Infiniti I30/I35Similar to a Maxima, yet not really a Maxima. Discussion forum on Nissan's luxury model, the Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Anyone know how to disable the motion lockout in the OEM NAV system? Is it a switch in the VSS line ? Or do I have to find and ground the brake signal ?
Check the compatibility list, it may very well not work. Chances are just that he's not tested it, though.
Quote:
Originally Posted by Kevin
going to give it a shot, I have the switch and the wiring. Question - anyone know which wire from the back of the NAV harness is the VSS line?
VSS line is pin 14 on the back of the nav control unit, purple/red wire.
Note that the navi may use the GPS in addition to VSS at normal travel speeds, the FSM doesn't really clarify which speed input it uses to lock out the screen.
__________________
Quote:
Originally Posted by 2damax
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
Thanks Pmohr,
Will have to try this out this weekend and report what happens. IF it works like my other car it should give the passenger a set period of time to enter the destination before you have to re-trip the switch. I will probably mount a switch in the ashtray or something.
the OEM system uses the VSS line in slow trafic to update your point on the map. the GPS is used once you get moving.. like on a highway... so if VSS not connected then your car on the map will be off..
__________________ WTB: 00-01 shifter linkage/shifter, front mud flaps a32 or a33, real speaker grill (a32), white spoiler led bar, i30 cleared rear brake lights,RPM switch, Side Skirts (paradox/ionic
