I popped my bose sub .....
My bose sub needs to be replaced since I popped it while blasting some track that I shouldnt of.
I can find some 2002+ I35 bose subs on ebay for about 200-300 bucks ... my question is, how easy is it to install it ? Im not a pro mechanic, I dont really work on cars unless its something very simple, so what do you guys think ? can a noob tech like me install it ? or do I have to take it in to a shop ?
When something's a PITA to do I usually remember it vividly but since this was rather forgettable it must not have been too bad, LOL.
For 200-300 bucks, why not buy a nice Kicker or Pioneer sub to replace the factory Bose one with? Something a little more durable with a urethane cone that will sound smoother at high volumes, as well as give you better response all around.
Just pop it into the factory mounting spot. I'm sure the factory amp will be able to push it just fine.
Unless the sub in our cars is an open air baffle like the ones in the Z?
Replace with new
OP,
I dont think an aftermarket will work because a Bose system is based upon a one ohm setup. I have wondered for awhile if A 2 ohm sub would be compatible?
I worked in car audio right after HS (10 yrs ago) so im not sure on these newer Bose systems.
At any rate, when looking at your $300 pricetag I would suggest to buy a quality aftermarket sub that is 2 ohm, try it with the bose amp, and if it doesnt work Buy a small aftermarket amp and you'll effectively have spent the same or less and have a superior quality setup that isnt 9-10 years old.
Good luck and keep us posted
Before I went with a conventional sub + box in the trunk in this car, I used a Kicker Free-air 8" sub in the stock sub location. The sub I bought even lined up with the mounting holes for the BOSE sub. I never entertained the idea of using the existing amp, instead choosing to use a small aftermarket amp to power the free-air sub.
It sounded OK, probably better than the stock sub, but ultimately didn't satisfy my tastes, and eventually replaced it with what I have to this day.
You're probably right, Using aftermarket subs with the stock amp wont work right. Its incredibly easy to tap into the existing sub lines and convert them to RCA for an aftermarket amplifier though (bonus-no rear deck rattle). I put dual 12's in mine and couldn't be happier.
I believe that '02-'04 are the same. The sub amp is actually part of the sub. It's contained in the black plastic piece mounted on the bottom of the sub driver. IMO, it's a P.O.S little digital amp. I've had mine apart to resolder as it cut in and out.
Do you remember how long it took you ?
I only removed the amp/crossover part to resolder it. But it was easy. Just have to lay in the trunk and unplug a couple of wire connectors and 3 screws. To get the driver/entire unit out, I believe you have to pop the grille from the inside and remove the screws from inside. It would likely take 2 people to re-install.
My remove-resolder-install fix took less than an hour.
Although, my 8" polk db840 sounds 10 times better than my stock bose sub. It doesnt hit the really low freq's. You guys have any idea on how to seal this up. I ordered a XTC baffle that might help a bit!?! But, ultimately I think I'm ghoing to have to build a box that mounts under it for .30 cu ft of air space....Thoughts?
Hey can someone help me out please. I just installed a after market indash clarion navi/dvd with the harness attached and I'm not getting base at all. What seem to be the problem?????? I was told to cut the RCA plug behind the radio and hook it directly up to the radio. IDK
Unclejunebug
04-02-2016 05:42 AM
