Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-14-2009, 08:04 PM   #1
Send a message via MSN to below90hz
SES, TCS & SLIP lights - car sputters in cold weather
My 2000 I30 currently has the SES, TCS & SLIP lights all on, all the time. Took it to the stealership and they said it was the ignition coil. Replaced all 6 myself in 15 minutes, and it DID stop idling rough, but the lights never went away, nor did the "jerky" sputtering when I first start the car in cold weather. AND it did not pass the emissions test.
I tried unhooking the battery over night, it did not reset the lights. My mechanic tried to reset the codes with his machine, no dice there either (although he did pass the car even though it actually didn't pass emissions). I've also had to replace my MAF 2 years ago, and an ignition coil a year before that.
I could care less about the lights, but my TCS really is off and it will not pass emissions again. That I DO care about. Something is causing my ignition coils and MAF to fail, and I;d like to get to the source of the problem instead of replacing the MAF and coils every year. Anybody have an idea what the problem might be?
below90hz is offline   Reply With Quote
Old 07-15-2009, 11:40 AM   #2
Willing to learn
oldngivout's Avatar
You must give us the code number generated by the SES lamp, otherwise we can't help you. Or you could search for it yourself.
__________________
Unless you do it exactly like I did, your results may vary.
oldngivout is offline   Reply With Quote
Old 07-15-2009, 02:12 PM   #3
oh. yeah that would make sense, I'll post some codes as soon as i can get out to autozone. thanks
Old 07-15-2009, 04:08 PM   #4
Okay here's the codes:
P1320
P0420
Could catalytic converter be causing all my problems?
Old 07-16-2009, 06:49 AM   #5
Willing to learn
oldngivout's Avatar
Three things going on here:
P0420 code is Bank 1 catalyst inefficient, there is a TSB on that one. Search the 5th Gen forum for lots of info.
P1320 is ignition signal, usually associated with the coil packs. However since you have already replaced them, you should look at other sources, such as the wiring and the crank & cam position sensors. You DO have NGK plugs in there, don't you?
The stumble at cold start is probably the upper intake gasket leaking. It will "cure" itself after the engine warms up, but will eventually need replacing to finally fix the issue.
And no, the catalytic converter is not the cause of the performance problem, but you will never pass emissions until the P0420 is resolved.
__________________
Old 07-16-2009, 02:28 PM   #6
Ok searched the threads for the TSB on 0420, sounds like I def need a new catalytic converter. The guy at AutoZone showed me the part I needed, it looked like this:
http://cgi.ebay.com/ebaymotors/NISSA...Q5fAccessories
Is that the right part?
As for the 1320 code, I'm not sure what NGK plugs are, soooooo...what are NGK plugs?
Thanks for all your help,
Ethan
Old 07-16-2009, 02:59 PM   #7
Willing to learn
oldngivout's Avatar
You didn't search hard enough evidently. The Ebay cat is NOT the one for the P0420 code. Don't buy that one. The Bank 1 cat is in the y-pipe. The entire y-pipe must be changed out. I think it is a dealer only item, maybe not.
As for the spark plugs, NGK is the original Nissan brand used for optimum performance. Bosch double platinum, for instance, will run like crap in your car.
__________________
Old 07-16-2009, 05:30 PM   #8
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Some cars have an oversensitive ecu software problem and there is a tsb for it, other times its caused by the cat itself, and then other times it's a faulty o2 sensor. To avoid people having very expensive bills, I just drill out some anti-foulers and put them on the rear o2's when I come across P0420's & p0430's on a 5th gen, it will work for all three possibility's and be cheaper than any one.
__________________
Gatorade on my keyboard FTL.
5th & 5.5 gen VLSD Auto transmissions for sale, PM me.
Cheap VIAS block plates
Dual-mass 6-speed flywheel resurfacing available!
NX wet kit w/digital gauge $400 shipped
KRRZ350 is offline   Reply With Quote
Old 09-07-2009, 08:14 PM   #9
I had a similar problem with my lights on my '02 i35. It actually ended up being the cam & crank sesnors that needed to be replaced. ~$500 for both @ the dealer.
__________________
he Internet wasn't designed for ridicule. It was invented so researchers could share comman data sets at University. It was I tell you.........it was. --Homer Simpson
Keepin it real for the SA!
AcuraLegend is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
