
  66. ***weird problem
  67. Rims for Sale Locally
  68. What are some of the causes...
  69. 1st gen. survivor in New England
  70. Doing 5 speed swap
  71. Egr Stem Broke
  72. Engine Bay Diagram?
  73. Superchagred 2nd Gen?
  74. 2nd gen vg33
  75. Ecu Codes
  76. Should i get this car?
  77. Ecu diagram or rad fan wire
  78. Rack & Pinion replacement
  79. grease in intake/tb?!
  80. 1st Gen Sedan (1984, Gas) For Sale - If You Don't Check The Classifieds ;)
  81. Injector recall ?
  82. Engine Control Fuse Blows...Engine wont stert
  83. Disable Factory Security?
  84. 2nd gen wont start
  85. 4th gen seat's
  86. Bigger brakes on 1st gen?
  87. Ye Olde Max of Yore to be retired, gauging parts interest
  88. anyone intrested in buying my max??
  89. in process of installin fuel pump
  90. I HAVE RETURNED..... now for my question
  91. My first beater
  92. Engine idle speed adjustment?
  93. So in spirit of my car breaking after meets:
  94. Got a vid clip of my car...
  95. Shifter cable
  96. 87 with Engine Whine
  97. oil leaking
  98. A few questions
  99. Automatic Transmission Installation
  100. Has anyone seen the new issue of Car and Driver?
  101. 1987 Parts F/S
  102. New pics of the 95
  103. How to remove right side half shaft??
  104. How did you put in your amp wire?
  105. Rusty water in my radiator
  106. The 2nd Gen King is back in business...
  107. Rear struts on 2nd gen.
  108. bmw antenna mod
  109. would these fit??
  110. 1st Gen parts - 1984
  111. Interesting find for doing projectors..
  112. engine or transmission at fault??
  113. Will this fit?
  114. Electronic help
  115. sWaP or get another car....?
  116. crankshaft pulley removal issues
  117. pwned
  118. Wow 140 dollars for nothing
  119. bent valve??
  120. THE clicking
  121. new max pics
  122. Tps Adjustment@i#@!*)$uuj
  123. Nice meeting all yall but I gotta go away....
  124. Transmission slipping?
  125. FS: Intake Plenum
  126. Reseting the ECU
  127. You guys have been great...
  128. New wheels for the daily driver.(56k dont think so)
  129. My intake...
  130. SE sunroof/moonroof on a GLE?
  131. Wagons
  132. Complications Of An 87 Nissan Maxima
  133. Spark Plugs
  134. New Nissan Purchase in the family
  135. Say It Aint So!!
  136. DJs 1987 Max of Traffik Blockin' NYC Crew
  137. like hids?
  138. Those going to performance nissan meet
  139. 2nd gen with a vg30et on ebay....
  140. Altima FSTB clearance and fitment issues
  141. Alright what is this?
  142. Tail lights el no workie
  143. Getting a cdplayer / speakers
  144. 18 inch tires...
  145. problem with stanza tb
  146. axles?
  147. Should I buy this car?
  148. Help with Stanza TB
  149. Pathfinder Intake Manifold
  150. Getting 60mm tb today!
  151. Which wires do I pull?
  152. hahaha
  153. Where can get a carpet kit?
  154. Found some pics...56k die in a ditch.
  155. Ok i need major help
  156. I got a question about a cracked wheel
  157. Tennessee Nissan/Infiniti meet!
  158. Received my new set
  159. Boring the INlet to the IM
  160. Exaust replaced BUT
  161. Screws stripped on it IMC
  162. Gear ratios for a 88 auto
  163. zparts wants 185$
  164. T-5 trans.
  165. How reliable are these cars generally?
  166. Question's Questions!?!
  167. Well im prolly trading the max...
  168. Front Sway Bar Bushing Size?
  169. Vacuum Hose Routing Assistance... please...
  170. wiring harness
  171. Interested in '85 200SX Mesh Turbo Wheels?
  172. boost controller & fuel system code
  173. msd ingniton??
  174. Wheel size for 84 rwd maxima
  175. suspension.....CCRRREEEEEAAAAKKKKK!
  176. Replaced rear inserts but I have a question?
  177. oi its back...
  178. Will this bolt on?
  179. MAF problem??
  180. Koni, F/S
  181. How do you guys think a wing would look?
  182. Quick question
  183. Chrome bumper trim...
  184. Do you have a 1/4 mile timeslip or time for your 1st or 2nd Gen?
  185. 84 Maxima Wagon Muffler
  186. a friend is thinking about buying an 88, what too look out for?
  187. Rats--literally. HELP
  188. Hard cold starts on the 87 getting worse.
  189. She's gone
  190. what bolts into 84 maxima?
  191. Possible F/S: Stanza TB
  192. steering rack rattle
  193. Timing belt
  194. (WTB)300zx ECU
  195. Well im buying new wheels....
  196. How to Pull ECU Codes on an 87?
  197. 2 Days to get a 1982 Diesel Maxima - California
  198. Where's the oil sending unit located?
  199. Look what I just bought!
  200. Only got 200 miles on a tank! O2 sensor?
  201. Fuel Pump
  202. my usual array of questions
  203. whats this frusterating part?
  204. Are all cars pre-wired for Drive Computer?
  205. strut tower bars...
  206. manual
  207. 5 Days 2 Hours to get a 1984 Maxima - California
  208. hu install
  209. yes finnally got some rims...
  210. Muffler inlet
  211. Does 88 tilt column lock in more than 2 positions?
  212. Crank Pulley
  213. 6 Hours to get an 84 Maxima - California
  214. fuel injectors
  215. ride
  216. exhaust gas, in car
  217. Auto tranny prob in 2nd gen
  218. Anyone have a turn signal for a 87 w/ cruise?
  219. 3rd Gen Guy Looking at 2nd Gen
  220. adjusting 1984 maxima MAF
  221. Coolant gushing out, disaster has finally struck, help me....
  222. 87 on the road again
  223. New thread for Maxwell
  224. clutch adjustment
  225. Fuel pump ordeal, need help.
  226. 86-88 intrax springs
  227. What is up with my max?
  228. Newest problem...
  229. altnator
  230. brake rotors
  231. Tailgate support struts?
  232. New Exhaust (on 1st Gen)... audio recording!
  233. Rhd?
  234. starter?? no power at all in car
  235. Car stereo wiring harness problems (previous owner cut the plugs)
  236. Factory service manual 1987+Haynes
  237. 87 se helppp
  238. Fuel pump? New tires in front or back? Heater fan? HELP!
  239. I want to buy a cold air intake...
  240. Parting out '87 Maxima
  241. crystal cut
  242. big problem !!!!!!!!!!!
  243. oil problem
  244. rough idle in D
  245. Just installed Ford Taurus cup holders
  246. saga of my 87
  247. Part Numbers
  248. wrinkles
  249. Check this ebay bid out.
  250. Look what I got!!!
