Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-01-2009, 11:06 PM   #1
Send a message via AIM to speed3000gt Send a message via Yahoo to speed3000gt
"HOW TO" remove fog lights on '96-'99 I30
Can somebody tell me how to remove the fog lamps on the '96+ I30? I've removed the underneath sheilds and cant find the screws/bolts holding the fog lamp in place.... Is there a how to on this somewhere?
__________________
1997 I30
speed3000gt is offline   Reply With Quote
Old 05-02-2009, 10:42 AM   #2
G-string Money Tight.
JNCoRacer's Avatar
Send a message via AIM to JNCoRacer
There should be a bolt holding the corner fog on. Then you should be able to access the bolts holding on the fogs themselves IIRC.
__________________
DNE VP
www.nissans.org
JNCoRacer is offline   Reply With Quote
Old 05-07-2009, 01:56 PM   #3
DCP
there is a 10mm bolt holding the corner lamp on, that needs to be accessed from under the car. Once the Corner lamp is removed you will see another 10mm bolt facing toward the front of the car. Remove this bolt, and the foglight will pull out.
DCP is offline   Reply With Quote
Old 05-11-2009, 12:31 PM   #4
Send a message via AIM to FFxI30
After removing the 10mm bolt holding the corner lamp (mine's broken because the body shop put it in crooked and used cheap bolts which are all rusted and broke as soon as I put a socket on it!!), the corner lamp needs to be "popped out" from the front of the car. I use a screwdriver to get between the corner light and the fog light and it popped right out with just a little pressure.
__________________
Formerly FFxMax
'98 I30 - 17" G35 Sedan Wheels, Cefiro One Piece Head lights, Frankencar Intake, WSP Y-Pipe, 20% Tint
FFxI30 is offline   Reply With Quote
Old 05-19-2009, 06:19 PM   #5
thanks guys
__________________
1997 I30
Old 06-15-2009, 03:33 PM   #6
What is the purpose of the corner part? Is there a bulb inside? I just got the car and haven't had time to look under/around but it seems useless if looking at the car from the front. Please help me out here.
my98i30 is offline   Reply With Quote
Old 06-15-2009, 04:37 PM   #7
Send a message via AIM to Navara330
Quote:
If its anything like me 01 i30 its a a turning light that goes on with the turn signal.
Navara330 is offline   Reply With Quote
Old 06-15-2009, 06:37 PM   #8
Send a message via AIM to adamsanders
Quote:
Yep, that's what it does.
adamsanders is online now   Reply With Quote
Old 06-16-2009, 10:50 AM   #9
Thanks. One last question. Is it white? I don't know if I called it the right thing last time. I am talking about the piece right next to the fog light. It's pointed kind of at 45 degrees. I didn't see a colored bulb or anything and thought it would be weird to have a white turning light. If I called it the wrong thing last time, I apologize. What would this piece be for?
Old 06-16-2009, 12:59 PM   #10
Its a turning light that goes on when you flip on the turn signal.
Maximas have the same thing but there's have a more integrated look
to them and are higher up. If the bulb is blown in it it wont light up for that
side...
defiance is offline   Reply With Quote
Old 06-16-2009, 12:59 PM   #11
and yes it is white
Old 06-16-2009, 01:54 PM   #12
Thanks. Yeah, the Maxima's look like it belongs. This just looks like an extra piece of glass they threw in cause they thought it looked cool. I'll check bulbs tonight. Thanks again.
Old 06-17-2009, 02:27 PM   #13
Are there other headlights that fit the a32 other than the cefiro? This could be from other infinitis, nissans, acuras, whatever.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
