Go Back   Maxima Forums > Miscellaneous > Members Rides
Members Rides Post Pictures of your car here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-29-2009, 06:07 PM   #1
MZ's 325i sh*tbox build thread (long & LOTS of pics)
I've been pouring my heart, soul, and way too much money into my ****box E30, so I figured I'd share. It's not that cool, but I'm doing what I can to turn the car into what it deserves to be.
I've got a project thread on r3vlimited too, believe it or not this is actually the abridged version. Here's the story.
Almost a year ago the maxima met its demise which ended up being the best handling mod of all
Poor max
So I picked up a certain girl's 325i that was the only "i" 5 speed in town in my meager price range, here it was sitting at the DMV getting registered, no working heater or AC, no working tach, no working radio, wipers didn't work without you holding the stalk (all of that fixed soon except the AC which had no charge)
In front of a friend's house a day or so later
Interior was in good condition
First thing I did was a timing belt and water pump outside of my gf's place (no pics)
Then I started picking up stuff I found for cheap
3.73 (stock ratio) LSD, old, little noisy and worn out but axle seals seemed to be ok, does the trick with mobil 1 in it
MorpheusZero is offline   Reply With Quote
Old 10-29-2009, 06:08 PM   #2
And being me I had to have lights that worked well, smileys with european grilles (which really don't make much of a difference)
Smilies on the left, old sealed beams on the right
low beam
high beam
I tried out the SEM stuff on some faded plastic trim pieces, worked pretty well
Old 10-29-2009, 06:09 PM   #3
Painted some other faded trim and door handles
ECU out of a newer 325i (the "173" ECU, Motronic 1.3 instead of 1.1) running a cloned "mark d" tune and bigger multi-pintle injectors as the stockers are running very high duty cycle
UUC Swaybarbarians (bday present to myself)
Those were fun to install
Brembo blanks and Textar OEM pads (pretty good pads actually) all around, rebuilt front calipers
-#u(k- set screws, $25 craftsman impact driver ftw
Old 10-29-2009, 06:10 PM   #4
Magnetic field from metal on metal near ABS wheel sensor, who cares about rear brakes anyway right?
Old 10-29-2009, 06:11 PM   #5
[this is partially copied out of another thread, so it's not totally up to date]
Turns out I've had a mild blown head gasket for awhile, it reared its ugly head sometimes and sometimes it didn't. I started shopping around and figured maybe I could get a rebuilt head and stick a cam in it, but it turns out that would actually cost more than just doing an M50 swap.
Cliffs on the M50 swap:
M20 (in the car now), brand new with an intact head gasket: 168hp@5800rpm, ~165lbft@4000rpm
84x75 (2.5L), 8.8:1, SOHC, mechanical lifters (thus the sewing machine symphony), timing belt, cap/rotor
M50: 189hp@5900rpm, 181lbft@4700rpm
also 84x75, 10.0:1, DOHC, hydraulic lifters, timing chain, coil-on-plug
Modest improvement, but a newer motor, hasn't had the oil pan broken, has been maintained and it paves the way for the more powerful S50 down the road
Finally, after gathering parts for a few weeks, I started the swap this weekend, mainly since school has just started, I'm going to be swamped with work sooner rather than later, and I was running out of time.
Ironically, I only spent maybe 7 hours over the weekend (most else was preparing, loading everything into the car, etc). Here's what I've done so far.
Disconnected driveshaft/guibo
Removed selector rod
Removed radiator
Disconnected PS and AC hoses (AC didn't have much of a charge anyway)
Removed O2 sensor
Disconnected harness
Disconnected downpipes
Disconnected throttle/cruise control cables
Pulled tranny brace
Almost ready to pull the motor/tranny, just need to get the clutch slave, heater core hoses and possibly the shift rod.
The workspace (courtesy of a really cool guy in Buellton)
Draining coolant
Old 10-29-2009, 06:12 PM   #6
Fuh raze interior
How I left it
Old 10-29-2009, 06:12 PM   #7
After I pull the engine, there's a checklist of **** to do:
delrin shift carrier bushings/new selector rod/tranny bushing, bend selector rod
Amsoil 75W90 GL4 in the tranny
Lighten flywheel
New control arms/M3 offset control arm bushings for increased caster
E36 rack (3.2 turns lock to lock instead of 4)
relocate brake booster for intake manifold clearance/new vacuum hose
new fuel lines (old ones are cracked to **** and I just cut them)
On the M50:
remove oil pan, loctite oil pump nut, new oil pan gasket
New GRAF water pump w/metal impeller
Semi-synthetic 5w30 (got for $3/quart) and new oil filter
I'm guessing, realistically, it will take another 2 weekends to finish. [WRONG]
Old 10-29-2009, 06:13 PM   #8
Got a good deal done this weekend.
