Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-18-2009, 02:18 PM   #1
Send a message via AIM to AznTran517
Fried ECU...
I think my ecu is fried since my IACV went bad. I went to the dealer and they wanted $815. I think that's crazy... One of my question is can I go to the junkyard and get a 00-01 Maxima ecu or it has to be and i30? Also do I have to get it installed by the dealer?
AznTran517 is offline   Reply With Quote
Old 04-18-2009, 02:39 PM   #2
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Quote:
Should be fine with any 00-01 max or I30 ecu, except if the year and/or fed/cali spec emissions doesn't match you'll have a few cel's without doing some work.
You don't have to go to them to put the actual ecu in, but you do need to spend (usually $75) for a consult nat's program whenever you swap the ecu on an immobilized car (99+). To save yourself some money you can remove your ecu yourself, leave it plugged in and laying on the passanger floor, swap it in the parking lot and have the program done and finish the install yourself.
__________________
Gatorade on my keyboard FTL.
5th & 5.5 gen VLSD Auto transmissions for sale, PM me.
Cheap VIAS block plates
Dual-mass 6-speed flywheel resurfacing available!
NX wet kit w/digital gauge $400 shipped
KRRZ350 is offline   Reply With Quote
Old 04-18-2009, 02:47 PM   #3
How easy is it to remove the ecu?
Old 04-18-2009, 05:50 PM   #4
Why do you think the ecu is bad? Did you change the IAC valve and try a relearn first?
Absolutt is offline   Reply With Quote
Old 04-18-2009, 07:30 PM   #5
I did change the IACV but my mechanic did a power test and said that its not responding and it's either the ecu or the wiring so I'm suspecting its the ecu.
Old 04-19-2009, 06:36 AM   #6
KRRZ350's Avatar
Quote:
I would have said the same thing, since it's very very rare for a nissan ecu to take a dump, but it's a known issue on the 5th gens, the iacv fails (probably an internal short) and takes out the ecu. Thing is I don't know if anyone has ever bothered to take there fried iacv 5th gen ecu apart, it could be a very easy fix and once it is out it's very easy to take it apart and give it a quick visual check.
Haven't had the pleasure of taking an ecu out of a 5th gen yet, but on 4g's it depends whether it's auto or stick how I go about it. But don't try to take the ecu out of the bracket, it's an insane nightmare, so much easier to remove the 10mm bracket bolts instead of the ecu to bracket screws. AZfter that you just cut the wire clips, bend the bracket a little, and take the whole bracket & ecu out. Doing it this way on a 4g makes a 2hr job a 2 minute job, seriously.
__________________
Old 04-19-2009, 08:50 PM   #7
Send a message via AIM to dineth00i30
damn so im sure my ecu is fried too. i have idle problems. (it idles high after driving in stop and go)
__________________
| Tint | Grounding Kit | 8k Heads & 3k Fogs | Clear Corners with L.E.D's | Hyper White L.E.D License Plate | Half Roof Spoiler | Black Roof Vinyl | 12" Sub with 400w AMP | Smoked Tails | S-tech (F) H-tech (R) with Illuminas |
dineth00i30 is offline   Reply With Quote
Old 04-20-2009, 09:00 PM   #8
Followed your steps and it came out pretty easy but i'm pretty sure installing it myself will be a nightmare! lol... Well actually my uncle owns a junkyard and we have a bunch of imports and I took the ecu out of a 5th gen Auto Max. I dont know if it had traction control or not(parts car missing dash parts). My question is how can I tell if this ecu will work or not?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
