Coolant level drops within days. . . .
Old 07-27-2010, 04:38 AM
Chester86's Avatar
Hi folks,
I just replaced my radiator after I noticed a leak from the crack. I thought this was a simple procedure, but . .guess not. Now, I start to notice that the resovoir drops in coolant level within a few days. I check frequently after a good drive to see if there are any leaks within the hoses, clamps, or any area. Still no luck and the coolant level continues to drop. Does anyone have any suggestions? I read another post stating it might be the water pump? Is there any way to check the functionality of the water pump? thanks folks!
Chester86 is offline
Old 07-27-2010, 07:29 AM
phatboislim's Avatar
weak head gasket? have you checked your oil? do you smell any coolant while driving or when you are under the car? locate the water pump and see if its wet around it
phatboislim is offline
Old 07-27-2010, 05:38 PM
Chester86's Avatar
I do smell coolant after driving and it does smell while I drive. But, after a drive I never see any visible leaks under the car or around the engine bay. If a water pump doesn't work any more is it likely to cause a leak or evaporation of the coolant?
Old 07-28-2010, 05:22 PM
Col Ronson's Avatar
i seriously doubt its a head gasket. Those problems are almost nonexistent on a VQ. My coolant level dropped drastically one day, but i was overheating cuz the fans had failed. It also could be your water pump is leaking?
Col Ronson is offline
Old 07-28-2010, 08:23 PM
soto2635's Avatar
water pump???
soto2635 is offline
Old 07-28-2010, 09:36 PM
Look and see if you're leakng any coolant from the passenger side near the front wheel. The water pump is around there.
ChrisMan287 is offline
Miket2006
03-01-2021 03:55 AM
mclasser
22
11-12-2020 01:58 PM
06-06-2017 02:01 PM
maxima-junky
10-07-2015 06:13 PM
Quick Reply: Coolant level drops within days. . . .