How I found her when I returned:
I started disconnecting the few things that were left
Got sick of the heater core lines so I just cut them
Look at that, it's got an oil cooler. Goodbye oil cooler (doesn't look like there are fittings on the M50 for this)
Finally! Just using the front bracket since I couldn't get to the rear hoist point. I wouldn't do this normally but others on r3v have swear by it, I only had one hook so I gave it a shot.
Removed the clutch slave while it was more accessible (couldn't do it while tranny was mounted)
I haven't gotten the obligatory "in the engine bay" pic because I've done all of this on my own. I'll try and get one, as it is after all obligatory.
Old 10-29-2009, 06:13 PM   #9
You can spot the bracket starting to bend, I figure most who've done it this way might not have pulled the long block/IM and tranny all using one bracket.
I kept it going anyway, my entire weekend would be wasted if I didn't (have no other hooks besides the one already on the cherry picker)
Success! I had to drop the chassis by a good 4 inches to clear the body.
Separated the G260
Hey, ***** clip! **** you! [it's called ***** clip since it's almost impossible to remove while the tranny's in the car]
Used the "hack saw" method of CAB removal [pretty self-explanatory, thread the saw through the 3-piece bushing and saw away]
Old 10-29-2009, 06:14 PM   #10
Used a bench vice and motor oil (I know I know) to press in the new M3 bushings. This one didn't really have the orientation quite right but I matched the other one pretty well, so at least it's symmetric.
Out comes the M50... First time I'd seen its pretty valve cover since I bought it
Up...
And away!
Bell housing assy was a pain to remove
Old 10-29-2009, 06:15 PM   #11
Two of the three bolts that stripped on me, I wound up just hammering a 13mm socket onto them
The flywheel that's going to say goodbye to a few lbs of padding
And the clutch... it's been fine, hasn't been replaced in awhile but has been pretty grabby. Then again I'm not sure how much material is normal, but there's not all that much left.
I'm going to do the pilot and throwout bearing anyway, think I should just get the full clutch kit? Looks like it's got some life left... but how much I don't know.
Anyway my camera ran out of batteries, I took a few pictures with the phone but they didn't turn out.
Few other things I did
Remove steering rack
Reinstall one control arm (although still wrestling to get the lollipop to thread, didn't get it "all the way on" the control arm)
Drain M50 oil and start installing accessories.
Old 10-29-2009, 06:16 PM   #12
Today
AKG delrin shift carrier bushings
These took SO much play out of the linkage, probably about 90% of the play.
Put the new rack in
Dropped it down on the new suspension
It seemed like the CABs froze on the control arms in this position, doesn't look good, but it's better than nothing.
Old 10-29-2009, 06:16 PM   #13
Oil pump nut looks good but I forgot the loctite, so we hold back.
After some brakekleen and a razor blade it's almost ready for a new gasket
My ugly mug, obligatory engine swap pic
Lightened flywheel, 12.5lbs
Old water pump and ****
Probably going back tomorrow
Old 10-29-2009, 06:17 PM   #14
Soo hit a few road blocks last night
First order of business was to relocate the brake booster. We'd have to drill new holes, shave away at some of the firewall and change the mounting position from the "arm" of the brake pedal to the pedal itself.
First we removed the booster, then we removed the pedal. We drilled the pedal, then cut off the "connecting arm" shaved it down and put it in like a spacer to give the new mounting surface more width.
Then we started drilling more for the booster. Ran into a big problem: on one hole (top passenger's side booster hole) we'd basically be drilling lengthwise into the pedal support bracket, and on the other side (top driver's side booster hole) we'd be relocating the bolt too close to the bracket.
Well, fawk. I don't really like where this is going, so I decided just to give up and get a different booster. I just don't like screwing with things that need to hold in order to make my car stop.
Anyway, next order of business was loctiting the oil pump nut and just making sure it never comes loose in general. I torqued it on a little too tight, put some red loctite on it and used a chisel to **** up the threads (can't really see in the pic) but I don't think it's going anywhere any time soon.
Old 10-29-2009, 06:18 PM   #15
Then the new gasket went on
Well, turns out we were missing two bolts
Couldn't find them anywhere, they weren't in the bag with the rest of them and they're the ones you can't get to when the G260 is bolted to the motor, so no flywheel installation or anything.
As a side note, I noticed M20 and M50 flywheel bolts were identical. Exactly the same.
