04-26-2012, 08:15 PM
Next I removed the weir metal contraption from behind the reflector bowl that had some wires attached to it and mounted to the bulb holder that was for the OEM HID system. Once I had the bulb holder removed I had to remove the notch that was used to seat the bulb in the correct position as well as grind down the h7 adapter for the MH1 to fit in the bulb holder.
Before w/ notch...
After w/out notch and h7 adapter fitted...
Projectors mocked up...
I had to address the yellowing of the headlights...sanding and polishing was not enough as seen below...before on the left and after on the right...
So I sanded down both sides of the headlight lens and had them clearcoated...
When cleaning the shrouds I mistakenly used an ammonia based glass cleaner and it stripped the shrouds so I ended up painting them but am actually glad I did.
All together...
My modified Denso ballasts from a IS300 donor...will make them look nicer in v2...
Since the OEM HID equipment were missing the back of the lights had a big opening so I made a panel for it. I have yet to paint them and find a grommet for the hole.
I never got any real output shots as I realized the cutoff was not as sharp as it should be...which is why I need to tweak the shields
NOTE: I originally used the rubber washers and grommets that came with the projectors but they introduced to many vibrations in the projectors so I took them out and now 95% of the vibrations are gone. What is left I attribute to the fact that the headlights aren't bolted in the fenders on the bottom of the headlights due to the tabs being broken, but I will look into this some more in v2.
04-26-2012, 08:18 PM
I will have more detailed pics when I crack them open this weekend for v2.
v1 done...
v2 will consist of...
Gatling gun 2.0 shrouds (bigger)
shroud centric rings
CCFL w/ a twist
color mod
fixed shields
v2.5 will be...
LED bulbs in highbeam area since I don't need stock highbeams anymore
Morimoto XB35 bulbs
will see if my Ford Fusion fogs will fit in OEM foglight housings
04-26-2012, 08:54 PM
GOT RETROFIT?
Points: 15,372, Level: 80 |
Nice job! Looks clean. Didn't I see these pics elsewhere though?
04-26-2012, 09:21 PM
I like your workbench  lol
Great job on the retrofit!! Very OEM'ish
__________________
IMISSMY2KMAXIMA
04-26-2012, 10:39 PM
Dude, how'd you do those probe headlights? Those come 4x6, right? Been trying to figure out a simple solution for my 240. Really clean job though.
__________________
89 Maxima GXE Daily Driver
Mods: Rear Disc Conversion, Front Strut Tower Brace, Brembo's all around (Slotted Front), SE Tails
92 240sx Weekend Warrior
04-27-2012, 04:25 AM
Chrisman287 most of them are in my build thread but I have had couple questions about them so I thought I would do a thread about them. I will have up some new pics today and over the weekend since I will be doing more work on them.
Ihavea2kmaxima as you can see that old ironing board is multi purpose. Sometimes the washer and dryer are turned into one also.
Dhunterx yea those are 4x6 housings. You should check out hid planet.com as they have a couple examples of retros using those. My way was simple but also those projectors were waterproof so I had no need to worry about the from exposed but I still wanted to make a lens for the light itself, but didn't have the car long enough after. All I did was bolt up the lights in the back then cut a piece of plexi for the front....found a hole saw the size of the projector and cut the hole in it. Not only did it act as a bezel to guide everything in the back but it also helped to stabilize the projector in front.
04-27-2012, 05:21 PM
Got the stuff today for v2. I already have a problem though, one of the shroud centric rings won't stay in the shroud so I guess I will have to do some modding to make it stay. The shrouds are bigger than I expected so I hope I don't have to trim them.
04-27-2012, 05:25 PM
GOT RETROFIT?
Quote:
Originally Posted by dna59
Got the stuff today for v2. The shrouds are bigger than I expected so I hope I don't have to trim them.
Just by looking at it, I'm pretty sure you're gonna have to trim them.
04-27-2012, 05:50 PM
I don't mind trimming the depth but I really don't want to have to trim the top or bottom of it.
04-27-2012, 07:19 PM
GOT RETROFIT?
I think they'll just have to be trimmed depth wise a little. You shouldn't have to touch the top or bottom.
04-29-2012, 12:03 PM
I got alot of work done today and will post up pics in a few.
Completed:
fitted and painted shrouds
modified and fitted shroud centric rings
rebuilt and preliminary tuning on projector
modified headlight housing to mount ballast under
04-29-2012, 01:06 PM
i like your work a lot dude! Good job.
I found it easier to retrofit my aftermarket ebay headlights, since with a little fiberglass and epoxy the existing bracket was easily modified to accept the new projectors.
Also i still retained the aiming ability of those aftermarket lights, albeit it was way crappy. I found it easier to raise the rear end of my car up than to aim the headlights down haha.
__________________
MODS:
BC Coilovers | Stillen FSTB | Progress Rear Swaybar | ES BUSHINGS | Subframe Collars | 10mm Front/ 25mm Rear Eibach Spacers | Unorthodox UDP | CC OBX Headers | NWP Intake Spacers | Cattman 3" Catback + Test Pipe | 3.5" WAI w/ LR MAF | PFTB | NWP Engine Torque Link | Shinjinduo Grounding Kit | 300ZX BBK | Ionic Dynamics Bodykit |Retrofitted TSX Projectors | Foglight HIDs |License Plate LEDs | Blacked out grills | Pioneer Avic-D3 | Interior LEDs | 5 SPD SWAP
BUY MY MISCELLANEOUS STUFF!!! CLICK HERE
04-29-2012, 02:34 PM
04-29-2012, 02:46 PM
04-29-2012, 05:05 PM
GOT RETROFIT?
Looks much better.
04-29-2012, 05:56 PM
05-01-2012, 02:33 PM
I got color but not as much as I wold like, minimal bowing, and a better cut off line than before. I think v3 will be FX-R 1.1s or 3.0. The ballasts wouldn't fit under the headlight when mounted and my headlight lens affects the sharpness of the cutoff. Even though they are clear the plastic itself is not in the best shape and not as clear as they should be.
ballast location...I also learnt that the foglights actually have a height adjustment screw.
CCFL inverter went under the headlight
crappy pics but will have more when I actually put them in...
05-18-2012, 06:49 AM
05-19-2012, 09:03 AM
Points: 15,779, Level: 80 |
looks really good dude
__________________
Quote:
Originally Posted by dared3vil0
Hey, The Kia forum called... They want you back.
MaximaOrg
Nissan Maxima
Paid Advertisement
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
