Key fob window roll UP feature ???
Old 08-08-2011, 11:29 AM
Nugent20's Avatar
as most of you know when you hold the unlock button on your keyfob for more than 3 seconds your windows roll down (if you didnt know, youre welcome ) and the only way to roll them up outside the car is by inserting the key in the door and holding toward the lock direction for a few sec's.....
my question is: can you add a relay/auxiliary device to roll UP the windows from the keyfob? Anyone done it? or even thought of it?
NGK
Nugent20 is offline
Old 08-08-2011, 11:32 AM
phatboislim's Avatar
this work on 5th gens?
phatboislim is offline
Old 08-08-2011, 12:16 PM
Nugent20's Avatar
Im pretty sure it will, try it. Also, found a link from another forum from one from KP -
http://www.kptechnologies.com/products.php#/17
NGK
Nugent20 is offline
Old 08-08-2011, 01:05 PM
Joeker82's Avatar
Didn't work on my car? Could it be because I have a remote starter?
Joeker82 is offline
Old 08-08-2011, 08:13 PM
Nugent20's Avatar
yea probably why. It works with the factory keyfob (remote) however, if you bought a good aftermarket remote start/alarm like DEI then you should be able to add an auxiliary up/down feature pretty easily
Nugent20 is offline
Old 08-08-2011, 11:34 PM
VQ'rInWLA's Avatar
hmm gonna give this a shot on my next smoke break
VQ'rInWLA is offline
Old 08-10-2011, 03:02 PM
Nugent20's Avatar
any luck VQ? I honestly forget if my '96 did it- thankfully the "new" '06 does!
Nugent20 is offline
Old 08-10-2011, 04:34 PM
VQ'rInWLA's Avatar
Didnt work for me
Old 08-10-2011, 07:13 PM
pahanorlando's Avatar
Works on my 02 i35. Thanks a lot!
pahanorlando is offline
Old 08-14-2011, 02:01 PM
Jaidon05's Avatar
Didn't work for my 01
Jaidon05 is offline
Old 08-14-2011, 04:41 PM
MaxMike93's Avatar
Doesn't work on my 2000 either.
MaxMike93 is offline
Old 08-15-2011, 10:04 AM
jglaw's Avatar
On my '02 I35 when I try this it starts to roll up but then stops. It acts as if something is blocking the window (like the fail-safe for the auto-up feature).
Any ideas why this may be happening? Nothing is blocking its path when I try this.
jglaw is offline
Old 08-15-2011, 07:14 PM
locknuts27's Avatar
I need to check this out for my ride!
locknuts27 is offline
Old 09-13-2011, 07:25 AM
Rsprince89's Avatar
My girlfriends car is 2000 maxima SE and hers rolls down and up with the key. I have a 2008 and mine rolls up and down with the keyfob and using the key in the door
Rsprince89 is offline
Old 10-11-2011, 08:54 PM
Infi30t's Avatar
Our Lexus is the same. You can roll the windows down with the remote, but to roll up, either turn the car on or put the key in the lock and turn it towards the lock direction...
Infi30t is offline
06-06-2017 02:01 PM
Fbana41
08-29-2016 12:18 PM
salty318
09-29-2015 01:21 PM
Quick Reply: Key fob window roll UP feature ???