Basically most of the day was spent pulling my hair out trying to figure out a way around the brake booster problem and trying to find those two oil pan bolts. Then I tried to reset the control arm bushings for more frustration and got nowhere. Need to get a thread chaser for one of the bolt holes, hopefully that will make it okay because otherwise I've got to go through the floorboards, and that's no fun.
Going to pick n pull today, hopefully I'll find an E32 booster/MC or something.
Old 10-29-2009, 06:19 PM   #16
So here's the yield from yesterday at pick the part
Got everything plus the C101 harness connector (that I need to make an adaptor for the M50) for $130
Glovebox in decent condition (on top of the old one that I had sitting around in my room because it was broken as fawk)
E32 B35 brake booster and MC with the weird "neck" design
And a nice crack-free dash
After I cleaned it up... now there are a few places that I scrubbed that seem to be discolored, maybe I need to treat the vynil or something.
That's it so far, now it's up to date. Car's in Buellton, might be able to make it up there next weekend if I'm crazy enough.
Old 10-29-2009, 06:25 PM   #17
Send a message via MSN to M1RAG3
Nice work...you have definitely put a lot of time and heart into your build and for that you deserve respect
__________________
My Car Domain Page ● Sarona Front bumper, Rear bumper, Fenders, Side Skirts, and Hood ● Projectors w/ TSX lenses and CCFL angel-eyes ● 8,000k HIDs ● Katana KR7 (Hyperblack) ● CMX Rotors w/ Axis Pads ● Tein S-Techs w/ Tokico HPs ● CustomMaxima.com FSTB ● Progress RSB ● NWP Thermal Intake Spacers ● BERK intake w/ AEM Dryflow ● Y-Pipe B-pipe, and Rear Section ● Custom Audio and Video ●
M1RAG3 is offline   Reply With Quote
Old 10-29-2009, 06:25 PM   #18
LA02MAX's Avatar
Send a message via AIM to LA02MAX Send a message via MSN to LA02MAX
Damn, I didn't even know your max was totalled! Very nice E30, though! I, too, am spending way too much time and money on my E36 325is! It was supposed to be just a DD, but it's turned into so much more. Can't wait to install all the new suspension bushings I have; mine are all reeaaaally blown. And you're right about the shifter bushings. Those made a massive difference in shifter feel; quite unlike my maxima's did.
What are your future plans with it? 5-lug and nicer wheels needs to be on the list (Yes, I'm evil and trying to make you spend more money). I hate the basketweaves that came on my car, but they're better than bottlecaps. :P
__________________
LTB, RSB, FSTB, H-techs and Illuminas, 6.5 gen wheels, 6th gen front brakes
PB: 14.338 @ 98.27 with a 2.300 60' stock.
LA02MAX is offline   Reply With Quote
Old 10-29-2009, 06:47 PM   #19
Quote:
Thanks bud.
Quote:
Yeah, was awhile ago. I can honestly say excessive understeer killed my max.
You don't know the MEANING of blown suspension until you've driven an E30 maintained by a woman it will all be replaced soon enough though.
Actually 5 lug setups are $$$$, and there are plenty of 4 lug wheels that I'd like. Personally I've got a line on some 15x8 Kosei K1s
Right now I've got a set of bottlecaps with all seasons and a set of 14x6.5 basketweaves with RT615s I picked up on the cheap. Not sure if I'll have the $$ for the Koseis or if the guy will even want to sell them any more when I'm ready to buy (he went 5-lug).
I'm also piecing together a GC coilover kit with shortened Konis (and probably some camber plates). Not sure if I want to go 5-lug yet, but after this I'll probably chill out for awhile since I'll be back to school-mega-broke mode.
Old 10-29-2009, 07:42 PM   #20
LA02MAX's Avatar
Quote:
Thankfully this hasn't happened with me yet...I do drive pretty psychotically... You had a really nice setup, too, with the SFCs and all. I actually rarely understeer..most of the time the rear tires break loose first and it's pretty scary in a FWD car. lol.
Yeah my car's at 198k right now and aside from the struts I just replaced, not a single part of the suspension has been touched...it's pretty bad, lol. Aggressive lane changes are noooot pretty.
mmmm Kosei K1's. I have my eye set on those as well. I'm not gonna lie though, an E30 lowered correctly on basketweaves is pretty damn hot. I hear you on spending too much, though...I haven't bought anything for a couple months cuz I made myself pretty broke before school started this semester on all the crap I bought for that car...most of which I don't even have time to install! lol. Cheap mods FTW, though. I did what you did and painted all the black stuff and used forever black on the side mouldings. Car looks 10 years newer.
