Transmission Fluid?!?!
Old 10-12-2009, 03:27 AM
Chester86's Avatar
Hi folks,
It looks like its time for me to change my transmission fluid. I noticed a slight shuttering when it shifts now, it is not as smooth as the early days of owning this car. I was just wondering what the BEST transmission fluid is for a 2000 Infiniti I30 with roughly 130k miles. It looks like I will be changing the transmission fluid and filter while down there. Any insight would help! Thanks!!
Chester86 is offline
Old 10-19-2009, 10:02 AM
sprale's Avatar
My y2k i30 has just 100k miles. I use Castrol Import Multi-Vehicle ATF (10 Qts) when doing mine. I'll probably set the schedule for every 30k miles for a transmission fluid change, but not a full flush. I put most miles behind me on two wheels, the i30 is there for really bad weather or when I need to drop off or pick up the kids.
sprale is offline
Old 10-19-2009, 01:57 PM
大陆弟弟
n3985's Avatar
Amsoil ATF is the best $ can buy, get it from talkinghorse for best price.
n3985 is offline
Old 10-20-2009, 07:07 PM
Col Ronson's Avatar
i use mobil 1 synthetic ATF. available at any autoparts store.
you can mix it with any other type of ATF.
Col Ronson is offline
Old 10-26-2009, 10:16 AM
BlueFusion6851's Avatar
Dexron III ftw.
BlueFusion6851 is offline
Old 10-26-2009, 05:12 PM
sascuderi's Avatar
Me too and the shifting improved
sascuderi is offline
Old 11-15-2009, 10:26 PM
Malibu Jim's Avatar
Strange.....doesn't anybody use Nissan transmission fluid?
Malibu Jim is offline
Old 11-16-2009, 10:45 AM
ZGadson's Avatar
Nissan will charge tripple what it's worth. And if you're doing a fluid change, this is a chance to upgrade to a higher performance fluid. You wouldn't want nissan fluid anyway. It may be made specifically for Nissan transmissions, but there are better options if you do your research.
ZGadson is offline
Old 11-18-2009, 01:55 AM
Chester86's Avatar
Looks like I am going to shop for the mobile 1 synthetic ATF. Thanks guys!!
I jacked up my car because I noticed oil stains on my driveway. Looks like my car is leaking oil from the oil pan gasket and the plug. Also, I saw oil spots near the transaxle. Here is a sample of what my winter maintanence checklist looks like
-Flush Transmission Fluid (Mobil 1 ATF Synthetic)
-Replace Oil pan gasket and plug
-Replace Driver Side Axle (CV boot ripped)
-Find out where that leak is coming from
Pics are on the way . . . . .
Any suggestions where I can get a good quality axle from?? Thanks folks!!! Let the work begin!!
Old 11-18-2009, 01:56 AM
Chester86's Avatar
By the way,
Is there a filler plug for the transmission fluid?? Or does it go through the dipstick opening??? Thanks!!
Old 11-18-2009, 09:15 PM
ZGadson's Avatar
Off topic, yes, but I've heard that if your transmission might be having issues, a flush could make it worse? (I don't see how, but insight on this would be nice.)
Also, if I'm not mistaken, there should be another plug for the tranny fluid aside from the dipstick opening.
ZGadson is offline
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
Pied
09-26-2015 03:29 PM
Quick Reply: Transmission Fluid?!?!
