Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Thread Tools Display Modes
Old 07-31-2008, 02:32 PM   #1
Does anyone notice or feel a small click in their shifter when braking?
I'm in the process of diagnosing my tranyy since it developed a spike (floor it when on the freeway to pass, the RPM's surge, but the car doesn't go faster or drop gears) over the last week.. Wasn't sure if this might be another sign of something electrical going on.. Only electrical mods are led lights all arround the car.
To test, feel your shifter when braking.. Is there a small movement that happens when in drive everytime you hit the brake? Ive been told its the lock mechanism, but I dont think it should engage once in drive.
Thanks!
__________________
03 I35: Transgo Shift kit, H&R front drop with Illuminas 2F-2R, Stage 2 LTB, Progress RSB, FSTB, Front Sway ES Poly Bushings, Spark advance, Hyperground kit, Clear front corners, G35 wheelies, Black n Tan Interior, LED rear conversion.
Norkoastal is offline   Reply With Quote
Old 07-31-2008, 02:41 PM   #2
大 陆 弟
n3985's Avatar
Completely normal
__________________
n3985 is offline   Reply With Quote
Old 07-31-2008, 03:12 PM   #3
Glad to hear!!! Time to troubleshoot the TCM.
__________________
Old 07-31-2008, 03:46 PM   #4
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Yeah, this was talked about to Infinium on the 5th gen board quite a while back. I feel it when in park or very slow speeds (coming to a stop. But not when on the highway or even cruising speeds.
Seems like it might be a relay which tells the lock out switch when it is ok to shift the shifter in or out of park, i.e., if your foot is on the brake.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 07-31-2008, 05:27 PM   #5
Kind of wierd it clicks when in drive.. If its normal Im dropping it off my "concerned parts" category.. Unfortunately I have a tranny issue thats shown its ugly head so Im reducing as many variables as possible. The car is rev spiking off an on when I floor the gas on speeds around 60+. Feel like the motor revs, but the tranny doesn't bite thus keeping the car at the same speed. Time to swap fluids and see if any debris is found.. After that is swapped (assuming clean fluid) its off to install a new TCM.
__________________
Old 08-01-2008, 12:53 PM   #6
Certified Hooptie
NmexMAX's Avatar
The click is normal, but on the rev issue.
Could this be the end ...
__________________
Old 08-01-2008, 03:14 PM   #7
I think the click is the lock for the shifter so you can put into Park/Drive
__________________
Why mod a POS?
C P Squared is offline   Reply With Quote
Old 08-01-2008, 05:21 PM   #8
Cant say its to that point as its off and on (happened twice) and only when I floor it on the freeway.. Off the line it roasts like usual.
Im thinking TCM or shift solenoid is starting to go since the upshifts are smooth and buttery.
__________________
Old 08-06-2008, 11:31 AM   #9
Certified Hooptie
NmexMAX's Avatar
Being that it doesn't try to drop a gear even when floored, I would to the TCM or solenoid.
When I floor mine @ 60MPH, it drops down to 2nd, slips like hell, bounces off the limiter for a while, then sloooooooooooowllllllllly engages.
If i do it and it goes to 3rd, it drives just fine.
__________________
Old 08-06-2008, 01:49 PM   #10
^^ That sounds about right.. Dropping to second is where the issue is.. 3rd seems good for the most part. I need to do more testing on this since I dont floor it everyday on the freeway .
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
