Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-09-2009, 08:41 AM   #81
Send a message via AIM to ZGadson
Quote:
Originally Posted by aidar77 View Post
Nice!! Thanks for the response! I guess I will have some fun time this weekend )
Well, speaking of the wheel controls, I have to disagree a bit with you. It would've been the case a couple of months ago when I started to project my very own CarPC, but just ten days ago I discovered the greatest invention of all - the Soundgate AUXNISSV3, which you can still buy on ebay!! )
So, as a result now I am not planning to remove the Stock Bose and saving tons of money (well, relatively)! Instead, I'm going to use my laptop, which I'm putting it under the seat and plugging it into a 400w power inverter, which is powered through the rear cig outlet. So, the gps is connected through usb (i heard that bluetooth gets weird from time to time), and an external antenna through a rather long wire goes through the side stand (behind the seatbelt) all the way to the moonroof - actually there is space between the glass and the car body. All the cables from the screen and the AUX are run under the console, and get out at the bottom left part of the plastic cover of the gear stick. Not the neatest way, but pretty easy to implement... And most importantly, the laptop remains portable )
Well.... that's how I plan (hypothetically) to keep my wheel controls )) I was deciphering the wheel controls and audio unit electric scheme, but I was getting into trouble, because I think that the wiring for nav and non-nav is slightly different for wheel controls... Because I think I couldn't find a similar match on a non-nav
Sounds like its going to be a cool setup! Id love to put my stock Bose headunit back in, but then I'd lose my Navigation. If you look back a few posts, there's a gigantic pic of a stock Mazda nav system - If I can do something like that, where all I need is a screen and a remote control (whereas I can hide the nav computer in the trunk) I can put my Bose unit back where it belongs, rather than in a box under my basement steps. lol
__________________
ZGadson is offline   Reply With Quote
Old 10-10-2009, 05:35 PM   #82
Quote:
Hmm... Why don't you try to do the same thing - get a carPC (read: any netbook), plug it into the RGB through VGA, and output the audio through some aux port? and to control the navi, there can always be used a Logitech DiNovo Mini keyboard, which is the size of a cellphone! also, wire one navigation power input through a switch, so you can control when to open or close the screen...
Btw, i've got a question to your previous response - you are telling me to use a yellow and yellow/black wires... but where do i find them? my screen came without harnesses at all
can you tell me a number on the harness?
I think the monitor harnesses are #192 and #193... (top left on the picture)...
Here's the picture:
SOrry, couldn't find a better quality pic
aidar77 is offline   Reply With Quote
Old 10-12-2009, 03:31 PM   #83
Fortunately for me, my system came with all the wires and harnesses, but I know you can order the screen harness from the dealer (for a pretty penny, I'm sure) but there's also still that car-part.com. I'm sure they've got a harness for the screen though. There's only 6 wires that come out of it (R, G, B, +,-, and a remote wire for the up/down function).
__________________
Old 10-21-2009, 05:03 PM   #84
Whats up Z.. I've been a ghost in here since I bought my new condo in April. I'm giving up on the existing Navi and plan to gut the OEM screen and install an aftermarket VGA monitor with RCA inputs.. None of the convertor boxes out there seem to get a fixed picture on the screen without ground loop interference.. My phone (ATT Fuze has Video out and my next phone HD2 (US version) will have video out as well. Audio will route through my existing ghetto rig Aux in which I use daily...
Any screen out there that you've seen that are releatively the same size & depth needed to allow the lid to close completely? I still need to do a bit of research to package up a solution.
__________________
03 I35: Transgo Shift kit, Spark advance, Hyperground kit, G35 wheelies, Black n Tan Interior, LED rear conversion.
Norkoastal is offline   Reply With Quote
Old 11-16-2009, 12:46 PM   #85
Nork, any updates to your nav yet?
I'm about to play again. I've had an aftermarket screen forever that is going to replace the OEM pop-up screen. It should fit exactly like the OEM screen, but I need to swap them out with some fabrication first. The one I have is even a touch screen, so I hope I can make it work properly. I found a stand-alone GPS system that should work with the screen, but I haven't bought it yet because its $400. Its got a remote and has an input for a 6 disc DVD changer. Even if the touch screen part doesn't work, the remote will be enough.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