__________________
Old 10-29-2009, 07:53 PM   #21
Addicted to the Org
maximized98's Avatar
Wow you have done a lot of work to it so far. Those are sure some fun cars to drive. Congrats on the work, I know you cannot wait to enjoy it
__________________
" It's more fun to drive a slow car fast, than to drive a fast car slow"
maximized98 is offline   Reply With Quote
Old 10-29-2009, 08:04 PM   #22
Send a message via AIM to bigpopaj369
wow man what an awesome build nice work!
__________________
BIGPOPAJ369
SEXIMA badge,black w polished lip rims,rain guards,SRI,painted spark plug cover,AE'd heads w/luminics bulbs,rewired yellow tinted fogs w/out glare guards,polarg blinkers/reverse/plate lites,tinted n rewired sidemarkers(blinker mod),painted interior trim,all interior lights to led,AB clock mod w/white display,red leds in climate control w/white display
bigpopaj369 is offline   Reply With Quote
Old 10-29-2009, 10:29 PM   #23
Bear > Wookie
DrunkieTheBear's Avatar
Send a message via AIM to DrunkieTheBear
God I am so turned on by your car.
__________________
2004 Pontiac Grand Prix GTP Comp G
|3.5" Intake Bpi/R2C|Ram Air|3.4" Pulley|180* T-stat|Headers|Corvette Brakes|SSC Lowering|KYB|LEDs everywhere|GXP parts|SE Parts|
Want a Plug and Play Harness for your Emanage Ult/Blue? CLICK HERE!
Quote:
Originally Posted by MOHFpro90 View Post
Thank you Dave. I love you Dave.
Quote:
Originally Posted by bigleman View Post
...so i had to get towed out of a ditch last night...
DrunkieTheBear is offline   Reply With Quote
Old 10-29-2009, 10:30 PM   #24
Bear > Wookie
if you repaint it in black, I would really hump it
__________________
Old 10-29-2009, 10:35 PM   #25
not bad, i'm thinking of getting an E30 aswell. are they as hard to work on as i've heard all euro cars are?...
__________________
99 Maxi: KYB GR-2s|Ksport springs|front ebay strut bar|hot air intake|I30 woodgrain panels|carbon rear window spoiler|ricer fart can.
FRIEND'S
DON'T LET
FRIEND'S
ROLL ON
ROTA'S
MaxiNone is offline   Reply With Quote
Old 10-30-2009, 07:25 PM   #26
I'm a Faulker
Conrad283's Avatar
Send a message via AIM to Conrad283
Kudos on the build ... Pretty involved, but it'll all be worth it in the end.
__________________
Conrad283 is offline   Reply With Quote
Old 10-30-2009, 09:15 PM   #27
o-mazing grace
EnervinE's Avatar
How much did the stock flywheel weigh/how much material did you get lopped off? I'm planning on getting a stocker resurfaced for my 5spd swap so I'm a bunch about it.
__________________
: Illuminas : Progress : Muranos : Vibrant FSTB : MEVI : NWP Spacers : Budget SS Y : Full SS catback :
I30 Auto-Dim Mirror & Armrest : Maglite Mod : AE Headlights : Red/Clears : 35% Tint : SE Conversion :
: LED'd interior : Sony CDX-GT31W & Speakers : Sony XT-100HD : RF Punch HE2 10" 800w : Kenwood 600w :
EnervinE is offline   Reply With Quote
Old 11-01-2009, 01:57 PM   #28
Yeah, I loved how it handled with all of that. I'd get the rear to come out just enough, but without lifting I'd never actually oversteer. There was a moment or two I've been sideways at about 80 though, that was fun
I only painted one side of the car actually I kind of wanted to do it the "right way" on the other side and remove the trim, we'll see when I get around to it.
Quote:
Fun like you wouldn't believe. Even fun to ride in.
I'm waiting with baited breath.
O RRY? I really like the lines of the car, but in terms of modded sexiness it's pretty tame I'd say.
Quote:
No. E30s are nice and simple.
Quote:
Thanks. And let's hope so.
Quote:
Stock it was about 18lbs, he took off around 6lbs. I got a good deal at $100. Generally machine shops charge about $65 an hour, and it's about an hour to shave a flywheel and another hour to balance it. Sometimes more complicated (dual mass, etc) flywheels can take longer. I've never held an A32 flywheel in my hands so I couldn't tell you how simple it was, but I'm pretty sure it's a single mass, and it's a similarly simplistic design.
