Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-06-2009, 07:55 PM   #1
So i bought a I30, seemed like a great deal....
So i bought a 2001 I30 with 134,000 miles for $2700. The car would not start due to dead battery and idle issues. It also had a check engine light.
I knew it had a few issues, but I was hoping i could fix them relatively cheap.
Here is so far what i found and fixed.
Charged the battery, the car would start but not idle.
Had codes for Maf and IACV valve. Bought a new maf, car would run a bit better, but the idle was still crappy. Also the charge light was on, so found out the alternator was dead.
Started taking it apart to replace the alternator and both axles had CV boots totally ripped. So i bought 2 new axles, while looking at the front struts, both were leaking. So i bought 2 new struts.
2 days of hard work and I had struts installed, alternator replaced. Axles installed as well.
Started working on the idle issue, bought a new IACV, installed it, but it still doesnt idle and won't relearn. So i searched this forum and found that ecu can be damaged from a bad iacv valve.
30 minutes of cursing and busted knuckles had the ecu out. Open it up...... and 2 chips are blown and seconary damage on the pcb.
So now the question is, who knows a good place for cheap ECU's or a good repair facility?
Also when the car is running i can hear a hissing noise by the intake manifold, i sprayed some misty water on it, but i can't see any leaks. Could the noise be normal?
Kaane is offline   Reply With Quote
Old 03-06-2009, 08:21 PM   #2
call daveb
pchau is offline   Reply With Quote
Old 03-06-2009, 08:45 PM   #3
wat
AceofSpds's Avatar
Send a message via AIM to AceofSpds
www.car-part.com
__________________
00' Maxima
95' 240sx
AceofSpds is offline   Reply With Quote
Old 03-07-2009, 07:48 AM   #4
You can't friend yourself
Kevlo911's Avatar
Ya car-part.com and ebay.
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 03-07-2009, 07:53 AM   #5
Willing to learn
oldngivout's Avatar
Hissing is due to upper intake manifold gasket leak. You might as well fix that while you're at it. It will run a lot better when cold then.
After it's all fixed, either replace the ECU in the dealer parking lot or be prepared to tow it there. You won't be able to start the car at all with the replacement ECU, until is reprogrammed by the dealer with Consult.
__________________
Unless you do it exactly like I did, your results may vary.
oldngivout is offline   Reply With Quote
Old 03-07-2009, 07:54 AM   #6
MaXXiN
MaXiM@KiD's Avatar
Send a message via AIM to MaXiM@KiD
Auto or 5spd. Does anyone know if the 00 and 01 are the same? I know it's 3.0 but is did the egr or anything change? I'll PM this guy I know that had a 00 ECU he might still have it but I think it's 5spd...Also when you change the ECU you have to re-program the key
MaXiM@KiD is offline   Reply With Quote
Old 03-07-2009, 08:05 AM   #7
Willing to learn
oldngivout's Avatar
He has an I30.
All 2000 I30 are auto, CA emissions.
__________________
Old 03-07-2009, 08:16 AM   #8
MaXXiN
MaXiM@KiD's Avatar
Maxima...err 5spd and fed spec too..sorry I couldn't be of more help
Old 03-07-2009, 11:28 AM   #9
Maxgig's Avatar
Keep a record of what you spend getting it properly road worthy. Once you're done you should have many miles of trouble free driving and you'll see that it was money well spent
__________________
03 SE Sterling Mist, 6 spd, T.E. 89,452 miles - Stillen FSB - Hawk pads - 350Z AE rims - Cosmo CAI - 35% tint - Redline MT90 - rear louver - track visors - 04 valve cover fix - 3&5mm wheel spacers - free STS mod...more 2 follow, 97 SE "SuperBlak," Max, 147,275 miles "SOLD": see the Mist www.cardomain.com/ride/831971 new toy "69 Mercury Cougar" blk tag, #'s matching, blueprinted, rebuilt 351W, blk on blk, super faaast, picked up 30 July
Maxgig is offline   Reply With Quote
Old 03-07-2009, 02:47 PM   #10
Anyone have the part number or picture of which manifold gasket goes out? While waiting for a replacement ecu, i want to tackle it.
Old 03-07-2009, 04:06 PM   #11
Send a message via AIM to turbizzy
Autozone also rebuilds ECMs for like 100 bucks. Might wanna give them a call.
__________________
turbizzy is offline   Reply With Quote
Old 03-08-2009, 12:06 AM   #12
autozone rebuilds ECU's??? since when?
Old 03-08-2009, 12:41 AM   #13
ebay
Brianm0121 is offline   Reply With Quote
Old 03-08-2009, 12:07 PM   #14
Does anyone know if a 2000 ECU will work in my car? Or are 2000 and 2001 different?
Old 03-08-2009, 02:58 PM   #15
Quote:
They rebuilt a customer's 1990 J30 ECM because he didn't wanna for out like a grand for a new one. I told him he could try that but no gaurantees from us it would solve his problem. Got it done and haven't seen him since.
You have to go in person because the parts guys sometimes aren't very bright so you have to kinda guide them through it, make sure its engine control module, i think its under emissions or powertrain section in their catalogue. Youll need to bring in your old one.
__________________
Old 03-08-2009, 06:37 PM   #16
I had the same issue and got a 01 Maxima one from car-parts.com for 130 bucks. Since it wouldn't idle and it is still cable controlled, i just put a little rubber ring behind the throttle body and that let me drive it to the dealership.
__________________
MODS:
Illuminas + Eibach | Stillen FSTB | Progress Rear Swaybar | 10mm Front/ 25mm Rear Eibach Spacers | Unorthodox UDP | Stillen Y-Pipe | HKS Rear Section | InJen WAI | Shinjinduo Grounding Kit | 300ZX BBK | Ionic Dynamics Bodykit | Ebay Projectors | Foglight HIDs |License Plate LEDs | Blacked out grills | Pioneer Avic-D3 | Interior LEDs
McSteve is offline   Reply With Quote
Old 03-08-2009, 09:00 PM   #17
Willing to learn
oldngivout's Avatar
2001 Max ECU may work in a 2001 I30 since the updated part number for each one is the same.
Seriously doubt if the 2000 Max will work, but the 2000 I30 might. Why not just get the correct one?
__________________
Old 03-09-2009, 12:18 AM   #18
Because I can't find any I30 2001 ecu's for sale. Only thing on carpart are maxima ecu's and they dont list if they are federal or california models. I dont want to get a federal maxima one and have issues.
Old 03-09-2009, 12:21 AM   #19
I just told ya man, TRY AUTOZONE!
__________________
Old 03-09-2009, 11:31 AM   #20
Willing to learn
oldngivout's Avatar
All 2001 Maximas are CA emissions.
Car-part is an excellent resource for interchangeability of components. 2001 Max ECU will work in a 2001 Maxima also.
__________________
Old 03-09-2009, 03:03 PM   #21
ok great thanks a lot.
Old 03-13-2009, 04:38 PM   #22
Find a junk yard.. car-part.com
I snagged so many expensive things on my car on the cheap at the local junkyard.
__________________
1999 Infiniti i30 - FSTB | Warpspeed Y | Progress RSB
2006 BMW 330i Black on Terra Leather 6MT - ZSP | ZPP | ZCP
talisman311 is offline   Reply With Quote
Old 10-12-2009, 06:43 PM   #23
had to replace ecu in my 1996 i30 . place out of texas had a rebuilt with one yr warrenty 100$ 888-217-4072
the number came from websit talisman311 is referencing to.
ericks_i30 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
