Am I Projector Crazy?
Originally Posted by Nissan 6
Damn thats really nice. How well do they light up the road?
Closer shots of what, naijai? Let me know what, and I can take more pictures.
Originally Posted by Tatanko
Don't know yet, installed them earlier this afternoon and it isn't dark yet. I'll let you know tonight. I assume you mean the fogs. The headlights light up the road like no other, I already know that
Originally Posted by MorpheusZero
I assume you got the CE fogs?
It actually looks much better than I thought it would. Good job.
CE was out of them, these are ebay specials.
Pat, looks very good. How about some closeups with the fogs on, fogs off etc. Indivitual side shots so we can see the mounting/ installation etc.
Originally Posted by naijai
The fogs how they are mounted and look
Originally Posted by 99grnmaxgxe
Nice pics, how did you get your sidemarkers not to light up? Just took out the bulb?
Originally Posted by BlueC
Don't tease us with far away shots.
And a few shots with the fogs off and if u re-wired them with just the fogs on too.
Originally Posted by Big_E-Dog
i think you are but i feel your pain....
Thanks again for all the compliments guys. More pictures to come tommorrow!
Oh, and to Nissan 6, about the light output: it's not too bad. Roughly the same as stock in terms of brightness (but then again, it's rated at the same 55w). In terms of beam pattern, though, it lights up farther ahead of you (compared to the measly 4 or 5 ft. in front of the car stock) and lights up a good bit wider. The beam pattern is overall excellent for $20 ebay lights. I think they would benefit greatly from some 3000k 85w bulbs and a better power source.
The link to my exact auction:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Basically, just look for the seller texassizedeals . Looking back at the auction, the pictures on the auction are so terrible. The lights look gray-ish in that picture and plastic-ey, but they are flat black and metal in real life.
Originally Posted by M1RAG3
The projector fogs look good
Yes I meant the new fogs. But 20 dollars what a deal!! At least theyre a little better but nice job.
Originally Posted by Karim
$20 eh? i hope the lenses don't get cracked from road debris. Did you think about retro'ing those fogs into some OEM fog housings?
Are you on HIDPlanet by chance?
Yeah, I'm on HIDPlanet. I don't post much, though...mostly in the for sale section. Same name as on here.
Originally Posted by Kevlo911
Interesting. My 6 month project might be finished today or tomorrow
OEM housing and yellow lexus projector...
Next step should be to build a stock colored grill/bracket to go around the light so it looks stock.
Did you splice into the stock wiring?
Basically all I did was cut the stock wiring plugs off, and then the way the wiring was on the fogs made it very simple. The positive had a little hole thing (kind of like a crimp connector almost) that I just stuck the wiring into and crimped and then the ground had the "loop" connector you're supposed to bolt to something that I just wrapped the ground wire through a couple times. Taped it all up and that was it. I may buy some wire loom to cover everything up, though, the wires look far too exposed
Ya cover the wires. I would definately paint something either black or body color and it would look great.
It started with AE headlights, then I got the black corners to match, and the stock fogs were one hinderance to keeping the theme going. So now that I have a chance to darken that up a bit I'll take it. Still need to AE my corners, too bad I'll have to wait and have someone else do it because I'm too afraid to open up my corners myself after a bad experience
You know, you should get the mesh, then put a screen like they put over grass to stop the weeds from growing right over that, that would give a nice look and you could get it the right shape.
Any wall pictures?
They aren't true projectors in the sense of having a nice cutoff. Keep in mind these are $20 ebay lights They don't have a true cutoff, but above a certain point they don't have any glare or anything really (much like halogen headlights). They do, however, do a half-decent job of lighting. They just need to be brighter, and that remedy will come fairly soon in the form of 100w 3000k bulbs.
BAHAHAHA, my projector fogs are better too bad one lens is already cracked.
I think you should get some CF for the mold.....hehehe.
Actually that would be stupid. Unless you painted it.... well it would still be sort of stupid.
How about a wall pic with the headlights off puhleaze.