Should be noted that resurfacing and lightening are two different things though. Lightening is removing as much non-friction material as you can, and resurfacing is shaving down the friction portion until it's even. Resurfacing generally takes a machine shop about an hour, $65ish.
Good luck.
Old 11-01-2009, 08:50 PM   #29
Nrw
Send a message via AIM to Nrw
You have great taste. Keep up the good work.
__________________
Nrw is offline   Reply With Quote
Old 11-01-2009, 09:29 PM   #30
Bear > Wookie
you got me looking at E30 M3's
If one was close and under 15k...the GTP would be gone in a flash...seriously
__________________
Old 11-02-2009, 10:33 AM   #31
Quote:
Will do, though there won't be any work done until this weekend.
Haha, M3s are awesome, but they're also a 4cyl. Go test drive a 325is. The sound of an M20 basically the auditory equivalent of sexy time with Scarlett Johanssen. Then you get a chip and injectors and Scarlett's a screamer.
Old 11-02-2009, 05:58 PM   #32
Offset Is Everything.
Send a message via AIM to MrDicks95SE
good god Nate... still working on this thing?? good luck dude.
btw, the Koni's are just fine... loose in the housings (a cut up 7up can fixed problem)
MrDicks95SE is offline   Reply With Quote
Old 11-02-2009, 07:31 PM   #33
Quote:
going insane having nothing to drive. It should all come together in the next week or two.
Awesome. Thought you said they blew out awhile ago? Glad to hear they're still truckin'.
Funny though, I never had any problems with rattling or noise in 'em.
Old 11-04-2009, 10:59 PM   #34
yeah the lower bolt holding em down was loose too. needed another thick washer. done done and done. just wish i had an alignment and camber plates.
id go insane with nothing to drive, public trans sucks here. i couldnt imagine how bad it is up there...
Old 11-05-2009, 01:44 AM   #35
Huh. I didn't torque the lower bolt down all the way because I had to cut it down a little and didn't want to strip it. It worked fine for me as long as I had the GCs, so for quite awhile.
Seriously I love the E30, tooling around in it was fun even with a motor in the trunk. I need something to drive even if it's just to get away from **** (and go grocery shopping), having nothing is pretty gay.
But like I said, fingers crossed, should be done soon.
Old 11-05-2009, 03:51 PM   #36
u should turn that thing into a track monster. gutted, caged, koni.GC, fuel cell, recaro's, takata 4pt, etc etc. it's already torn apart...
Old 11-07-2009, 06:32 AM   #37
Send a message via MSN to Professor Send a message via Yahoo to Professor
I love all the Info and Photos !
__________________
Eibach Springs|HIDs|20% Tint|Custom Stereo|Custom LED Interior|GAB|Brembo Sport Drilled Rotors|Hawk Hps pads |SE Tails|AE Headlight Coversion
SHIFT_auto rolling
Professor is offline   Reply With Quote
Old 11-09-2009, 12:22 AM   #38
Alright, did a lot this weekend. Here she was again, waiting for me.
I got started repairing the threads for the control arm bushing bolts, here's the tap after going through one of the holes. Shavings-a-plenty.
After re-tapping both holes I got the bushing on in 10 or 15 minutes:
Then I got working on the brake boosters. Here's the original booster:
About 5 1/4" from firewall to the center of the pin hole.
And here's the E32 booster, I removed the nut and backed the coupler up all the way on the threads to make it as short as possible.
5 3/8". I tried it like this, it fit with some ingenuity but it had preload (with the brake pedal in the non-depressed position it was loading the booster) and I wanted to do it right.
Old 11-09-2009, 12:23 AM   #39
The E32 coupling bracket worked fine with the E30 pedal and pin, just used some washers for a tight fit.
Turns out, though, that the E30 coupler fits on the E32 shaft just fine. So here was the final setup, plenty of room for adjustment and I didn't have to worry about loctiting it so it didn't back out.
Booster's in the car, connected the brake lines to the MC, cut the little nubby for the clutch master cylinder and connected it.
Great, I've got to use my old pilot bearing. Check out how much bigger the inner race of the one I ordered is--must be some discrepancy in part numbers or something.
So I cleaned the old one off, cleaned and heated the center of the flywheel and stuck the sucker in there.
Old 11-09-2009, 12:23 AM   #40
Here's the clutch and pressure plate
Brakekleen'd em up
On goes clutch and pressure plate (centering the clutch was real fun)
It was about 1AM and the old cherry picker was gone so I finished off the night with a new tie rod.
Still can't believe these things are 6 bucks when the E30 plates are 1
There, had to use vice grips for the final tightening, used loctite 242 for the hell of it.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
