Go Back   Maxima Forums > Miscellaneous > Members Rides
Members Rides Post Pictures of your car here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Closed Thread
Thread Tools Display Modes
Old 06-19-2009, 08:30 PM   #1
'Trynna' is not a word
mtrai760's Avatar
Build stage #2 3.0 S/C to N/A 3.5
This is going to be a worklog. Updates will be posted when available and time permits. I'll open to comments once I am done.
Original build, which never really ended... 98 Maxima 5spd with a couple mods...
Now moving on:
S/C is being removed, never a problem with it, just a personal choice. It is going to a good home locally.
New setup-
Engine:
VQ35 from a 2002 Max, approx 60k miles
S/M Camshaft, IACV & Pathfinder TB adapters
Revup Camshafts
ARP Rod bolts
New water pump
New tensioners
VQ30 timing components
PR CAI
Underdrive pulley
Cleaned/balanced injectors
Port matched upper/lower intake manifolds
Mocal thermostat/oil cooler
Transmission-
Quiaffe going into my spare transmission with all new bearings, seals, and syncro's
Southbend Clutch stage 3
New transmission mount
Misc work to be done- Replace all parking brake cables, redo stereo and wiring, replace steering rack bushings
Keeping my Cattman headers, and will be using the EU to tune the new setup. Everything else should be staying the same. Everything on this car has pretty much been replaced at one point or another.
Current mods that are staying:
Suspension:
Tokico Illumina struts and springs
ES bushings
Progress RSB
Brakes:
Willwood 12.6" front BBK
Hawk HPS rear pads
Stainless lines all around
Transmission:
Quiafe LSD
B&M short throw shifter
Exhaust:
Cattman Gen 3 headers
Apexi World Series Exhaust
Started pulling everything apart tonight:
Waiting for its new home and toys...
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline
Old 06-22-2009, 10:25 PM   #2
mtrai760's Avatar
Been taking my time since I have the flu. Pulled the transmission tonight....
Old clutchnet clutch, will be coming out for a new unit:
Pulling a diff Jay25 style. If you don't know, you don't know...
Quiaffe all pulled out. Gotta pull the ring gear and it will be going into the new transmission. Gotta keep teh baller diff!
__________________
98 SE - VQ35
mtrai760 is offline
Old 06-30-2009, 06:30 PM   #3
mtrai760's Avatar
Old engine out:
Fun with timing components:
Revup camshafts installed:
__________________
98 SE - VQ35
mtrai760 is offline
Old 06-30-2009, 06:32 PM   #4
mtrai760's Avatar
Outer case back on:
Gotta use the old PT clothes for something... hooah!
ARP rod bolts installed, gotta torque 'em three times each!
Starting to look like a motor again:
__________________
98 SE - VQ35
mtrai760 is offline
Old 07-02-2009, 05:10 PM   #5
mtrai760's Avatar
Tapping the upper IM for EGR:
Engine is back in the car!
Old transmission internals:
Transmission all cleaned up and ready to go in:
__________________
98 SE - VQ35
mtrai760 is offline
Old 07-02-2009, 05:12 PM   #6
mtrai760's Avatar
Fidanza flywheel:
New Clutch - Southbend stage 3:
__________________
98 SE - VQ35
mtrai760 is offline
Old 07-02-2009, 05:12 PM   #7
mtrai760's Avatar
Installed:
__________________
98 SE - VQ35
mtrai760 is offline
Old 07-02-2009, 05:19 PM   #8
I'm needing a caw
Jeff92se's Avatar
Did you have to reshim the cam buckets after the cam install?
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline
Old 07-02-2009, 11:17 PM   #9
mtrai760's Avatar
Quote:
Nope. One of them was close, but I was able to switch a shim and get it where I was comfortable with it. Glad I had a few sets of feeler gauges.
__________________
98 SE - VQ35
mtrai760 is offline
Old 07-03-2009, 10:12 AM   #10
192.168.1.1
gtr_rider's Avatar
Awesome thread.
__________________
VQpower.com
Need work done:
Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
gtr_rider is offline
Old 07-03-2009, 11:03 AM   #11
You can't friend yourself
Kevlo911's Avatar
I like this new clutch brand I never heard of. Their website is very informational. Let me know how it runs with the 35, I might scoop one up.
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline
Old 07-04-2009, 09:40 AM   #12
mtrai760's Avatar
Thanks guys. I'll post a full clutch review once I get some miles on it. I'm hoping to have the car running again on Sunday.
__________________
98 SE - VQ35
mtrai760 is offline
Old 07-06-2009, 07:26 AM   #13
mtrai760's Avatar
As it now stands:
__________________
98 SE - VQ35
mtrai760 is offline
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
