Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-19-2009, 07:29 PM   #1
Dash Florescent Light is failing! Help!!
Has anyone had to replace/repair the florescent lighting in their dash? The left side of mine is getting dimmer and dimmer, and at times I can hardly see the speedometer/trip meter/gas gage. The only time its brighter is when the inside of the car is hot.
Anyone else have this problem? What’s the fix?
__________________
sascuderi is offline   Reply With Quote
Old 05-22-2009, 11:50 AM   #2
I'm kinda having the same problem too...I'm trying to figure if LED's, or if an LED strip can replace the florescent tube.
__________________
tjmoney's 2001 Infiniti I30
Operation BLUBYU coming soon...
tjmoney87 is offline   Reply With Quote
Old 05-22-2009, 05:30 PM   #3
I was wondering the same too. I've checked on all the online parts site and they don;t seem to sell, or even mention, a replacement bulb.
Do you think its fixed to the cluster and not replaceable?
Old 05-22-2009, 11:53 PM   #4
Got Projectors?
MetaOrbit's Avatar
Send a message via AIM to MetaOrbit
I've not actually looked at it, but I wonder if it's the same type of part they put into LCD screens for backlights?
You might see if you can pull it apart, take it out, and compare it to photos of other backlights online and see if you can find a suitable replacement.
__________________
:: John ::
2002 Infiniti I35 Sport
"Teach a man to fish..."
MetaOrbit is offline   Reply With Quote
Old 05-23-2009, 12:49 AM   #5
I've looked at it, it appears to be the same size as the back-lighting in laptops, but it appears it can't be replaced...If I can get my hands on another cluster, I'll try an LED strip. I've contacted my dealership (Infiniti of Memphis) about this and they want to replace the whole cluster. To me that seems like overkill for just a florescent tube...
__________________
Old 05-23-2009, 11:07 AM   #6
Got Projectors?
MetaOrbit's Avatar
Quote:
Just curious - why can't it be replaced? If it's soldered in there you should be able to de-solder it, or is there something else I'm missing?
My thoughts on the LED strip are that if you were able to replace it, I worry that you might not be able to dim it.
__________________
:: John ::
Old 05-23-2009, 07:09 PM   #7
I took a look at it again this morning, that tube is stuck in there...plastic covers the terminals so it's not coming out of there. Wish I had my camera handy when I took it apart to show... The LED strip hopefully will lighten/darken with the rheostat, I was going to tap the cigarette lighter for power.
__________________
Old 05-25-2009, 10:21 AM   #8
If you tap into the cigarette power then won't it always get full power and not dim when the headlights are turned on?
If you do fix this problem using an LED strip, please post a how-to!!
__________________
Old 05-26-2009, 12:34 AM   #9
Yeah, I forgot about that, I was looking at a Maxima FSM...I'll try to find a source to tap with the ignition switch in the ON or even the ACC position...I I have a LED strip on the way. If I can get this to work, I'll surely post a how-to...
__________________
Old 05-26-2009, 05:39 AM   #10
Got Projectors?
MetaOrbit's Avatar
I hope so. In my [admittedly limited] experience, LEDs don't like to dim very much, if at all, unless you're using something like a PWM.
__________________
:: John ::
Old 05-26-2009, 08:12 PM   #11
Quote:
I don't know if that is 100% true. I replaced the bulb in the clock with an LED and it dims just fine.
Sure would like to fix the dash issue. Can't read the left side of the dash unless it's real hot in the car. Then the left side lights fine!
__________________
Old 05-27-2009, 11:07 AM   #12
Got Projectors?
MetaOrbit's Avatar
True, my clock LEDs dim as well. I guess I was thinking about the dimming before turning off on my door and dome lights (both swapped with LEDs) which has pretty much disappeared.
__________________
:: John ::
Old 05-27-2009, 07:32 PM   #13
Yes true, the LEDs in my door and dome no longer dim and just go out.
Old 06-01-2009, 11:49 AM   #14
I dont think its the bulb that is causing the problem. After much trouble shooting replacing parts from a donor cluster, it is the board in the back thats the problem. The bulb is replacable but not sold. the only way to get it is with another cluster.
If you replace the board it will fix the problem but the mileage will be wrong.
__________________
01 I30- SFC's, Megan Catback, Moog Endlinks, ES swaybar bushings & MM. Suspension will be installed after winter along with 6th gen bbk.
94maxteamrtv is offline   Reply With Quote
Old 06-01-2009, 08:05 PM   #15
So the best fix, it sounds like, is to figure a way to add lighting to the cluster.
Any ideas out there?
__________________
Old 06-02-2009, 12:31 PM   #16
I guess so. The only thing is that there is such little space in there that I have no idea what would fit inside. I had mine completly apart and the only space you really have is where the florcesent tube already is. You would need to find something similar for even light. I dont think you can hard-wire the current tube to light on your dimmer switch because there are like 10 prongs that connect it to the board, not simple wiring.
__________________
Old 06-02-2009, 05:55 PM   #17
Old 06-05-2009, 12:47 PM   #18
+1, I just got my led strip so I'm going to try to see if I can get it to work...
__________________
Old 06-05-2009, 06:23 PM   #19
Thats great....please keep us updated! Thanks
Old 07-04-2009, 07:57 AM   #20
Anyone have any updates on a fix yet? (successful or not??)
Old 07-04-2009, 08:10 AM   #21
Send a message via AIM to ZGadson
This is not what I wanted to see posted here. I had a '92 Lexus with the same type of dash illumination. Because the car was older, the chance of the dash lights failing were higher - which is why, as the cars got older, the prices for new gauge clusters got higher. Within 2 years, clusters posted on ebay and other sites rose from $200 up to $500 just because they were in high demand and our only option.
They were designed to be replaceable by the dealer only. There are no replacement bulbs- new gauge clusters were only sold as whole pieces with the illumination system built into the plastic, so if your lights were dead, you had to spend the $1400 for the whole gauge cluster, or shop ebay.
The same thing is coming for our cars. Extortion at it's finest.
__________________
ZGadson is offline   Reply With Quote
Old 07-04-2009, 11:35 AM   #22
I wonder if the I35 has the same problem. Again, on the A33 I30 clusters, I believe the bulb is not to blame, it is the main board itself. I replaced the bulb and got the same results. The bulb is replaceable just not sold. You have to take it from another cluster.
__________________
Old 07-04-2009, 01:54 PM   #23
Exactly. And to get the bulb, you have to buy another whole cluster assembly.
__________________
Old 07-04-2009, 04:49 PM   #24
Got Projectors?
MetaOrbit's Avatar
Depending on the time you have to work on it as well as the cost, re-wiring and installing an A33 Maxima cluster of the same year might be a better long-term solution.
__________________
:: John ::
Old 08-01-2009, 12:05 AM   #25
Well guys, I got it to work ! I was thinking it was going to be a nightmare but it was actually fairly easy. I'll post a how to when I get a chance, I'm pooped now .
__________________
Old 08-02-2009, 12:41 PM   #26
OMG please post when you rest up.....(I've been considering just buying a new cluster to fix the problem but it was too expensive)
__________________
Old 08-12-2009, 10:24 PM   #27
Well everyone, I did the unthinkable, got it to work! I also posted a how-to here...
00-04 I30/35 EL bulb to LED strip how-to...
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
